Page 1 of 1
Win32/64 6502 Disassmebler
Posted: Sat Apr 25, 2015 12:09 pm
by banedon
Hi guys
Does anyone know of a decent Win32/64 6502 disassembler? I.e. one that they've used and can recommend?
I've found a few already, but they're either web based or Win16 or Linux/Unit.
Any recommendations?
[edit]
I've found this one:
http://sourceforge.net/projects/dis6502/
Seems ok, but will have a play. Recommendations still welcome, though
Re: Win32/64 6502 Disassmebler
Posted: Sat Apr 25, 2015 2:07 pm
You might try Ruud's disassembler:
http://www.baltissen.org/htm/auto_dis.htm
I use the very basic facility in
Ian Piumarta's lib6502: can dump a disassembly of memory and then get to work in a text editor.
Posted: Sat Apr 25, 2015 2:20 pm
by banedon
Thanks for the recommendation, Ed. Unfortunately, it won't run under windows 7 x64 (it's a 16 bit DOS app). However, I do like the idea of his data auto detection routine that he mentions on the main page.
Posted: Sat Apr 25, 2015 2:27 pm
Oops!
Posted: Sat Apr 25, 2015 3:31 pm
by magicaros
for running 16bit dos app under Win7/8 64bit or whatever else there is DOSbox
Posted: Sat Apr 25, 2015 5:34 pm
by HansO
Turbo Pascal source is included, so perhaps Freepascal will compile it. Or run it in a VM or MS- DOS emulator
Posted: Sat Apr 25, 2015 6:32 pm
See if there's one in the list on my links page at
http://wilsonminesco.com/links.html#assem that suits you. One or two of the links there are to other pages with further long lists of 65xx assemblers.
Posted: Sun Apr 26, 2015 3:36 am
by White Flame
I've got one here that's quite powerful:
http://www.white-flame.com/wfdis/ It requires HTML5 & Javascript enabled, but will run anywhere that runs. You can even download & run a local copy; it's not technically "web based", as it runs completely in local javascript.
It's currently Commodore 64 specific, but if you have a binary, prepending the 2-byte load address to the file will make it work as a "prg" file.
Features:
- Tracing 6502 disassembler
- CBM BASIC detokenization, finding SYS addresses and disassembling from there
- Very slow emulator for running relocation or decompression code, allowing you to disassemble further from that
- Understands .prg and .sid formats, as well as .d64 images containing them
- Edit formatting (indentation, blank lines), and comments
- Create or rename labels
- Built-in C64 ROM & I/O labels
- View areas as some C64 graphics types
This is technically just the front-end to my AI-driven disassembler back end, but I am also keeping it fully runnable client-side with just the rudimentary tracing disassembler.
Big caveat: no saving/export yet. Saving & loading the disassembler state does work, but there's no UI hook for it yet. Still, you can explore the workings of a file, and copy/paste out if you're desparate.
Small caveats: No "illegal" opcodes yet. Manually switching things from gfx back to binary sometimes doesn't register quite right.
To get more features in, just bug me.
Re: Win32/64 6502 Disassembler
Posted: Thu Apr 30, 2015 8:18 am
A
timely post from Peter Fröhlich mentions a resurrection of "a flow-tracing 6502 disassembler first published in 1986 by Robert Bond" - it's a work in progress.
The
project page has a link to
Eric Smith's dis6502 page (including the original dis6502 sources)
Note that this is a command-line program and needs lex and yacc to build it - probably OK using cygwin or similar on Windows, but it's not a GUI program as was originally sought. Might be interesting anyway.
Posted: Wed Mar 23, 2016 10:12 am
There's a mention of the impressive-looking open source
'radare' reverse engineering tool, and at least one simple command line disassembler, over in
this thread.
Posted: Wed Mar 23, 2016 10:53 pm
by White Flame
Note that radare actually is an interactive disassembler, as the main part of its tool. I had to search to try to find how to do a simple commandline disassembly dump of a file, for that particular thread.
Posted: Thu Mar 24, 2016 8:44 am
I'm glad you did search - for someone who prefers command line, it's essential to know that a GUI-looking tool also supports the command line.
