Assistance with single-board computer
Posted: Fri Feb 15, 2013 4:26 pm
I'm still working on this thing, it's not working any more. Instead of showing the pattern, the LEDs stay lit and won't turn off.
I checked the ROM, the right data's loaded. That was the problem I had before, but it's not that this time. I checked every power and chip enable pin, they're all connected correctly. I checked all the data and address lines, they're connected properly...
I did find a problem with the clock timer, the 74LS04. it wasn't producing a wave. I don't have the proper equipment to check, I test it by connecting a LED between the chip and the power, then turning it around to see if its producing both positive and negative. First time I tried, it was only producing a positive output. I replaced the chip with a spare and it seemed to work normally, as far as I could tell. it was producing positive and negative output. The computer wasn't working properly though.
That's about all I can think of at the moment. It's got me stumped, it was working last time I checked and now it's not. Can anyone provide any suggestions? Can you see something obvious that i've missed? Anything?
