Fast CRC without tables
Posted: Tue Nov 23, 2004 2:46 pm
Hello all, I was browsing the source code repository and remembered I had written a fast CRC routine a few years ago. So I thought I would contribute it, as it might come in useful for anyone developing TCP/IP stacks etc.
These routines are entered with the next byte of data in A and the current CRC in zero page memory. For the first byte of data CRCLO and CRCHI should contain $FF, and in the case of CRC8, CRC should contain $00. On exit A is clobbered and the updated CRC is in the zero page locations.
All code below is relocatable. Sizes and execution times listed do not include the final RTS, and code is assumed to be page-aligned.
The following routine implements a CRC-16 cycle in constant time, without tables.
36 bytes, 62 cycles, AXYP clobbered.
Alternative ending:
39 bytes, 66 cycles, AXP clobbered, Y preserved.
With a starting CRC of $FFFF, the binary string $01 $02 $03 $04 should evaluate to $89C3.
For comparison, a shorter routine can be derived from Paul Guertin's MAKECRCTABLE in the repository:
24 bytes, 128..256 cycles, AXP clobbered
Here is a CRC-8 routine in near-constant time where memory constraints do not permit tables:
20 bytes, 25..27 cycles, AP clobbered, XY preserved.
With a starting CRC of $00, the binary string $01 $02 $03 $04 should evaluate to $E3.
Variations:
a) If the application demands constant time then BCC *+2 ($90 $00) can be inserted at UP1 and UP2:
24 bytes, 31 cycles.
b) Making a loop from the repeated code is barely worth one's while:
18 bytes, 36..38 cycles, AXP clobbered, Y preserved.
CRCLO EQU $6 ; current value of CRC
CRCHI EQU $7 ; not necessarily contiguous
CRC16_F:
EOR CRCHI ; A contained the data
STA CRCHI ; XOR it into high byte
LSR ; right shift A 4 bits
LSR ; to make top of x^12 term
LSR ; ($1...)
LSR
TAX ; save it
ASL ; then make top of x^5 term
EOR CRCLO ; and XOR that with low byte
STA CRCLO ; and save
TXA ; restore partial term
EOR CRCHI ; and update high byte
STA CRCHI ; and save
ASL ; left shift three
ASL ; the rest of the terms
ASL ; have feedback from x^12
TAX ; save bottom of x^12
ASL ; left shift two more
ASL ; watch the carry flag
EOR CRCHI ; bottom of x^5 ($..2.)
TAY ; save high byte
TXA ; fetch temp value
ROL ; bottom of x^12, middle of x^5!
EOR CRCLO ; finally update low byte
STA CRCHI ; then swap high and low bytes
STY CRCLO
RTS
Alternative ending:
STA CRCHI ; save high byte
LDX CRCHI ; then swap high and low bytes
STA CRCHI
STX CRCLO
RTS
CRC16_S:
LDX #8 ; A contains the data
EOR CRCHI ; as we now have the high byte
BITLOOP ASL CRCLO ; in A, things are the other
ROL ; way round from MAKECRCTABLE
BCC NOADD
EOR #$10 ; high byte of polynomial
PHA
LDA CRCLO
EOR #$21 ; low byte of polynomial
STA CRCLO
PLA
NOADD DEX
BNE BITLOOP
STA CRCHI
RTS
CRC EQU $6 ; current value of CRC
CRC8:
EOR CRC ; A contained the data
STA CRC ; XOR it with the byte
ASL ; current contents of A will become x^2 term
BCC UP1 ; if b7 = 1
EOR #$07 ; then apply polynomial with feedback
UP1 EOR CRC ; apply x^1
ASL ; C contains b7 ^ b6
BCC UP2
EOR #$07
UP2 EOR CRC ; apply unity term
STA CRC ; save result
RTS
Variations:
