Wire Wrapping Power Distribution?
Posted: Mon Jul 04, 2016 3:29 pm
My search skills aren't bringing back anything useful. Can't hardly search WW without some jewelry page coming up. :-/
Anyway, I'm starting to WW a computer but I'm curious on how you guys handle power distribution. I can't seem to find any information on this.
For example, I know you wan to use heavier gauge wire for power and ground. I was thinking of using my normal breadboard wire for power since it's thicker than the WW wire.
But wouldn't that mean soldering those pins together? I thought about perhaps using the VCC and GND pins as a way to tack down the WW sockets and then soldering point-to-point.
What are your recommendations?
Also, a separate question...if the WW sockets are to be put side-to-side in order to reduce distance, how are you getting decoupling caps in there? Some of these IC's have the power literally in the middle of the chip (I'm looking at you Propeller).
Thanks
Thanks
