Page 1 of 1
Cmod + 65816
Posted: Sun Jun 30, 2019 2:51 am
by Rob Finch
I've got this project going on in the background with my other work to interface a CmodA7 to a 65C816. It doesn't quite work yet. On reset the blue LED lights up indicating the cpu is accessing the ROM, but it doesn't light up another led like it's supposed to or send a power on message. The cmod contains a high-speed uart (921600 baud), ram, rom.
- Block Diagram
- Photo of system
Re: Cmod + 65816
Posted: Sun Jun 30, 2019 4:21 am
by barrym95838
921600 baud seems (for this old-timer) to be rather ambitious for an initial goal. Definitely keep us posted, and provide additional info if you decide to seek any advice from the resident hardware gurus.
Re: Cmod + 65816
Posted: Mon Jul 01, 2019 4:01 am
by Rob Finch
It’s serial through USB so it can be fast. I’d go with an even higher baud rate but 921600 was the highest listed for the device in Windows. The rate is high enough that simple text screen can be emulated through the serial. 921k is about 91kB per second. Which is about 3k characters at 30Hz refresh rate.
The ‘816 isn’t actually transmitting directly through the port. Instead it writes to dual port memory. The other side of the dual port memory is connected to the uart transmitter in a DMA fashion. The DMA just loops around repeatedly through the transmit buffer. So, the transmit buffer somewhat resembles a text video buffer.
There’s a program running on the PC workstation that can pick up this repeated transmission and display it in a window. The baud clock (14.7MHz) is about 0.25% too slow but it seems to work okay.
- HelloWorld
- HelloWorld.png (3.74 KiB) Viewed 1506 times
The "hello world" is hard-coded in the transmit at the moment.
The cpu is powered by about 3v and clocked at 6MHz. Two power diodes are used to drop a 4.5v USB power down to about 3v.
Found two bugs yesterday, the reset line going to the cpu was active high and it should be active low, and the ready line needed a pullup resistor. Initially I forgot that the ready line is bi-directional on the ‘816. Then I made it a tri-state I/O on the FPGA but forgot the pullup.
Re: Cmod + 65816
Posted: Mon Jul 01, 2019 9:23 am
by Rob Finch
I hooked up the logic analyzer to the inputs from the 65c816 and found out it's mostly garbage. It looks like I bought bad/fake chips. Unless there's something else wrong with the system.
From the logic analyzer, the vector pull line doesn't go active on reset, and the address bus is all ones. I've seen it reset to $FFFC and flip back and forth between $FFFC and $FFFD doing a vector fetch non-stop, but with no active vector pull. This is the second chip I tried. The first one didn't work at all.
- Logic analyzer trace
Re: Cmod + 65816
Posted: Wed Jul 10, 2019 6:28 pm
by tingo
I didn't know what a Cmod A7 was, so I googled it:
https://store.digilentinc.com/cmod-a7-b ... ga-module/
So it's an Artix-7 (plus more) on a breadboard module.
