Page 1 of 2
Strange 6502 trainer
Posted: Wed Jul 30, 2014 7:36 pm
by mba
Does anyone know what it could be? It uses two Rockwell chips: 6502 and 6522. On the board are labels: "MPS 65-2", "THALER" and "85-1-1". The board was probably made in mid-eighties.
Re: Strange 6502 trainer
Posted: Wed Jul 30, 2014 9:09 pm
by barrym95838
Here's an awkward translation from this page:
http://allegro.pl/mps65-6502-microproce ... 26352.html
Tile MPS65 to learn programming of the microprocessor 6502. Did not find anything about it on the web.
On the board is written MPS 65-2. At the bottom of the inscription Thaler THALER (the same inscription is in ROM, in addition to the date 84). Systems dating back to the years 1983-1987.
Tile is efficient. It has a 6-digit LED display, a keyboard 24, a push, a microprocessor 6502 (execution Rockwell) VIA 6522 to support the display, keyboard and timers, 2KB ROM monitor program, 2KB RAM 6116 of which the user is available 1.5kB (unless, that do not use the monitor program).
For tiles do not have documentation but no problem I figured how to use it: you can write a new program instructions, view the program forward / reverse, jump into memory at any given address, inserting NOP instructions in the indication of the place of the code (it can be later converted into BRK what will stop program and displaying the contents of registers X, Y and A by monitor - such a simple debugger. program has also monitor watch. buttons S and L are presumably Save and Load. Save probably works because you can see on the serial communication port PB7 the VIA (so that the pin is nowhere connected). Interested remain zdeassemblować program monitor.
I enclose a handwritten fragment pattern of connecting a keyboard and display (and a brief description of how the program the user can take advantage of them, a simple matter). A brief but adequate descriptions of monitor functions.
A piece of history for the collector.
Tile requires a stabilized power supply 5V 0.5A - wire is complete.
Mike
Posted: Wed Jul 30, 2014 9:28 pm
by mba
I've just bought it here. I'm looking for more detailed information about the board.
Posted: Thu Jul 31, 2014 7:37 am
by HansO
Never seen this one. It looks like one of the many KIM-1 type of machines. I see a 6502, a 6522, an EPROM type 2716, SRAM 6116.And a big DIN connector at the back. The usual keyboard/led display scanning hardware like the KIM-1, the Elektor Junior, MCS Alpha 1 etc have.
What i do not see is any kind of I/O like cassette.
The advertisement talsk about PB7 as serial port, which may mean another pin of the 6522 is also part of a serial port. No connector visible though.
Can you dump the EPROM?
Posted: Thu Jul 31, 2014 5:51 pm
by mba
EPROM dump is in the attachment. It starts in address space at 0xF800.
Posted: Wed May 20, 2015 12:20 pm
by Michael
I wonder if anyone has found any additional information on this particular SBC? I haven't found anything, so far.
Posted: Sat Dec 29, 2018 11:51 am
Thanks for the ROM dump, mba. I see a very similar board is now being discussed over here:
https://stardot.org.uk/forums/viewtopic ... 55&t=16253
Posted: Sun Dec 30, 2018 1:22 pm
by GaBuZoMeu
My brain isn't that bad ..
I remember some advertisement in the german monthly "mc Die Mikrocomputer-Zeitschrift" (Franzis-Verlag).
This board is a reduced version of the CT-65 from Thaler (Thaler & Co. Mikroprozessor Technik GmbH, Krefeld, Germany) called "MPS-65".
Sorry guys (and gals) - german only. If required I can translate it.
Regards
Arne
Posted: Sun Dec 30, 2018 1:29 pm
Nice findings - thanks for sharing!
Posted: Sun Dec 30, 2018 3:25 pm
by bprosman
Thanks , indeed a nice finding. Translation is not required even though my German might be rusty.
I read that the connector was according to the "Siemens SMP norm", anything known about that ?
Posted: Sun Dec 30, 2018 3:29 pm
by GaBuZoMeu
Welcome, bprosman!
Posted: Sun Dec 30, 2018 3:47 pm
by bprosman
Posted: Sun Dec 30, 2018 4:13 pm
by GaBuZoMeu
Sorry, no suitable findings for that "Siemens SMP norm".
It is most likely just one out of a million possible pin assignments for these DIN 41612 (now IEC 60603-2) connectors that were used frequently those days (especially in industrial solutions, Eurocard size boards).
Regards,
Arne
Posted: Mon Dec 31, 2018 1:18 am
by tanteju
If my memory is not completely wrong, the SMP Bus was a predecessor of the SMP 16 Bus, without b row. See
https://cache.industry.siemens.com/dl/f ... u066_e.pdf section 5.1.3
There are other signals on a and c, which are not used and if I remember correctly, there had been an article in c't (a German magazine from that time) about that bus.
Posted: Mon Dec 31, 2018 3:50 pm
by HansO
A summary page on the findings on the Thaler MPS-65 and CT-6502 SBC's here:
http://retro.hansotten.nl/6502-sbc/msp-65-2-thaler/
