65ORG16.c Core
Posted: Fri Apr 06, 2012 2:21 am
In the end, I would like this .c core to have a 16-bit databus / 32-bit address bus just like the .b core. It will have 16 registers to start with, maybe more if max speed timing permits.
--Consider this post a placeholder-- as there is alot of things to consider and experiment with.
All registers/accumulators will have the ability to have full functionality of the Y Register as in the original NMOS6502. This is the most powerful and longest reaching due to indirect indexed Y mode. This mode will apply to all 16 Accumulators/Registers. And vice-versa, math/logic like ADC, SBC, EOR, etc. that was formerly done only on the accumulators, will be able to be performed on these registers/accumulators. So forget the difference between index registers and accumulators in this machine. Out with the old, in with the new, as they used to say. They are now one in the same. From now on I call them all Registers on this machine.
I alluded to this idea towards the end of the .b core thread. Arlet helped out here...
Also, there will be 16x16 multiplication opcodes.
