ZIF socket giving me headaches.
Posted: Fri Feb 08, 2019 4:30 pm
I fired up my SBC again and starting writing more code.
When I built my SBC, I made a mistake and put a DIP socket in the ROM. Later, I decided to put a ZIF socket in but I didn't want to pull out the DIP socket. I should have used the ZIF socket initially.
Not that it would have mattered too much...seems the ZIF socket is a piece of crap. I'm going to test it tonight but I think some of the pins are not making a connection.
Unfortunately, I don't have another ZIF socket. Good ones are surprisingly expensive.
So, I was wondering if there is another way. A way to quickly get new code over to my AT28C256.
Another foobar on my part is that I didn't create an easy way to program the EEPROM in circuit.
Now I'm wondering what my options are.
What would be cool would be a way to add an upload to my make/build process.
Worse case, I might make a small board that has wires going to my programmer and my SBC. I could just turn off the SBC when programming. Not sure what running the SBC will do to my programmer, however.
Something else I've considered is to use an Arduino or something similar in the loop. Either as direct ROM (albeit, slow) or as a programmer.
I have one of those fancy ESP32's as well. That thing is wireless and might be fast enough for general purpose ROM. And it has 32 GPIO, IIRC. Just need voltage translation.
What are you guys doing to quickly get code into your SBC?
PS
My long-term goal is to write a minimal monitor that will pull new code over serial. But, I need a faster way of getting that minimal monitor installed.
PS
