K1 Controller Board for Parallel Video Board 'Backplane'
Posted: Wed Oct 17, 2012 6:42 pm
It's time I started this thread, as now a PVB seems to be close to a reasonable success. There are six presently, but maybe 8 PVB boards populating a DEVboard Backplane.
I plan on making a controller board, but I intend this thread to be open ended. My plan for a K1 Controller Board is to hopefully have a modified 65Org16.b core. A version of Arlet's 8-bit 6502 Core in a Spartan 6. I'm sure there may be others who would support a 1GHz 32-bit ARM. Maybe some others would support 8 or 16-bit databus wide CPU or microcontroller. This is a beautiful thing IMO, and this is why I have provided pinouts of all connectors and have gone into so much detail exposing my design. I will update the K1 Controller Board pin assignment table soon (EDIT - 10/23/12 Final update has been made). The bidirectional databus common for each PVB is 8 bits wide and supports a 6500/6800 type R/W signal with a Phase 2, R/W and Chip Enable signals present.
Also, this mainboard should have an IC that interfaces a camera RGB input and can output the signals to the first PVB through the K9 connector. Still looking for this IC...
EDIT: 8/5/13 Changed Title
