Page 1 of 1
CA65 examples?
Posted: Wed Feb 27, 2013 5:32 pm
by Michael
Anyone come across a tutorial or examples for using the CA65 cross-assembler (on a Windows 7 laptop)? Do you use a text editor for your source and then feed it to the CA65 executable?
TIA... Regards, Mike
Re: CA65 examples?
Posted: Wed Feb 27, 2013 6:13 pm
Yes, I'd use any convenient text editor.
Here's how I use the assembler and linker:
ca65 -l boot816.as -D BASE=0x8000
cl65 boot816.o --target none --start-addr 0x8000 -o boot816.bin
(From viewtopic.php?p=9534#p9534)
Re: CA65 examples?
Posted: Wed Feb 27, 2013 7:03 pm
by Michael
Thank you, Ed...
Re: CA65 examples?
Posted: Thu Feb 28, 2013 12:49 am
by White Flame
Here's portions of the Makefile boilerplate I've grown over the years. It reports on the used size of segments and generates all the debug output. I use a proper src, obj, and bin subdirectory set as I often have other resources that have to go through the pipe.
# Final output filename
BINFILE = editor.prg
CFGFILE = src/editor.cfg
obj/%.o: src/%.asm
	ca65 $< -g -o $@ -I src
clean:
	- mkdir -p obj
	- mkdir -p bin
	- rm -f obj/*
	- rm -f bin/*
all: clean obj/editor.o
	ld65 -Ln L -C $(CFGFILE) -m obj/map -o bin/$(BINFILE) $^
	@sed '1,/^$/ d' obj/map | sed -n '/Exports list/q;p'
I name the labels file simply "L", so from Vice's monitor I can type ll"L" quickly to load the labels, as there's no scriptable cmdline option for preloading label files.
Oftentimes I export labels with a double-underscore in them and add a grep + sort for them from the labels file after final compilation, to give some finer grained boundary reporting when memory is tight.
YMMV on the exact sed format, as I'm using a modified version of an older ca65/ld65, and I don't know what newer versions output. Same for cmdline switches, but I'd expect those to be pretty stable.
Re: CA65 examples?
Posted: Thu Feb 28, 2013 6:21 am
by Michael
Gosh, I only understand about a quarter of that (way over my head).
After using only Integrated Development Environments (IDE) these last ten years I can't even remember how I used to create Apple ][ and 68HC11 programs. But, I don't seem to remember it being quite as involved as your description.
Thanks, Gentlemen... It looks like I may have a lot of work ahead of me (lol)...
Re: CA65 examples?
Posted: Thu Feb 28, 2013 6:59 am
by White Flame
If you want to use that blindly, there's just 3 things to configure.
Set BINFILE and CFGFILE at the top, then in the line
list all the object files you want compiled together. For instance, if you have foo.asm and bar.asm in your src directory, the line would be
all: clean obj/foo.o obj/bar.o
and it will compile and link those files together.
The basics of Makefiles are pretty simple. As far as all the crazy punctuation goes, I'm not an expert in that. I read the docs as needed to make them work in the general case, and it works across all the projects I have.
When I have small things that can fit in a single .asm file, I sometimes do grab a single-command assembler like xa. But it is good to have a proper ca65 project skeleton that you can do bigger, more flexible development in.
If you're just banging around with small stuff and aren't familiar with Makefiles and segment-based configuration, yeah you might want to go for something simpler than ca65. It takes a fair amount to set up, but it's the only thing I'd want to use for large projects. I simply run smaller projects through the same, since it's good future-proofing for scaling something up later.
