Page 1 of 1
"65C02: Tear down, A look at the CMOS version of the 6502"
Posted: Mon Jul 03, 2017 10:35 am
Via Jac Goudsmit on G+, a short video and matching blog entry, from "electronupdate".
This particular version was plucked off of an embedded industrial controller... a place where this processor still finds design wins. The die has patent numbers which were very helpful in sorting down the details of this design.
Video:
Blog:
I think some of the commentary on the chip is not quite right. I would say the floorplan is very like the NMOS 6502 - the area below the decode array will be the so-called random logic, and the more organised area in the bottom half of the core will be the datapath - that's where you'll find the registers, the ALU, and the busses. Note that the decode array doesn't have fuses - it is mask-programmed - but the variable features are indeed the programming of the array.
Lots of white space in the chip, as noted - looks pad-limited, which is not great for price, as the core is such a small part of the silicon.
Re: "65C02: Tear down, A look at the CMOS version of the 650
Posted: Wed Jul 05, 2017 11:02 pm
by jac_goudsmit
I got the link from TheAmpHour. https://www.reddit.com/r/TheAmpHour/com ... _6502_cpu/
===Jac
Posted: Fri Jul 14, 2017 5:17 pm
by calculi
Very interesting ! Finally we've got better pictures than the tiny ones to be found on WDC's web pages. Maybe some day we'll enjoy even higher resolution since the video clearly shows some zooms on the PLA and the patent numbers. Their CPU seems to come from Sanyo, before WDC's switch to TSMC foundry, it is already a 2-metal process. Too bad that the commentary isn't accurate.
Posted: Fri Jul 14, 2017 5:37 pm
===Jac
Just got around to looking at this. Good find, Jac.
After the 65C02, the 65C22 ^^
Posted: Wed Aug 02, 2017 2:43 pm
by calculi
A new entry recently showed up on ElectronUpdate blog : our well-known VIA !
https://electronupdate.blogspot.fr/2017 ... -past.html
An unusual fact : the bonding pads are labeled with the pin number and the signal name. The third picture matches WDC's datasheets : 1 polysilicon and 2 metal levels. The floorplan seems to share common points with the CPU : the horizontal middle section looks like a datapath (8 horizontal slices) ; it probably hosts the various registers (control registers, timers, I/O)... and the BIG output transistors are easily noticeable on the peripheral ring.
I'd really like to know if they plan to publish super-high resolution pictures... ? imagine a "visual 65C02" :D
Posted: Thu Aug 31, 2017 5:39 pm
by calculi
Bump
For those who are interested, please have a look at an older entry on "Elecronupdate" blog :
https://electronupdate.blogspot.fr/2017 ... -down.html
and click the 1st image ; the upper left part of the chip clearly looks like a CPU, doesn't it ?
If you search the internet for "GHH393" you'll find a chip from SunPlus/GeneralPlus, with a very similar looking CPU core used in the Furby toy -and 65C02-based.
Our preferred processor has a tendency to hide everywhere, just as told by WDC (and Garth ;-) )
Posted: Thu Aug 31, 2017 5:44 pm
Good spot- that's certainly a 6502 of some sort!
