Page 1 of 2
6502 compatible peripherals
Posted: Mon Sep 03, 2018 7:50 am
by Atlantis
Currently I am working on a project, that utilizes 6502 and set of other chips to replicate the functionality commonly found in amateur embedded devices, based on modern microcontrollers. More specifically - I want to recreate one of my own designs, using "retro parts", a lot of DIP chips and multiple PCBs connected by ribbon cables.
At this point I am looking for chips providing I/O functionality, that (preferably) could be connected directly to the system bus and accessed via address in memory space. I know how to do it with UART, timers/counters and GPIO. My system generates RD and WR signals used by intel chips, so I can use 8251, 8252 and 8255. I was also able to connect HD44780 display. But what to do with following modules?
- Real Time Clock/Callendar with battery backup. Preferably separate battery. I know about those disposable Dallas modules with non-rechargeable battery built in, but I would rather use something else.
- SPI. Is there something interesting, or should I simply code software emulated SPI, using GPIO chip?
- Ethernet. Is there some solution, except of using ENC28J60 connected to the hardware of software SPI?
- Small amount of non volatile (EEPROM?) memory for storing configuration. Even 512 bytes will be fine.
- CAN bus controller. Not critical in case of my project. I am just curious if there is some solution, compatible with 6502 bus.
Re: 6502 compatible peripherals
Posted: Mon Sep 03, 2018 7:59 am
I think bit-banging SPI (or perhaps I2C) should be a good approach.
For network, it might be worth considering an ESP8266 and UART, which would give you WiFi rather than wired.
Posted: Mon Sep 03, 2018 8:27 am
by ttlworks
Long time ago, I had used two PIC16C65 microcontrollers in a 6502 SBC to do things like
UART, PS\2 keyboard interface, SPI, PWM etc.
PIC18F4680 is available in 40 pin DIP, seems to have parallel slave port, SPI, I2C, EEPROM, CAN, etc.
But I'm not sure if that chip matches your definition of "retro".
...and not everybody likes PICs.
Posted: Mon Sep 03, 2018 8:43 am
by Atlantis
I know I could simply use modern microcontroller, "borrowing" its peripherals. But honestly I would rather like to take more traditional approach, using hardware controllers wherever it is possible. For the same reason I don't want to use ESP8266, however I am aware that would be the easiest way.
Posted: Mon Sep 03, 2018 9:01 am
For a 65-bus SPI IC,
Daryl's 65SPI is nice, but the CPLD he was making it with is no longer available. I think he's all out. I have about five of the 65SPI's here I could let go.
I've bit-banged SPI several times. I have sample code at
http://wilsonminesco.com/6502primer/SPI.ASM . I've also bit-banged I²C several times, and I have sample code at
http://wilsonminesco.com/6502primer/GENRLI2C.ASM .
I've made tiny modules for both SPI and I²C. The I²C EEPROMs are not as dense as the SPI flash memories, which I suppose is because I²C is not as fast, so it would take too long to transfer a big file at I²C speeds. For really compact modules, let me recommend using our
I2C-6 connector for I²C, and our
SPI-10 connector for SPI. These are both very hobbyist-friendly. I have some I²C RTC ICs here that I got to make a tiny RTC module with as well, using a watch battery for backup, but I just haven't gotten around to it yet.
My tiny (half-postage-stamp-sized) SPI-10 flash modules can be seen on the front page of my website, linked below. My
workbench computer has at least 81 bits of I/O, or possibly quite a bit more depending on how you count them. I could approximately double that number by adding four more VIAs if there were room on the main board. It does have fast A/D and D/A converters onboard, and a speaker amplifier to monitor what goes in and out of them.
Posted: Mon Sep 03, 2018 9:31 am
by ttlworks
NXP has parallel to I2C
interface chips like the
PCF8584... but not everybody likes NXP.
Also, it looks like these chips are only available in SMD nowaday.
You probably are better off when Bit_banging I2C per software.
There were CS8900A based
Ethernet interface cards for the C64, but manually soldering a CS8900A ain't fun.
Microchip
MCP2515 is a SPI to CAN2.0 controller.
Microchip
MCP2551 is a CAN transceiver.
Bosch AN82527 was a CAN controller with SPI plus parallel interface, but it's out of production.
Siemens\Infineon
SAE81C90 and SAE81C91 seems to have SPI plus parallel interface, but availability doesn't look good.
Posted: Mon Sep 03, 2018 12:41 pm
by MichaelM
For the non-Microchip Ethernet I/F you asked about, check out the Wiznet product line. Modules are available from Digikey. A module with an SPI I/F you may consider is the WIZ550IO. I haven't not used these chips or modules, but a reputable company built an Ethernet I/F to their equipment for one of my projects recently using these devices, and the I/F worked very well.
Posted: Mon Sep 03, 2018 7:11 pm
by Guus Assmann
Hello,
Check the SJA1000 for Can-Bus. (Not sure if it's still available
For RTC, the good old MC146818.
BR/
Guus
Posted: Tue Sep 04, 2018 11:40 am
by Atlantis
I am not afraid of SMD soldering. In some of my earlier projects I used LQFP/MLF chips and 0402 resistors/capacitors.
I see there are CS8900A also a modules containing CS8900. I assume there are drivers/libraries written in 6502 assembly or ready to compile with CC65?
I know those chips. I've used them in one AVR based project few years ago. If I remember correctly W5100 can even be configured to work on parallel bus. But to be honest, network controller with built-in TCP/IP stack doesn't match 6502 system.
Posted: Tue Sep 04, 2018 11:59 am
by ttlworks
André Fachat had used a CS8900A based Olimex board
with a PET.
On second thought, if you might be using Daryl Rictor's
65SPI peripheral anyway, also take a look at Daryl's
ENC28J60 Ethernet module plus the related code.
Posted: Tue Sep 04, 2018 2:35 pm
by BillO
The PCF8584 are readily available in DIP-20 on eBay. I recently bought 3 of them from a vendor named 'u-barn'. No issues.
Posted: Thu Sep 20, 2018 5:37 am
by Atlantis
I've read the documentation of that chip and I see it was designed rather for 8048/8051 microcontrollers than for 6502. It has data bus multiplexed with address lines, so it would require additional circuitry to implement it into my design.
Is there any other RTC chip with separate data and address lines and straight away compatible with 6502 bus (RW and PHI2 signals) or Intel bus (RD and WR signals)?
Posted: Thu Sep 20, 2018 9:32 am
by GaBuZoMeu
Although I would prefer using an SPI or I²C device you may take a look at TI DP8573A:
It appears to be in production but only as 28 pin PLCC. Mouser listed them, they aren't cheap. The datasheet says there had been a 24p narrow DIP variant as well, but I only found obscure sources and astronomical prices.
ST produces "Timekeeper RAM":
The DIP packaged types (2K or 8K) seems to be monolithic but the SO variant has a "SNAPHAT" containing the crystal and a battery.
Regards,
Arne
Posted: Thu Sep 20, 2018 2:22 pm
by BillO
Another possibility for an RTC is a Maxim SmartWatch. Used to be called the Dallas No-Slot Clock. Readily available on eBay. I bought 2 of these for my Apple II computers a few years back. Still going strong. Writing a driver should not be that hard.
Posted: Thu Sep 20, 2018 3:17 pm
by Atlantis
Thank you for suggestions.
I have another hardware related question. It is rather basic, so I ask it here, instead of creating another topic.
How nominal frequency of ACA chip relates to system frequency. For example: I have R65C51P2 chips, so they are designed to work with maximal frequency of 2MHz. What does it really mean? Is it about main system clock or some other factor? Can I use one of those chips with WDC65C02 clocked at 4MHz? If not, what kind of UART chip should I look for?
