I'll add a couple comments.
6) Paper to do the transfer - I use HP High Gloss Laser Paper, 200 sheets to a box, 95 brightness, partnumber Q2419A
After last pass thru the laminator take immediately and place under cold running water for a few seconds for each side, then put it in the separation bath. It won't take long, you will be able to tell easily when the paper is coming up. Gently peel the paper off. You may need to rub the board carefully with the waste paper or your finger to remove any excess residue.
I tried a number of different papers looking for something that would work
fairly well and be commonly available.
I settled on Epson "photo quality glossy paper" S041124
which worked far better than anything else I tried. It generaly just floats
off after a brief soak in warm water. Usually some of the sizing
(which acts as a release) remains, I just gently brush it off with a paint
brush under running water. None of the paper ever remained on the
board and my experience is that it's real easy to damage the pattern
trying to rub paper off the pattern (the fibers remain embedded in the ink)
and if you don't get all the paper off it messes up the result (although,
I've gotten acceptable results for things that didn't need really fine detail
with plain old photo copies)
I didn't have any luck with any of the HP papers I tryed, but I don't recall
which ones exactly I did try. I do recall that the absolute worst
paper (for this usage) was an HP photo print type paper made specifically
for laser printers (just about needed a chisel to get it off the board
2) Muriatic acid. I just bought a gallon of it from Lowes
3) Hydrogenperoxide (sp?) - won't need to much of this, I keep a large bottle of it around, it's lasted quite a while
Making the cupric chloride...
This is the one part I don't feel comfortable talking about. I am not a chemist, and followed directions off of a website I don't have the link to, but if you search for cupricchloride pcb etching, you should find the recipe. Basically it's a portion of HCl (muriatic acid), mostly distilled water and a little H2O2 (kicks off the process). There is an order to doing this which is why I don't feel comfortable telling you how - one order is safer then the other as it is less likely to splash.
The beauty of this mixture is that it lasts forever and can be easily neutralized when done. I have my batch that I started over a year ago, and it still works. if it gets a little slow to start, I just add some H2O2, and it works well again.
I've always heard this called peroxy-acid or acid-peroxide
Not sure where the term cupric chloride is comming from, except that that
may be what you get when you etch a board using hydrochloric (Muriatic)
acid in the mix. I believe they add copper sulfate to the etchant,
if they're using sulfuric acid, as a sort of stabilizer or buffer to make the
action of the etchant more predicatable.
Perhaps the same sort of thing is done with hydrochloric acid (though I
didn't see any mention of that in the above description).
I think it's more usual to use sulfuric acid but I wouldn't swear to that.
I use the same stuff, pool acid, fuming hydrochloric acid
with a little sulfuric acid thrown in as a stabilizer, sold in two gallon boxes
for $4-6 around here, used to adjust pool PH
If you've never used the stuff be advised.
IT'S FUMING ACID, IT GIVES OFF ACID FUMES ANYTHING THAT'S REMOTELY
MOIST THAT THE FUMES COME IN CONTACT WITH WILL BECOME ACID!
(yours skin, your eyeballs, your lungs)
One good lungful will probably only make you wish you could die, two
will probably kill you
Having said that, it's not all that dangerous as long as you're carefull and
don't spill/splash it and work with good ventilation.
I use it for cleaning the bathroom fixtures and the like.
They sell a slightly less potent form of basically the same thing
(25% acid versus 35%) (at a much higher price, several dollars a quart)
for cleaning toilet bowls.
And if you get a whiff you'll know it, but you may not notice it attacking
your eyeballs untill they fog over or something. (no, I never let that
happen to me, I'm just guessing
Peroxide-acid mixtures are reputed to decompose spontaneously in a runaway
exothermic reaction if you get them too hot (imagine it as taking the lid off
a bottle of warm soda only with a fuming acid mixture that eat's metal)
I've tryed to cause this to happen and never managed it so I don't think it's
much of a danger, but be advised.
I use ordinary 3% medicinal hydrogen peroxide which I reduce by about
2/3 by heating gently on the stove top in a stainless steel pan, and I do
mean gently. If it's forming bubbles at all, it's probably too hot.
I'm really just warming it some to encourage evaporation, nothing close
to boiling or simmering.
Having said all that about the acid, it's the hot concentrated peroxide that's
dangerous. My experience is:
>>IT WILL EAT THE FLESH OFF YOUR BONES<<
Get a splash of fuming hydrochloric acid on you're hand, no sweat, go rinse
thouroughly.
Get a drop of hot concentrated peroxide on your hand, too late, you've got
a patch of dead skin.
No I've never had it literally eat the flesh off my bones but I have managed
to get a drop on my hand and personally, I wear goggles when I'm doing
this stuff.
I believe, when diluting acid with water, it's generally recommended to
slowly add the acid to the water. The idea being that since it generates
heat as it dilutes you'd rather have some boiling water/dilute acid than
the acid boiling and possibly spattering (if you did it the other way around)
I'm not sure how that should be applied to mixing the peroxide and acid,
but I add the peroxide to the acid because I'd much rather get spattered
with the acid than the peroxide (if that's what's going to happen. I've
never had anything like that happen and I've tryed to get some
boiling/spattering reaction to happen too, just to get an idea of what's
involved and never managed it)
I mix one part of (33%-35%) acid to two or three parts of the concentrated
(3% peroxide, reduced by 2/3) peroxide.
I always make a fresh batch, I've never had the stuff last more than a day
or two. I think the peroxide decomposes.
Perhaps I've made this sound really dangerous, I believe it is dangerous
but I don't think anyone should have any problems if they're careful and
prepared for accidents. I don't think it's any more dangerous than alot of
other things one does daily.
I don't have a laminator and I haven't tryed to make double sided boards (yet).
I've found that it works far better with less spreading of the
toner/etchresist if I heat the board and then press the pattern on to it.
Better to not get the paper hot enough to melt the toner at all.
I pop the board in the oven an a low heat untill it's just starting to change
color (the copper begining to oxidize I expect) then quickly slap the pattern
down on it put a couple of paper towels over it and then press it on with
a rolling pin.
You might think this would damage the board. Maybe it does, but I've
never had any problems, even when I screwed up and got the board so
hot that it started to curl
I think the board only gets up to ~350 F.
Not really directly applicable to press and peel type boards, but might
want to poke around here:
http://www.thinktink.com/
lot's of interesting info.
