Page 1 of 4
Beginners CPLD
Posted: Thu Dec 01, 2011 4:48 am
by Dajgoro
Well, i decided to try out this fantastic invention at last...
(The thought that i could put all that messy logic in one ic for my sbc projects instead of soldering lots of logic ic convinced me that this is the way to go...)
I had never before used or touched a CPLD, but i am familiar with VHDL, from my digital logic class...
I've found XC9536 cpld on ebay, and is kinda cheap, and the sockets are too. But it turns out i can't use any regular cheap usb jtag for it. But i do have a genuine parallel port on my pc, and i could build one of toes parallel jtags, but i just need a schematic. Now if you could comment the XC9536, and as an alternative, but a bit more expensive i found the Altera EPM7064.
Posted: Thu Dec 01, 2011 7:19 am
I've voted for Xilinx, but only because it worked for us, and it's the only one I know. That might be normal: most people will only be familiar with the single supplier they first picked.
I'd be interested to hear more detail from any other voter, especially from anyone voting 'other' - the stability and usability of the tools are very important, and Xilinx is good there.
I thought the sockets for PLCC devices were expensive, but indeed just over £1 for a
through-hole PLCC44 socket.
This page has a good walk through of a first CPLD project using xilinx, all on stripboard/project board, including making up a parallel cable adapter. (The Xilinx tools work the same on Windows and Linux - this page happens to talk about Ubuntu.)
Once you have the adapter and the tools, the move from CPLD to FPGA, if you ever want to make it, is seamless. At least it is for Xilinx.
Posted: Thu Dec 01, 2011 1:39 pm
by 8BIT
I too like the xilinx chips. I found this on ebay
http://www.ebay.com/itm/120803095352
its $15 from Hong Kong. I bought a similar one way back when. You can also search for "xilinx jtag" and find many others as well.
The schematic for a parallel port programmer can be found in this document:
http://www.xilinx.com/support/documenta ... xtp029.pdf
Hope this helps!
Posted: Thu Dec 01, 2011 2:20 pm
by Windfall
Voting Xilinx or Altera is only fair when you have experience with both, and I don't think many people do. The picture painted by what I read on-line, e.g. in several forums, is that Altera development software is considerably more solid than that of Xilinx.
Beginners CPLD
Posted: Thu Dec 01, 2011 3:33 pm
I'm partial to Atmel. I'm planning on using the 1508 series in POC V2 when I get to it. WinCUPL works well as a development tool, although it does have some bugs.
Posted: Thu Dec 01, 2011 7:17 pm
That's a reasonable position, but too late for me, sorry!
Interesting! I had the impression it was the other way around, but that's from 3 or 4 years ago (maybe more.) Certainly I've had no problem, on both Windows and Linux.
The quality of support forums would be another consideration.
BDD, do you have one or two bullet point reasons for preferring Atmel, or is it a gut feel thing?
Posted: Thu Dec 01, 2011 8:05 pm
by BitWise
I bought some ATMEL ATF1504 CPLDs for glue logic a while back but haven't got around to using them yet. The simpler ATF16V8 and ATF20V10 have been enough so far.
Posted: Thu Dec 01, 2011 8:14 pm
by Dajgoro
Thanks for the links, i think i will go for the XC9536 for now, and i am going to try to build my own lpt jtag... But which program do i use for editing/programming the XC9536?
Posted: Thu Dec 01, 2011 8:42 pm
For all the xilinx parts, you use
ISE - the free version is called 'webpack'. It's a huge download. You will need a (free) machine-specific license from them, and for that you need to register using an email address from a company (or an institution) - gmail won't be accepted. I've never had any spam from them though.
Posted: Thu Dec 01, 2011 10:21 pm
by Dajgoro
I managed to register with my student email, i hope it will work...
Posted: Fri Dec 02, 2011 1:17 am
by ElEctric_EyE
... The picture painted by what I read on-line, e.g. in several forums, is that Altera development software is considerably more solid than that of Xilinx.
I've had problems in the past with Xilinx ISE10.1 when working with the Spartan 2 but much less so with ISE13.2 using the Spartan 3 and 6 families. Although I do use 'legacy' schematic entry for top_level, also for 32bit address decoding, so this may be to blame, but no problems in my current Spartan 6 FPGA design.
Still, I am of the mind that supporting 1 company without investigating another does not serve the competitive edge which brings us all, 'end users', better products.
Also, I and some others here are very disappointed in Atmel, regarding their GAL22V10. I won't bring it up again here, but there's a common observed problem of programming their proprietary GAL IC.
Beginners CPLD
Posted: Fri Dec 02, 2011 6:34 am
Partially a gut feeling and partially due to familiarity with WinCUPL and being able to simulate fairly complicated logic in it without incurring too steep a learning curve.
I've struggled trying to make some sense of Xilinx's ISE and have found its workflow doesn't mesh well with my thought processes. As the time I have available to me to play with this stuff is limited, I can't see investing much of it into something with which I can't be comfortable. I set aside ISE nearly a year ago and probably won't look at it again.
Posted: Fri Dec 02, 2011 7:02 am
Every now and again I'm reminded that I use the world's worst hash function. I have confused Atmel and Altera! It looks like Atmel make only CPLDs, but Altera make a range from CPLD to FPGA (as do Xilinx, and indeed Lattice.)
Posted: Sat Dec 03, 2011 2:41 am
That's the trouble with two names that share the same vowels and some consonants.
Atmel also makes GALs, which are handy for small logic projects, but good luck finding a programmer that will work with them. I snagged some Lattice GALs off eBay a while ago and although I have no immediate need for them, I figured I might as well keep a few around in case a need does arise.
Posted: Sat Dec 03, 2011 2:58 am
by Dajgoro
Well, i bought four XC9536, and sockets. I also managed to install ISE, now i just need to figure out how to transfer the program to the cpld using the lpt port...
