Page 1 of 1
WinCUPL question(s)
Posted: Sun Apr 08, 2018 8:59 am
by Jokse
I'm doing a FIELD in WinCUPL for a 22V10, but as soon as I want to use the .d flip flop part for synchronizing with a master clock on pin one, using something like out.d = input:[0..2FF] doesn't work... Do I really have to spell out the full logic equation or is there some way to get around that?
Name Test;
PartNo 01;
Date 04-04-2018;
Revision 01;
Designer Flaf;
Company Flaf;
Assembly Flaf;
Location Flaf;
Device p22v10;
PIN 1 = clk;
PIN [2,3,4,5,6,7,8,9,10,11] = [in0..9];
PIN 22 = output;
FIELD input = [in9..0];
output.ar = 'b'0;
output.sp = 'b'0;
output.d = input:[0..2FF];
  17:output.d = input:[0..2FF];
[002ca] invalid number: 2FF
Total time: 0 secs
Re: WinCUPL question(s)
Posted: Sun Apr 08, 2018 12:23 pm
by Martin A
It would appear to work if you use 'h'2ff instead of just 2ff. Not sure why the explicit hex definition is needed though.
Posted: Sun Apr 08, 2018 2:29 pm
by Jokse
That certainly did the trick! Thanks!
Posted: Sun Apr 08, 2018 9:00 pm
The hex reference is required because decimal is the default in CUPL. Without the 'h' prefix, the compiler might try to evaulate the 2ff part as a variable.
Posted: Mon Apr 09, 2018 8:02 am
by Martin A
I always thought hex was the default, the following code from one of my projects compiles correctly without any explicit 'h' declarations.
Name     AtomGAL ;
PartNo   00 ;
Date     09/02/2018 ;
Revision 01 ;
Designer Engineer ;
Company  None ;
Assembly None ;
Location  ;
Device   p22v10 ;
PIN   1  = A12                      ; /*                                 */
PIN   2  = A13                      ; /*                                 */
PIN   3  = A14                      ; /*                                 */
PIN   4  = A15                      ; /*                                 */
PIN   5  = A11                      ; /*                                 */
PIN   6  = A10                      ; /*                                 */
PIN   7  = A9                       ; /*                                 */
PIN   8  = rw                       ; /*                                 */
PIN   9  = phi2                     ; /*                                 */
PIN  14   = wr                      ; /*                                 */
PIN  15   = rd                      ; /*                                 */
PIN  16   = ma2                     ; /*                                 */
PIN  17   = vram                    ; /*                                 */
PIN  18   = io6                     ; /*                                 */
PIN  19   = io4                     ; /*                                 */
PIN  20   = io2                     ; /*                                 */
PIN  21   = io0                     ; /*                                 */
PIN  22   = ramcs                   ; /*                                 */
PIN  23   = romcs                   ; /*                                 */
Field address = [A15..0];
!ramcs = address:[0000..7FFF] ;
!io0 =address:[B000..B3FF] ;
!io2 =address:[B400..B7FF] ;
!io4 =address:[B800..BBFF] ;
!io6 =address:[BC00..BFFF] ;
!romcs = address:[C000..FFFF] ;
!vram = address:[8000..97FF] ;
!ma2 = address:[A000..AFFF] ;
!rd =  rw & phi2  ;
!wr = !rw & phi2  ;
Posted: Mon Apr 09, 2018 8:29 am
by Tor
Maybe WinCUPL will understand [02FF] as hex, but not [2FF] (without the 'h')?
Posted: Mon Apr 09, 2018 10:39 am
Maybe a 10 bit number, not being an even number of nibbles, throws it.
Is it worth padding the zero to make the numbers the same length?
output.d = input:[000..2FF];
Posted: Sun Apr 29, 2018 12:07 am
by cbscpe
The default is hex. But it is overwritten when using a prefix, like in your case you say
output.ar = ´b´0
after that the default is binary.
