Page 7 of 15
Re: Neolithic Tiny Basic
Posted: Thu Feb 27, 2025 4:12 pm
This is a personal view, but I'd be wary of a syntax design which involves scanning ahead. (ELSE is not so bad in BBC Basic as it only scans to the end of the line.) But the idea of finding a "matching" element seems to me a problematic one: you might need a rule that such an element has to be in the first statement on a line, or not guarded by an IF, for example.
I very often write code where a FOR might have two or three NEXTs, or similarly for UNTILs. Perhaps I'm just a very naughty boy. Or perhaps such code should be illegal in a particular dialect which does try to match loop start with loop end.
Posted: Thu Feb 27, 2025 4:17 pm
by barrym95838
I'm familiar with only the Micro$oft, Woz and TRS-80 Level I variations of BASIC, and for me a FOR/NEXT loop that may execute zero times is unexpected, due to the extra effort in scanning forward (through treacherous but legal spaghetti) ... that's more of a C thing, isn't it?
[Edit: I see that Ed and I think along similar "naughty" lines. I believe that DEC even offered an UNLESS keyword, which adds another (unnecessary IMO) kink ...]
Posted: Thu Feb 27, 2025 4:40 pm
by barnacle
And I've just discovered that my for/next isn't behaving as I expected it to. I think a problem with the comparison... need to think about that.
But first, input...
Posted: Thu Feb 27, 2025 6:36 pm
by drogon
Scanning forward in an interpreter is/can be tricky. I do it in my 'big' Basic but it's limited to one statement per line which helps this and some other things too.
C treats a FOR loop like a WHILE construct... So:
for (i = 0 ; i < 10 ; ++i) { do somestuff}
is effectively like:
i = 0 ;
while (i < 10) {
do somestuff ;
++i ;
So it can be executed zero times - but then the compiler has to forward scan that anyway, so knows that the {} isn't closed and can whinge about it. Forward scanning in an interpreter is as tricky in that I have to count all inside loops and hope that someone like Ed didn't use a naughty GOTO to jump out of the loop
BCPL also has UNLESS which just negates the test.
Posted: Thu Feb 27, 2025 7:45 pm
by barnacle
<shudders> Ye gods and little fishies, I'd forgotten that such shenanigans were even legal, let alone expected... that sort of code's going to break my basic, I think. So, er, in my basic it's not legal, OK?
p.s. yup, it breaks it; it mostly works, but this code with two nexts from a single for:
executes both the inner and outer loops the expected number of times, but it's clearly not matching the nexts correctly; line 80 is executed only once and its next is being treated as an end (reasonable: an endif, next, or return all do the same thing: nothing; they're considered markers rather than executable keywords).
Posted: Thu Feb 27, 2025 8:31 pm
(FWIW I believe there's a Basic on the Spectrum Next which likewise tries to match loop beginnings and ends. And I think I checked that ANSI Basic also does. So, it's certainly a design choice.)
Posted: Thu Feb 27, 2025 9:12 pm
by drogon
It's not 'legal' in my TinyBasic to omit the loop variable - and it is checked. Could I remove the need for it and check? Yes, but I think I like it. One thing I can't do is:
which you can do in some Basics..
Posted: Thu Feb 27, 2025 9:15 pm
by barnacle
My feeling is that whatever is being attempted with multiple nexts from the same for can probably be achieved with more structured, er, structure.
I'm having some difficulty even contemplating how you might track nexts if the language not only permits that you can have more than one next per for but also that any given next might apply to more than one for... truly 'goto considered harmful'
I suppose it comes down to whether one wishes to write a structured program, or treat basic like spaghetti machine code?
Strictly, of course, the only construct you really need is if and goto... not even endif.
Posted: Thu Feb 27, 2025 9:23 pm
A particular thing which I find quite difficult to write efficiently as a properly structured program is a prime tester using trial division - because there are two conditions for leaving a loop, broadly speaking.
Posted: Thu Feb 27, 2025 9:37 pm
by drogon
A-Ha! I was about to say "oh no you don't" ... Then I checked. The 'core' of my B Prime checker:
800REM Is it Prime?
810REM Input N, output P - true or false (1 or 0)
811REM
820IF N < 1 P = 0 : RETURN : REM 0 and 1 are not Prime
830IF N < 4 P = 1 : RETURN : REM 2 and 3 are Prime
834IF N%2 = 0 P = 0 : RETURN : REM Trivial case for even numbers
840S = N : GOSUB 1000 : U = Q : REM Test up to the sqrt of S
845T = 3
850DO
860 IF N % T = 0 THEN P = 0 : DPOP: RETURN
870 T = T + 2
880UNTIL T > Q
890P = 1
899RETURN
See that DPOP there? Well - proves you right
Posted: Thu Feb 27, 2025 10:16 pm
by barnacle
Well, at the moment I seem to have completed the last module: input of either an integer or a string. So it's _nominally_ finished, though I need to look again at that for/next issue; perhaps something wrong in the compare routine. I also need to rationalise variable names and jump target names.
Then I'll stick it up and let you all have a laugh...
But I'm under 4k (just - $fcb = 4043 bytes
Posted: Thu Feb 27, 2025 10:18 pm
well done! Under 4k is impressive!
Posted: Fri Feb 28, 2025 6:51 am
by barnacle
The parent C version - x64 linux - is 29.7k, so it's improved somewhat.
Posted: Fri Feb 28, 2025 7:34 am
Wow!
Posted: Sat Mar 01, 2025 8:58 am
by barnacle
Well as a first cut, here it is. A couple of issues that I know about:
- There are some combinations of values for which for/next never stops. Still investigating; I may rewrite the whole chunk.
- Code to list single lines or group of lines still to be done
- As far as I know, execution stops on an error, with a message, but does not yet list the line number
- There is no 'oops' (e.g. ctrl-C) or warm restart
; assemble with as65, http://www.kingswood-consulting.co.uk/assemblers/
; use: as65 tiny.asm -h0 -ltiny.lst -s2 -x -m
; (or remove -s2 for binary output)
; THIS BUILD FOR SYMON EMULATOR - check ACIA register locations
It builds to just under 4k, starting $e000.
Enjoy, please let me know if you find (or fix!) any bugs. It's explicit in the code, but, FreeBSD licence to avoid future worries.
