Page 1 of 2
AIM-65 Display
Posted: Sun Aug 10, 2008 6:11 pm
by 8BIT
I have an AIM-65 I'm trying to restore. One of the 4 character displays is not working. I've switched it around and am sure it's the display module that's bad. It's a DL1416A, according to the schematics. Does anyone know where I can buy a replacement?
Also, a good source for the thermal paper would be appreciated... in several places, the documents note that special non-abrasive paper is required... normal thermal paper is too abrasive and will wear out the print head. I have one roll of the original paper - it prints in blue vs. black!!
thanks!
Posted: Sat Aug 16, 2008 1:01 am
by devzone
I have not seen the aim-65 displays but if they are LED 7 Segment then you could use any comman anode or cathode (choose correct type to match original) displays but you will probably have to rewire the connections for the common and a-g segments to match the originals
Posted: Sat Aug 16, 2008 1:43 am
They're at least 16-segment IIRC.
Posted: Sat Aug 16, 2008 3:52 am
by devzone
Oh I see, are they led or is it possibly a multi digit floresent digit display ? (will be a lot harder to find a replacement)
Posted: Sat Aug 16, 2008 3:52 pm
by 8BIT
They are LED. I found a datasheet and one online parts house that has 6 in stock, but they won't sell to the public, only a business that can send a P.O. Unfortunately, I cannot use my place of work to buy them.
Posted: Sun Aug 17, 2008 12:28 pm
by devzone
could you post a link to the datasheet or the display part number so I can take a look as I may be able to find a substitute that is available retail
Posted: Sun Aug 17, 2008 12:44 pm
by devzone
I found these 8 digit led starburst bubble displays but they are probably the wrong type as I have never seen the aim-65
http://cgi.ebay.co.uk/Alphanumeric-LED- ... dZViewItem
try doing a google search for led displays using the keyword
starburst you may get lucky
if you are unable to find a supplier then you could replace the whole display line using the displays above as at only £2.67 for 8 digits it would be inexpensive but a bit of work
good luck
Posted: Sun Aug 17, 2008 3:57 pm
by 8BIT
I have already started looking at a full replacement. I am considering a 20 char LCD module or a 20 character LED dot matrix display. Both will require some custom interfacing.
Thanks for your input!!
Posted: Sun Aug 17, 2008 9:06 pm
by leeeeee
I have a DL1414 but it is physically very different to the DL1416.
Lee.
Posted: Mon Aug 18, 2008 4:53 am
by RichCini
Daryl --
Have you seen this page?
http://www.izabella.freeuk.com/html/dl1 ... plays.html
Posted: Mon Aug 18, 2008 1:06 pm
by 8BIT
thanks Rich, I'll check it out!
Posted: Mon Aug 18, 2008 4:07 pm
by devzone
AIM 65 Display
Posted: Wed Dec 10, 2008 1:34 am
by gmcge
I have a bunch of those displays. We use to built the Aim into a product we produced. I wish I still had an Aim. All I have now is some Toshiba cmos static rams we substituted to drop the power consumption down. May have the old Fourth compiler too.
Let me know if you still need a display
Re: AIM-65 Display
Posted: Sat Jan 14, 2012 6:06 am
by orgwood
late post but did you get your dl1416? dave
thanks!
Posted: Sat Jan 14, 2012 6:32 am
by 8BIT
Yes, found one on ebay if I recall correctly.
thanks
