My '816 update. Second time is a charm!
Posted: Mon Jun 11, 2018 2:50 am
Well, after failing to get my '816 doing a free run on a breadboard using discreet logic, you would think I would wise up and put the wire strippers down and the oscope in the closet and go outside to enjoy the good weather.
But no, I'm too dumb to know better, and too stubborn to admit defeat even when I am clearly over my head.
I decided to just hook the CPU up to the FPGA board and to start implementing all the glue logic required since I'm ultimately heading that way.
If you care to see it running just hit the link https://youtu.be/L1oqJR2sejY. I'm sure to most of you it will be pretty ho-hum, but hey, I'm excited! Some of us are easily amused.
Next up is adding some ROM/RAM and seeing if I can get it running something other than a NOP.
Thanks for all the info you guys have provided, it has been very helpful.
