Page 1 of 2
Converting byte to hex string
Posted: Fri Jan 23, 2015 5:47 pm
by banedon
Hi guys
I couldn't readily find some 6502 code to convert a byte to hex string (basically, to show the contents of particular memory locations on an LCD screen, etc.) so have written my own. It does work. What does everyone think?
' Parameters:
' A - value to convert from byte to hex string
' Outputs:
' X - LSB character
' Y - MSB character
.byteTOhexstr
PHA
' grab the MSB and move to LSB
LSR A
LSR A
LSR A
LSR A
' if A is greater than &A then go to A-F
CMP #&A
BCS numstrMSB_AtoF
.numstrMSB_0to9
ADC #48
TAX
JMP numstrLSB
.numstrMSB_AtoF
CLC
ADC #55
TAX
' LSB
.numstrLSB
PLA
' grab the LSB by masking out the MSB
AND #&0F
CMP #&A
BCS numstrLSB_AtoF
.numstrLSB_0to9
ADC #48
TAX
JMP numstrLSB
.numstrLSB_AtoF
CLC
ADC #55
TAY
RTS
Re: Converting byte to hex string
Posted: Fri Jan 23, 2015 6:32 pm
by rwiker
You'll find code for printing a hex byte at http://www.sbprojects.com/projects/apple1/wozmon.txt; search for "PRBYTE" on that page. That's code written by Woz, so should be worth looking at.
Posted: Fri Jan 23, 2015 7:32 pm
banedon wrote:
Hi guys
Have you looked at this code? It can convert a binary value to any of four radices, hex being one of them. The largest binary value that it can convert is $FFFFFFFF or (2^32)-1.
To convert a single byte to printable hexadecimal characters, you could use the following code:
;binhex: CONVERT BINARY BYTE TO HEX ASCII CHARS
;	Preparatory Ops: .A: byte to convert
;	Returned Values: .A: MSN ASCII char
;	                 .X: LSN ASCII char
;	                 .Y: entry value
binhex   pha                   ;save byte
         and #%00001111        ;extract LSN
         tax                   ;save it
         pla                   ;recover byte
         lsr                   ;extract...
         lsr                   ;MSN
         lsr
         lsr
         pha                   ;save MSN
         txa                   ;LSN
         jsr .0000010          ;generate ASCII LSN
         tax                   ;save
         pla                   ;get MSN & fall thru
;	convert nybble to hex ASCII equivalent...
.0000010 cmp #$0a
         bcc .0000020          ;in decimal range
         adc #$66              ;hex compensate
.0000020 eor #%00110000        ;finalize nybble
         rts                   ;done
Labels such as .0000010 and .0000020 are local labels.
Posted: Fri Jan 23, 2015 9:28 pm
by White Flame
It's a few bytes longer, but a few cycles faster (especially if you avoid the JSR), to look the nybble up in a table of "0123456789ABCDEF". I tend to go that route, since that's often an integral part of IO where I need to maximize speed.
Posted: Sat Jan 24, 2015 1:09 am
by teamtempest
Ugh. Longer than it needs to be and somewhat obscure.
;                    .Y: entry value
         jsr .0000010
         tax                   ;save ASCII
         pla                   ;recover byte
         lsr                   ;extract...
         lsr                   ;MSN
         lsr
         lsr
; 0 to 9 -> $30 to $39
; 10 to 15 -> $41 to $46
.0000010 cmp #10		         ; 0 to 9 ?
         bcc .0000020          ; b: yes - must set bits 4 and 5
         adc #103-1            ; 10 to 15 -> 113 to 118
; $71 to $76
; %01110001 to %01110110
; - must clear bits 4 and 5
.0000020 eor #%00110000        ;set or clear bits 4 and 5
         rts                   ;done
; or perhaps the One True Way as Preached by Leventhal:
         bcc .0000020          ; b: yes ($00 to $09)
         adc #'A'-'0'-10-1     ; 10 to 15 -> $11 to $16
.0000020 adc #$30              ; $30 to $39 or $41 to $46
         rts                   ;done
Posted: Sun Jan 25, 2015 9:09 am
by Omegamatrix
How about this?
;  A = entry value
  sed        ;2  @2
  tax        ;2  @4
  and #$0F   ;2  @6
  cmp #9+1   ;2  @8
  adc #$30   ;2  @10
  tay        ;2  @12
  txa        ;2  @14
  lsr        ;2  @16
  lsr        ;2  @18
  lsr        ;2  @20
  lsr        ;2  @22
  cmp #9+1   ;2  @24
  adc #$30   ;2  @26
  cld        ;2  @28
;  A = MSN ASCII char
;  Y = LSN ASCII char
I ran a short test program and it works. It's very quick at 28 cycles, and just takes 19 bytes. The basic code comes from Lee Davison code shorts.
Posted: Sun Jan 25, 2015 9:37 am
by MichaelM
There aren't any branches associated with the CMP instructiions. To convert to ASCII hex, a test for 0...9 should be followed by an ORA #$30 (or ADC #$30). But if the nibble is greater than 9, the adjustment for A...F needs to be applied instead.
Posted: Sun Jan 25, 2015 9:42 am
by barrym95838
He's using the cmp instructions for their carry side-effects, Michael. Combined with the BCD +6 adjustment, the carry flag provides just the right +7 to jump from '9' to 'A' in ASCII.
Mike B.
Posted: Sun Jan 25, 2015 9:53 am
by MichaelM
Missed the significance of the SED at the beginning. Very cool and sneaky.
Posted: Sun Jan 25, 2015 11:14 am
by Klaus2m5
Though there is one problem: It works with invalid BCD digits and might not work on emulators.
I looked at the source code of Lee's EhBASIC. He used that trick in HEX$(). I had to patch it to use binary mode ADC only.
Posted: Sun Jan 25, 2015 10:25 pm
Omegamatrix wrote:
How about this?
;  A = entry value
  sed        ;2  @2
  tax        ;2  @4
  and #$0F   ;2  @6
  cmp #9+1   ;2  @8
  adc #$30   ;2  @10
  tay        ;2  @12
  txa        ;2  @14
  lsr        ;2  @16
  lsr        ;2  @18
  lsr        ;2  @20
  lsr        ;2  @22
  cmp #9+1   ;2  @24
  adc #$30   ;2  @26
  cld        ;2  @28
I seem to recall trying that one on POC and not having it work right. It may be an issue with 65C816 native mode operation.
Posted: Mon Dec 25, 2017 6:08 pm
by jgjg
Hi, I want to change this code to be able to write on a screen 2 bytes number. It shows only first byte now, I should make a jump to PRHEX before making 4 LSR for sure, but despite trying it doesn't work, so I think there is something I forgot. Can you tell me what is wrong in my thinking?
Posted: Tue Dec 26, 2017 8:54 am
by Klaus2m5
; put this just before PRBYTE
                BMI     PRBYTE
;  Subroutine to print a word in X (low byte) and A (high byte)
PRWORD          JSR     PRBYTE          ;print high byte
                TXA                     ;continue to print low byte
; continue with PRBYTE
Posted: Wed Dec 27, 2017 9:17 am
by jgjg
Thank you for your answer. I edited my code as you'd wrote, but it didn't work, it printed high byte all the time. I tried putting
lda <text
ldx >text
in different positions, because I wonder if it should be executed 2 times, but I haven't had good result yet.
                opt f-g-h+l+o+
                org $1000
start           equ *
                lda <text
                sta $80
                lda >text
                sta $81
                ldy #0
                lda #$ba    ; input
                jsr print
                lda <text
                ldx >text
                jsr $ff80
                brk
                bmi phex
print           jsr phex
                txa
phex            pha
                lsr @
                lsr @
                lsr @
                lsr @
                jsr prhex
                pla
prhex           and #%00001111
                ora #'0'
                cmp #'9'+1
                bcc pr
                adc #6
pr              sta ($80),y
                dey
                rts
byte            dta b(0)
                org $2000
text            equ *
                dta b(0),b(0)
                dta b(10) ; '\n'
                dta b(0)
                org $2E0
                dta a(start)
                end of file
Posted: Wed Dec 27, 2017 10:19 am
by Klaus2m5
Prior to "jsr print" I do not see any ldx and A is always loaded with $ba! The "bmi phex" is only necessary in the original context. I suppose $ff80 points to your print string utility.
The original problem seems to be here:
pr              sta ($80),y
                dey
                rts
You initialize Y with 0 and then attempt to write the characters of a hex word backwards to ($80)+0, ($80)+$ff, ($80)+$fe, ($80)+$fd.
Please note that you should ask this kind of questions in a separate thread in the newbies section with a link to where you found the original code. And remember to post your modifications from the beginning as what you say might not be what you actually have programmed.
