Commodore DOS-compatible filesystem with > 256 byte sectors?
Posted: Wed Apr 17, 2019 6:40 pm
I'm wondering if anyone knows of a Commodore DOS-compatible file storage device or server software that runs on a (e.g.) Linux PC which uses (and exposes) sectors larger than 256 bytes.
CBM DOS filesystems are limited to 16MB partitions because of the two bytes used for pointers in the filesystem. However, a 512-byte sector size would allow the partition limit to go to 32MB. A 4096-byte sector would, for example, allow a partition to reach 256MB, and so forth.
Yes, I'm aware that other elements of the filesystem would change as well. E.g., side sectors for REL-files would likely have very different layouts, etc., as would the relationships between super-side sector and regular side sectors. But, on the whole, it seems CBM DOS commands are high-enough level that they should be supportive of larger partition sizes. That said, strict CBM DOS-compatibility is not a hard requirement.
I'm just wondering if there are open source projects along this line which I can study.
Thanks.
Thanks.
