TNMOC Contest
Posted: Wed Feb 21, 2018 3:43 pm
The honour of the 6502 must be upheld. Read on.
Feel free to squeeze a few more cycles out.
; In the recent 'Grand Digital Computer Race' at The National Museum of Computers
; the two 6502 based machines, a BBC and Apple II only managed 70 and 38 values
; in 15 seconds -- I assume this is because it was coded in BASIC (Yuck!).
; We can do better. We must do better.
; This program works out values with up to 512 digits. On my laptop running in an
; emulator it generates 2542 results in in 0.382394 Secs with an overall CPU
; Frequency = 79.5137 Mhz. Scaled to the BBC's 2Mhz 6502 that would take 15.20
; Secs (approximately). A real BBC would be a bit slower as it has interrupts to
; handle and the I/O would take longer but even so a more respectable ~2000
; values in 15 Secs should be possible. The Apple II will be around 50% of that
; as its clocked at 1MHz.
; All the real code is 6502 but I've used the WDM opcode in the emulator to
; produce output text (see UartTx) so I compile it as 65816 to enable it.
; Andrew Jacobs
; 2018-02-21
.65816
; Macros
COMPUTE .macro NA,NB,NC,LA,LB,LC
ldx #0
clc
repeat
txa ; Reached end of shorter number?
eor LA
if ne
lda NA,x ; No.
endif
adc NB,x ; Add digits (or zero + digit)
sta NC,x
inx
txa ; Reached end of longer number?
eor LB
until eq
if cs ; Has result extended the value?
lda #1 ; Yes, add a 1 to the start
sta NC,x
inx
endif
stx LC ; Save the new number length
.endm
DISPLAY .macro NM,LN
repeat
lda NM-1,x ; Fetch two digits
pha
lsr a ; Extract MS digits
lsr a
lsr a
lsr a
if eq ; Leading zero?
cpx LN
beq Skip\? ; Yes, suppress it
endif
ora #'0'
jsr UartTx
Skip\?: pla ; Extract LS digit
and #$0f
ora #'0'
jsr UartTx ; And print
dex
until eq
lda #10 ; Send CR/LF to output
jsr UartTx`
.endm
; Workspace
.page0
.org $10
LEN_A .space 1
LEN_B .space 1
LEN_C .space 1
; Number workspaces (for 512 digits)
.bss
.org $1000
NUM_A .space 256
NUM_B .space 256
NUM_C .space 256
; The emulator expects the S28 to contain a ROM image so this is kicked off via
; the dummy reset vector.
.code
.org $f000
Fibonacci:
ldx #1 ; Initialise number lengths
stx LEN_A
stx LEN_B
stx LEN_C
lda #0
sta NUM_A ; Start with A = 0
stx NUM_B ; .. and B = 1
sed ; Work in decimal mode
ComputeLoop:
; C = A + B
COMPUTE NUM_A,NUM_B,NUM_C,LEN_A,LEN_B,LEN_C
cpx #0
if eq
jmp AllDone ; Result is over 512 digits
endif
DISPLAY NUM_C,LEN_C
; A = B + C
COMPUTE NUM_B,NUM_C,NUM_A,LEN_B,LEN_C,LEN_A
cpx #0
if eq
endif
DISPLAY NUM_A,LEN_A
; B = C + A
COMPUTE NUM_C,NUM_A,NUM_B,LEN_C,LEN_A,LEN_B
cpx #0
if eq
endif
DISPLAY NUM_B,LEN_B
jmp ComputeLoop
UartTx:
wdm #$01 ; Use emulator I/O
rts
AllDone:
wdm #$ff ; Stop the emulator
jmp AllDone
.org $fffc
.word Fibonacci ; Dummy RESET vector
.end
