comb sort
Posted: Thu Apr 21, 2011 5:07 am
I've been doodling.
Here's a first whack at a comb sort.
Edit: clarified (I hope) the comments some
; comb sort list of (up to) 256 8 bit elements.
; list must be page aligned
; top = location containing the location in the
; list page of the last list element
; = number of list elements - 1 (list is
; zero based, page aligned)
; ie if there's 3 elements in the list
; top contains 2
; upper = lo byte of the zp pointer of upper list
; element to compare. upper contains gap
; list = address of first element of list. Must be
; page aligned
; Upper is set to the gap and Y is set to top - gap
; so initially, (upper) + Y = top and
; list + Y = top - gap
; Then the inner loop decrements Y to zero, comparing,
; and swapping as needed. The V flag is set at the begining
; of the inner loop and each time a swap is performed
; the V flag is cleared
; The outer loop decreases the gap by a factor of 1.33
; untill the gap is one and then exits when an inner loop
; does no swaps.
; In order to avoid an explicit cpy in the inner loop,
; we exit the inner loop when Y = 0 which still leaves
; a compare for Y = 0 to do.
; So seperate code is provided for that.
; Two special cases must be provided for.
; If there's only one element we just skip it all
; If there's only two elements we jump directly to the
; Y = 0 code and provide a special exit from the sort
; routine for the case of two elements. Fortunately the
; special case handling can be mostly out side the main
; loop(s) and doesn't add much in the way of cycles used
;intialize zp
lda #>list
sta upper+1
SORT
; first, corner case kludges
lda top
beq RETURN ; don't try and sort one element
sta upper
cmp #$01 ; if there's only two elements
bne NEXT_GAP ; the first compare is the last
ldy #$00 ; but Y still needs initializing
beq LAST_COMPARE
; shrink factor 1.33
; multiply gap by reciprocal = .75
NEXT_GAP
lsr ; .5 x gap
adc upper ; + gap = 1.5 x gap
ror ; (1.5 x gap)/2 = .75 gap
sta upper ; no clc and gap will never = 0
; so minimum result = 1
NEXT_GAP_1
eor #$FF ; negate gap
sec
adc top ; add to top to get
tay ; top - gap = index
lda #$7F
adc #$7F ; clear the swapped flag ie set overflow
bvs LOOP
SWAP
ldx list,y ; get the lower element into X, out of the way
sta list,y ; copy the the upper element in A to the lower
txa ; position and the lower element in X
sta (upper),y ; into the upper position
clv ; set the swapped flag
dey ; screw it we'll just waste a couple bytes
beq LAST_COMPARE ; to decrement and test the index here and save
; branching time. I love spaghetti
LOOP
; compare
lda (upper),y ; get the upper element to compare into A
cmp list,y ; compare to the lower element
bcc SWAP ; if the lower element is > then go swap 'em
dey ; damn, decrement and test again already!?
bne LOOP
LAST_COMPARE
; seperate compare and swap for Y = 0
lda (upper),y ; we tested/fell through on index = 0 for speed
cmp list,y ; so we still need to do compare for index = 0
bcs SKIP
; swap
ldx list,y ; and swap if that seems necessary
sta list,y
txa
sta (upper),y
clv ; set the swapped flag ie clv
SKIP
lda upper ; get the current gap
cmp #$01 ; and see if it's = 1
bne NEXT_GAP ; if not go calculate the next gap
cmp top ; corner case kludge
bcs RETURN ; if top <= 1 no more sorting can be needed
bvc NEXT_GAP_1 ; done swapping? if not, no need to calculate
; gap since gap = 1
RETURN
rts
