65816 BE pin (or...)
Posted: Mon Aug 31, 2015 4:15 pm
I have read the 65816 data sheet several times and searched here and the across the web, and I am still fuzzy on the usage of the BE pin on the 65816. The datasheet says (I think) it allows an input to enable/disable the "address and data buffers" . I'm not sure what this means. What happens to execution on the processor when BE is disabled? Do internal operations (not needing the bus) stop until it is enabled? the DS does not say, as far as I can tell.
Let me add some disclosure: I am trying (like others I see) to integrate a Propeller/65816 hybrid. My goal is to run the '816 asynchronously and let the Prop/'816 communicate only through RAM, save a few control signals (BE?). I need to be able to deconflict the bus. I was hoping BE would let me do that. I have a feeling it's not so simple. Is there a better way to do this?
I have the Prop talking to the 512k SRAM nicely but I can see it's relatively slow so I don't want to completely shut down the processor when the Prop is on the bus. After loading the ROM, the Prop will only be used for serial, SD, keyboard, and maybe mouse. I have other plans for video, but initial output will be serial terminal through the Prop.
I can use the Prop to generate an IRQ signal - I was thinking about an interrupt based scheme to accomplish the above.
I realize I am committing the newbie sin of too much complexity here. But I have built the plain jane 6502 projects and really want to make this system work.
Thanks,
George
Thanks,
George
