emulator performance on embedded cpu
Posted: Sun Aug 08, 2010 1:38 pm
WDC's 65c02 and 65816 are rated up to 14MHz. An FPGA T65 seems to promise about 40-50MHz. ASIC implementations are faster, but we don't have access to those.
I was wondering whether any cheap and available CPUs in dev kits or salvageable from consumer electronics would, when emulating a 6502, be a reasonable solution for a faster 6502.
I'm not sure, but I think the 6502 emulator originally written by Acorn for the Archimedes had a performance about 1/4 the clock speed of the ARM. (It would be written in assembly.) (Edit: I don't believe that performance any more.)
I ran a quick test of lib6502 on an 800MHz ARM-based storage device, and it looks like it runs a bit over 100MHz, so that's 1/8 the host clock. That's written in C. (Edit: with a less trivial benchmark, emulated speed is only 60MHz)
It seemed like the mbed LPC1768 dev kit, which has a 96MHz ARM, might be a good platform for an efficient 6502 emulation, for £50 (USB powered, 40-pin 0.1 inch form factor, weird online-only toolchain) - but based on the above, it would be a struggle to emulate at more than 12MHz. (It might be that 24MHz performance would be enough to make this interesting)
Any ideas or thoughts?
