Page 1 of 1
Where can I learn the 6502 hardware and instruction set?
Posted: Sat Dec 02, 2017 3:30 pm
by LBSC
I want to learn the 56 instructions and the hardware like, registers, ALU or whatever. Where can I learn that?
Re: Where can I learn the 6502 hardware and instruction set?
Posted: Sat Dec 02, 2017 7:19 pm
Due to its enormous proliferation, as well as its role in shaping computer history, the 6502 is arguably the most documented microprocessor ever designed. Everything you could possibly want to know about it is as close as the nearest Internet search engine.
Posted: Sat Dec 02, 2017 9:27 pm
The best tutorial and reference I know of is the programming manual "
Programming the 65816 including the 6502, 65C02, and 65802"" by David Eyes and Ron Lichty. It's not free anymore, but it's definitely worth the price. No 65xx enthusiast should be without it. The 65c02, BTW, has more instructions than the 56 number you gave (it's around 72), and more addressing modes too, and the 65816 has even more. If you're just getting into this, do not limit yourself to the original NMOS 6502's instruction set.
Posted: Sat Dec 02, 2017 9:39 pm
by JenniferDigital
Another thing that might well help you is that the Kowalski simulator shows you information about the instruction at your text cursor as you edit. This means you're getting given little clues as you go.
Oh, and although it is Windows software it does seem to work under Wine.
Posted: Sun Dec 03, 2017 11:38 am
I'll quote myself from another thread:
A lot of people - including me - got started on other books. Rodnay Zaks'
Programming the 6502 is a classic. It looks like Lance Leventhal also wrote one. I'm sure you can find a cheap secondhand copy, or a copy on line. The
Advanced User Guide for Acorn's BBC Micro
is also pretty good.
Note however that these older works are only about the original 6502 instruction set. That's quite enough to learn about how to use a 6502, but the 65C02 does offer some extra instructions which help a little with performance and code density, and the 65816 goes a lot further.
Posted: Sun Dec 03, 2017 2:10 pm
by LBSC
Thank you so much! This is the best tutorial ever =]
