Page 1 of 1
Puzzled by part of one of WDC's official examples
Posted: Fri Mar 31, 2017 12:34 am
by Alarm Siren
Hi again all,
I've been getting my head round WDC's official assembler (no easy feat I can tell you!), but I've come across something in one of their official examples (8LED_CCAH.asm to be exact) which doesn't make sense to me:
;This code is here in case the system gets an NMI.  It clears the intterupt flag and returns.
badVec:		; $FFE0 - IRQRVD2(134)
	php
	pha
	lda #$FF
				;clear Irq
	pla
	plp
	rti
The label "badVec" is mapped into the NMI vector. I... I don't understand what this code is supposed to be doing. To my mind, you could simply do the RTI on its own. It seems to put register A and P on the stack, set A to FF, then overwrite A and P with their original values as pulled from the stack... this just seems like a NOOP, or am I missing something?
Re: Puzzled by part of one of WDC's official examples
Posted: Fri Mar 31, 2017 12:53 am
by barrym95838
In the context you provided, it seems to be a bit of cycle-wasting nonsense to me too.
Mike B.
Posted: Fri Mar 31, 2017 1:15 am
Wow, somebody sure messed up, huh?!
Posted: Fri Mar 31, 2017 2:30 am
by clockpulse
Why is the (;clear Irq) comment located on a blank line?
Maybe something like sta zploc should be there?
Posted: Fri Mar 31, 2017 3:10 am
Still, you don't need PHP and PLP, since they're an automatic, implied part of the interrupt sequence and RTI anyway. As least they didn't do SEI and CLI too!
Posted: Fri Mar 31, 2017 10:37 pm
by Rob Finch
The only thing I can think of here is if there is a register flag located at address $FFE2 where the LDA #$FF instruction is. Maybe the $FF is loaded into an I/O reg by a read cycle ? It does say that it's an NMI flag that is cleared so there must be some sort of FF.
Posted: Mon Apr 03, 2017 10:11 am
by Alarm Siren
In case context helps, here's the whole program:
; File: SIM_8LED_CCAH.asm
; 09/16/2016
     PW 128         ;Page Width (# of char/line)
     PL 60          ;Page Length for HP Laser
     INCLIST ON     ;Add Include files in Listing
				;Test for Valid Processor defined in -D option
	IF	USING_02
	ELSE
		EXIT         "Not Valid Processor: Use -DUSING_02, etc. ! ! ! ! ! ! ! ! ! ! ! !"
	ENDIF
; End of testing for proper Command line Options for Assembly of this program
			title  "6502 xSimul8r Program V 1.00 - 8 LED Active High"
			sttl
; bgnpkhdr
;  FILE_NAME: SIM_8LED_CCAH.asm
;  DATA_RIGHTS: Western Design Center
;               Copyright(C) 1980-2016
;               All rights reserved. Reproduction in any manner,
;               in whole or in part, is strictly prohibited without
;               the prior written approval of The Western Design Center, Inc (WDC).
;               Information contained in this publication regarding
;               device applications and the like is intended through
;               suggestion only and may be superseded by updates.
;               It is your responsibility to ensure that your application
;               meets with your specifications.  No representation or
;               warranty is given and no liability is assumed by
;               Western Design Center, Inc. with respect to the accuracy
;               or use of such information, or infringement of patents
;               or other intellectual property rights arising from such
;               use or otherwise.  Use of WDC's products
;               as critical components in life support systems is not
;               authorized except with express written approval by
;               WDC.  No licenses are conveyed,implicitly or otherwise,
;								under any intellectual property rights.
;  TITLE: 8LED_CCAH
;  DESCRIPTION: This File describes the WDC Simulator Example Program.
;  DEFINED FUNCTIONS:
;          badVec
;                   - Process a Bad Interrupt Vector - Hang!
;  SPECIAL_CONSIDERATIONS:
;  SHARED_DATA:
;          None
;  GLOBAL_MODULES:
;          None
;  LOCAL_MODULES:
;          See above in "DEFINED FUNCTIONS"
;  AUTHOR: David Gray
;  CREATION DATE: September 16, 2016
;  REVISION HISTORY
;     Name           Date         Description
;     David Gray	09/16/2016   1.00 Initial
; NOTE:
;    Change the lines for each version - current version is 1.00
;    See -
;         title  "6502 xSimul8r Program V 1.00 - 8 LED Active High"
;endpkhdr
;                             Include Files
;None
;                              Global Modules
;None
;                              External Modules
;None
;                              External Variables
;None
;                               Local Constants
;	VIA_BASE:	equ	$f0
	VIA_BASE:	equ	$7FC0		;; base address of VIA port on SXB
	VIA_ORB:	equ	VIA_BASE
	VIA_IRB:	equ	VIA_BASE
	VIA_ORA:	equ	VIA_BASE+1
	VIA_IRA:	equ	VIA_BASE+1
	VIA_DDRB:	equ	VIA_BASE+2
	VIA_DDRA:	equ	VIA_BASE+3
	VIA_T1CLO:	equ	VIA_BASE+4
	VIA_T1CHI:	equ	VIA_BASE+5
	VIA_T1LLO:	equ	VIA_BASE+6
	VIA_T1LHI:	equ	VIA_BASE+7
	VIA_T2CLO:	equ	VIA_BASE+8
	VIA_T2CHI:	equ	VIA_BASE+9
	VIA_SR:		equ	VIA_BASE+10
	VIA_ACR:	equ	VIA_BASE+11
	VIA_PCR:	equ	VIA_BASE+12
	VIA_IFR:	equ	VIA_BASE+13
	VIA_IER:	equ	VIA_BASE+14
	VIA_ORANH:	equ	VIA_BASE+15
	VIA_IRANH:	equ	VIA_BASE+15
		CHIP	65C02
		LONGI	OFF
		LONGA	OFF
	.sttl "6502 xSimul8r Demo Code"
	.page
;                    6502 xSimul8r Demo Code Section
;Example code to controll 8 LEDs driven from the W65C22 VIA Port B
		org	$2000		;Our program code will be at $2000
	START:
		sei
		cld
		ldx	#$ff		; Initialize the stack pointer
		txs
; First, we initialize the VIA chip registers and set Port B to OUTPUTS
		lda	#$ff
		sta	VIA_DDRB	; set all as outputs
; Now we initialize the X register to use to count from 0 - 255 (FF)
		ldx #$00
;This is our loop where we get a value from $3000 in memory and load it
;into VIA Port B Output Register.  If ran all at once, this will cycle through memory
;from $3000 - $30FF.  The content at each memory address will be output to Port B
;which will be visable on the 8 LEDs as a binary equivalent.
;This exercise is meant to be done in the xSimul8r using single stepping.  The user can
;load the memory at $3000 with any data they wish.
LOADER:
		lda $3000,x		; Load the value that is in memory at 3000 + x index.
		sta VIA_ORB		; Display value on LEDs.  Value can be seen in ORB register of VIA
		inx				; Increment the value of X by 1
		bne LOADER		; Branch to the label "LOADER" if the value of the X-register is not $00
;After 256 loops, the program is done and we give control back to the simulator.
	IRQHandler:
		pla
		rti
	php
	pha
	lda #$FF
				;clear Irq
	pla
	plp
	rti
This_project_end:
WDCMON_RAM_START	EQU	$7C00
ROMSPACE EQU WDCMON_RAM_START-This_project_end  ;gives space left in the ROM BEFORE WDCMON TABLES
	IF ROMSPACE<0
		EXIT         "Not Enough Memory for This Application - bumping into WDCMON! ! ! ! ! ! ! ! ! ! ! !"
	ENDIF
	bits:	db	1
	cnt:	db	0
	wraps:	dw	0
	delay:	db	10
; New for WDCMON V1.04
;  Needed to move Shadow Vectors into proper area
	SH_vectors:	section
Shadow_VECTORS	SECTION OFFSET $7EFA
					;65C02 Interrupt Vectors
					; Common 8 bit Vectors for all CPUs
		dw	badVec		; $FFFA -  NMIRQ (ALL)
		dw	START		; $FFFC -  RESET (ALL)
		dw	IRQHandler	; $FFFE -  IRQBRK (ALL)
	        ends
vectors	SECTION OFFSET $FFFA
	        ends
	        end
Posted: Mon Apr 03, 2017 3:46 pm
by Rob Finch
Having a schematic of the board would help too. Just to see if there's an NMI disable FF hooked up.
