I have been playing around with cutting old microprocessors on my laser cutter - started with the 4004 and with the help of the 6502 community have now produced a 5 layer version of the 6502 - see attached photo. I have posted a video that give a better view of how the layers are arranged:
https://www.facebook.com/The-Light-Work ... NE&fref=nf
The layers are about 180x200mm.
Please feel free to contact me on through the forum if you are interested in this or have any suggestions or comments.
AUD $80 + postage
Germany - 57 Euro + 15 Euro postage,
US - $62 + $12,
UK - GBP 50 + GBP 12.5
I will post the Autocad file I used to produce this later today so you can cut your own if you have access to a laser cutter - takes about 2 hours to cut so would probably be too expensive to get it cut by a commercial laser cutter who generally charge about $100 per hour.
Now if only I could figure out how to get the picture the right way up...
Thanks
Chris
Laser cut acrylic 6502 available
chrissmith
Re: Laser cut acrylic 6502 available
GREAT WORK !
I´m curious to see this with a decent colored illumination
What is the size of each "layer"?
chrissmith
Layer are approx. 180*200mm (although scaling to other sizes is relatively easy.
I will probably design some illumination - might be a bit down the track as working through all the cutouts for the lights takes a while.
I don´t want to push you to do colored illuminations - but I think your small video would be even more impressive.
Why the hell you are living in Sydney ?? It´s damned far away
What may it costs sending some holey pieces of plastic
half around the world?
chrissmith
DWG plans for cut are attached here - instructions are in the file.
This relies heavily on the work of the visual6502 team - thanks to those guys.
- Attachments
- allfixed3.zip
- (4.11 MiB) Downloaded 80 times
Would it be possible to post the video elsewhere? I don't have FB access.
chrissmith
I can try uploading it here tomorrow - not sure what the forum size limits are. BTW - should not need a Facebook account to view the video - it is on a public page.
Thanks
Chris
Thanks
Chris
- BigDumbDinosaur
chrissmith
Here is the video for those who do not like/cannot get to FB. I had to zip it as the forum does not allow .mp4 files.
Thanks
Chris
Thanks
Chris
- Attachments
- 6502.zip
- (9.32 MiB) Downloaded 75 times
Thanks for the link. Looks great!
