I've finished my cpu emulator, and made some tests on it and I can say it's fairly complete and ready to be used on a host system development.
Which system would you say is simpler and easier to emulate? (e.g. Atari VCS, Atari 8-bit, Apple II, C64, NES, BBC Micro, etc. )
For my own
Propeddle project (real 6502, real RAM, everything else emulated), the Apple 1 was by far the easiest machine to emulate (and the only system emulated so far
). You only need to monitor 3 addresses in 6502 memory space: one where the 6502 writes a character to the video "terminal", one where it checks if there is a new character from the keyboard, and one where it actually gets the last character that came from the keyboard. Once you can emulate that hardware and you can map the
Krusader ROM image into memory, you have a running system with an Assembler/Disassembler and BASIC. If you don't want to do video or a keyboard, you can emulate it through a serial port and all software will still work because it simply doesn't expect to have anything else than character-in character-out: the original system didn't have any manipulation of the screen or cursor; all you could do was push a button to clear the screen, and that button wasn't wired into the 6502 circuitry: it was part of the tv-terminal circuitry. The Apple 1 uses no interrupts.
The Ohio Scientific (OSI) Superboard II a.k.a. Challenger a.k.a. UK101 should also be very easy to emulate: The video is memory-mapped text-only with a 256-character font that's ASCII based, but is a bit weird: the screen is 32x32 characters but the ROMs pretend that it's only 25x25. The keyboard uses only one location in memory (basically if I remember correctly the 6502 writes a value to a location that enables a row, and then it reads the location back to see which column is connected to that row because a key switch is down). Even without the keyboard emulation, you'll see a startup message "D/W/C/M". The only other peripheral that's on-board is a 6850 UART which should be easy to emulate. And in fact with some small changes to the ROM it's possible to run the system with just the UART and no video or keyboard emulation; Grant Searle has done this
here. The OSI also uses no interrupts.
The Commodore PET (or 4032, 8032, and other early monochrome Commodores) should also be fairly easy but you will need a memory-mapped text screen that generates PETSCII characters, not regular ASCII. You will need a matrix keyboard connected through a 6520 (or was it 6521) to make it work, but without keyboard or VIA/PIA it should still show the COMMODORE BASIC / READY" message when you start up. Besides the keyboard PIA/VIA, there are two more interface chips that are used for the IEEE-488 interface and for the cassette ports; they're not needed to bring the system up. The PET uses interrupts for timekeeping: a 60Hz (or 50Hz) clock is generated from the mains input.
If you don't want to bother with video, you can go for a Kim-1 emulator (or a similar system like the Elektor Junior or the SYM or AIM-65). The KIM-1 uses two 6530 RRIOT chips (ROM RAM I/O Timer) which are impossible to get, but you can use (or emulate) a 6532 RIOT (RAM I/O Timer) instead. Vince Briel did this for his
MicroKim, based on
research done by Ruud Baltissen. A single RIOT is enough, most programs only use one of them: the one that's connected to the on-board keyboard and the six 7-segment displays. If you don't even want to bother with the display or keyboard, you can just use the serial port which is bitbanged by the software in the ROM and has a reasonably well-working automatic baudrate detector. The KIM-1 doesn't need interrupts.
I'm not very familiar with the Apple II family of computers, there are many of them. I believe they have many video modes including graphics and color, so true emulation may be a bit more work than the ones mentioned above. I think it comes up in text mode though, so as long as you don't run graphics programs, you can get started pretty easily.
Systems like the Commodore 64, Atari VCS (2600), NES etc. all have pretty complicated custom audio/video chips; they would take a significant amount of work to emulate if all you have now is a 6502. However some people have already done this; for example Jeri Ellsworth's DTV was an FPGA-based Commodore 64 emulator (but it's closed-source, unfortunately). The nice thing is that these systems are available for cheap on eBay so you could just get one, plug your emulator into the 6502 slot (except in the NES -- the 6502 is physically part of the main chip there) and get started. Then one by one you write emulator code for the other chips until your system is all by itself.
Hope this helps!
===Jac
