Design of Parallel Video Board 'Backplane'
Posted: Tue Aug 14, 2012 5:50 pm
This thread goes hand in hand with the Concept and Design of Parallel 16-bit Video Boards, 16-bits being the RGB video output. There we discuss how we plan to manufacture 1 of these boards. This thread discusses how a multiple of these boards will be connected again using the ExpressPCB service. Although instead of a 3.8"x2.5" 4-layer Miniboard Pro board, this Mainboard will be constructed using their Standard 2-layer service, using a board size of 3.8"x5.5".
6 Parallel Video Boards and a still yet to be designed Controller board will be able to fit on the main connectors K1-K7. Thankfully, the Standard service does not appear to have a hole limitation as this design uses 800+ holes.
After wrestling abit for the layout of this Mainboard, I came to the conclusion this layout must absolutely dictate the assignment of pins for the main connector of the Parallel Video Board. Meaning, at certain points, 2 board layouts (PVB & Mainboard) had to be developed simultaneously.
A nice thing I had noticed is that a total of 48-signals can be joined directly using straight traces! This was very good news as early on, as I had not routed a single signal on the bottom layer or have had to use via's...
Also I must mention Garth Wilson, who has contributed significantly to the final layout of this design, spotting some critical errors and making suggestions about improvements for successful high-speed (100+MHz) signal transmission. A great many thanks Garth!
Here is the layout showing 6 PVB headers K2 thru K7. K1 is the controller board. K8 is an expansion header primarily meant for a future HDMI board. K9 is the expansion header meant for a sound board at this point. It uses a 16-bit databus, utilizing the lower 8 bit databus common to all the PVBs. K9's layout is done, but actual pin assignments are still a work in progress. All headers are mounted on top, except for K8 & K9.
Pin assignments for the K1 Controller Board connector:
Pin assignments for K2-K7 Parallel Video Boards:
Pin assignments for the HDMI header:
Pin assignments for the Expansion header (in-flux):
Parts list:
EDIT: 10/11/12 - Updated and pre-finalized.
EDIT: 10/12/12 - Added K7, K8 pin assignments and parts list.
EDIT: 10/17/12 - Expanded design to include 6 PVB's using same board size.
EDIT: 10/18/12 - This thread is currently a W.I.P.
EDIT: 10/19/12 - Last thread EDIT was a mistake, however updated K1 connector pin assignments
EDIT: 10/23/12 - 2 x Updated parts list
EDIT: 10/23/12 - Updated K8,K9 pics
EDIT: 10/30/12 - Pre-Finalized design
EDIT: 8/05/13 - Changed Title
Parts list:
QTY Price Description Part# Package Supplier ID
7 $4.85 96-pin male receptacle A32857-ND vertical thru-hole Digi-Key K1,K2,K3,K4,K5,K6,K7
1 $3.78 40-pin male header MHB40K-ND vertical thru-hole Digi-Key K9
1 $5.63 60-pin male header MHB60K-ND vertical thru-hole Digi-Key K8
14 $0.43 M2.5x1" fem/fem spacer AE10862-ND thru hole Digi-Key
14 TBD M2.5x15mm Screw TBAEDIT: 10/12/12 - Added K7, K8 pin assignments and parts list.
