Page 1 of 1
Status register and 0x30
Posted: Sun Dec 07, 2014 12:13 am
by BobLoblaw0101
This is perhaps a stupid question but:
Consider that the status register is defined as:
7 6 5 4 3 2 1 0
S V - B D I Z C
If I do the following code:
LDA #$00
PHA ; Push 00 to the stack
PLP ; Pop 00 into the status register
I now see the status register being 0x30. This means that bit 5 (reserved) is set and bit 4 (break) is set. I've seen this behavior on two different emulators. Based on the code above, shouldn't the status register be 0x00? I can't seem to find any CPU documentation discussing this 0x30 value.
I thought bit 4 can only be set with a BRK instruction. Why does it get set in this case? Also, why is the reserved bit (bit 5) set?
Thanks in advance.
Re: Status register and 0x30
Posted: Sun Dec 07, 2014 12:28 am
The B flag does not physically exist in the processor. It is only a position in the status byte that gets pushed when there's an interrupt; so to test it, you have to do PLA PHA AND#$10 from the ISR when status is at the top of the stack. PHP PLA AND#$10 won't work. There's an article on 6502 interrupts on this site at http://6502.org/tutorials/interrupts.html . Enjoy my outdated cartoons! :D
To prevent confusion, make sure you call the high bit of the status register "N" (for "negative") as is standard, not "S" which is the stack pointer.
Posted: Sun Dec 07, 2014 12:43 am
by BobLoblaw0101
So does that mean that there is no way to set the status register to 0x00? In other words, an emulator should always return the B bit and the reserved bit to ON?
Posted: Sun Dec 07, 2014 12:46 am
by Klaus2m5
The emulators just follow the behavior of a real 6502 or any of its hardware successors. The unused bit returns a 1 when read, because it is not present in hardware and reading an open circuit simply returns a logic high state. The same is true for the break bit, as it is not an existing flag bit register but a forced low to an otherwise open circuit. The bit is forced low only when the processor flag bits are pushed onto the stack during either an IRQ or a NMI. So the break bit would be better defined to signal "pushed by software" (BRK or PHP only).
Garth was a little bit faster but I post my answer anyway.
Posted: Sun Dec 07, 2014 12:50 am
by BobLoblaw0101
Okay that makes sense. Thanks guys!
