Page 1 of 1
Does 6502 have any hidden registers?
Posted: Mon Jul 27, 2020 7:28 pm
by JustClaire
Hello
I have been wondering, what hidden registers does 6502 have if any?
By hidden registers i mean registers that are not available to the programmer at all, cant be directly modified or read by any instructions and are only used for internal CPU operations.
For example in a hypothetical CPU a hidden register would be a swap register used only to temporary hold register values when swapping between registers.
Re: Does 6502 have any hidden registers?
Posted: Mon Jul 27, 2020 8:17 pm
by BitWise
Not really. The diagram at the end of the Hanson paper shows all the registers and latches in the chip
https://projects.ncsu.edu/wcae//WCAE1/hanson.pdf
The 6502 sometimes uses ALU is temporary storage area during some operations but there aren't any hidden registers as such. Its pretty minimal in its design.
Posted: Mon Jul 27, 2020 9:01 pm
by Dr Jefyll
One might consider the Instruction Register (IR) as being used only for internal operations. Unlike A X Y P and PC this register has no explicit instructions to modify it. But, as Bitwise said, it *is* noted in Hanson's diagram.
