Page 1 of 1
AIM65 and the EPROM-burner described in INTERACTIVE07
Posted: Sun Jul 08, 2018 8:49 am
by oz6ym
I would like to make a EPROM-burner and found the diagram in INTERACTIVE07, but but..
The software for it is made in FORTH, and I do no FORTH, so I was thinking, if any one of you ever made this EPROM-burner, and have done the program for it?
If so, I will be very happy to receive a DUMP af this program, ready to burn into a EEPROM for my vingate AIM65 system.
In advance, Thanks for your help!
Vy 73 de OZ6YM, Palle
Re: AIM65 and the EPROM-burner described in INTERACTIVE07
Posted: Sun Jul 08, 2018 9:13 am
by GaBuZoMeu
Hi Palle,
could you either attach a link to the source you mentioned or the schematics?
Arne
Posted: Sun Jul 08, 2018 2:02 pm
See pages 10, 11, and 12 of issue 7:
http://6502.org/documents/publications/interactive/
Posted: Sun Jul 08, 2018 3:05 pm
by GaBuZoMeu
Thank you, BigEd!
Palle, I have built something very similar for my SYM. The biggest difference in the hardware is, I didn't use a relay. I first set up the select switch (2716 <=> 2732) then insert the EPROM, and then turn on the SYM. The programing voltage is applied "by hand". My program issues a message when it is required.
You may take a look a it, and then perhaps know what to do on your AIM.
Arne
EDIT(1): one file is slightly corrupted, don't know how to remove it :oops: the upper one should be fine
EDIT(2): wrong one deleted :)
Posted: Mon Jul 09, 2018 1:00 pm
by oz6ym
Hej Arne..
Thanks for the ASS-file.
Do you have any picture or diagram of your EPROM-programmer ?
Homepage maybee ??
de OZ6YM Palle
Posted: Mon Jul 09, 2018 4:19 pm
by BillO
Edit your post, then scroll down to the section titled "Posted attachments". Find the unwanted attachment and click on "Delete file".
Posted: Mon Jul 09, 2018 5:20 pm
by GaBuZoMeu
@BillO: THX :arrow: :idea:
@Palle:
I attached a quickly redrawn schematic. I have no picture - I couldn't find that board, perhaps it's gone, dunno.
At the top of the ASM file there is a sort of schematic. If there are discrepancies between the new one and the one within the ASM file, trust the old one!
Arne
Posted: Wed Jul 11, 2018 6:07 am
by oz6ym
Hello Arne!
Thank you very much for the drawing.
Here I can see that the difference to mine is quite small, only the relay change you do not have.
My final result can be seen here:
http://planker.dk/AIM65/eprom.htm
Thanks to you and BigEd for input.
de OZ6YM, Palle
Posted: Wed Jul 11, 2018 6:46 am
by GaBuZoMeu
Hej Palle,
it is looking fine. And a fine picture to show how easy wire wrap goes :)
Just never forget: some 2532 (and a few 2716 as well) don't like 25V !!
Happy burning :P
Arne
