Page 1 of 1
Apple IIGS GSOS 6.0.1 source
Posted: Sat May 23, 2020 11:53 am
by handyandy
At the request of someone from another family of 6502-based computers (Atari) with a retro-fitted 65816 hardware enhancement, I searched for and found the source for the 16 bit operating system GSOS for the Apple IIGS:
https://archive.org/details/GSOS_6.0.1_source
If nothing else, it's a good resource for writing code for the 65816 in assembly language.
Andy
Re: Apple IIGS GSOS 6.0.1 source
Posted: Sat May 23, 2020 12:22 pm
Oh yes, always good to see a big chunk of solid code. Here's a snippet from
HS.FST.src indicating both a calling convention and a documentation convention:
* Name: Appl_call
* Description: Entry point for all application calls. Called by GS/OS only.
* Validates call before passing control to call handler.
* Created: Oct 6, 1987
* Modified: Mar 5, 1991
* Author: Bryan Atsatt
* Entry: jml
* Input: A = undefined
* X = call number times 2
* Y = class number times 2
* P = nvmxdizc
* ..000...
* Output: A = error code if carry set
* X = undefined
* Y = undefined
* P = nvmxdizc
* ..000..1 = error
* 0 = no error
* Exit: jml sys_exit
* Uses: Everything!
and a simpler example:
* Name: add_separator
* Description: This routine will insert a class 0 or 1 separator at the
* beginning of the gstring pointed to by X and Y.
* Created: Nov 6, 1987
* Modified: Nov 6, 1987
* Entry: jsr
* X = low byte of pointer to gstring
* Y = high byte of pointer to gstring
* P = nvmxdizc
* ..000...
* B = K
* class ;class of call.
* Output: A = undefined
* X = undefined
* Y = undefined
* P = nvmxdizc
* ..000...
* B = K
* Exit: rts
* Uses: all registers
* input_string
* length
