CS-101 problems and their FORTH solutions.
JimBoyd
Re: CS-101 problems and their FORTH solutions.
Post by JimBoyd »
Thank you.
I don't think floating point numbers would actually work in this instance. With some of the larger numbers, the floating point errors could accumulate and throw the result off.
An integer quotient is the exact quotient and an integer remainder is the exact remainder.
Martin_H
Post by Martin_H »
Years ago, I did an inverse kinematics Forth project for a robot arm. I used 16-bit integer arithmetic with binary radians and fixed-point trigonometry as 32-bit single precision floating point is massive overkill on a microcontroller, even if the C compiler supports it. The result was perfectly adequate accuracy which exceeded the resolution of the servo encoders. Unfortunately, I lost the source code when that laptop died years ago (I wasn't using Git Hub then). So, I decided to revisit 16-bit integer arithmetic with binary radians and fixed-point trigonometry in my CS-101 Forth thread. I may potentially reuse it in a future project, but I will need to add atan2 for inverse kinematics.
The heart of the project is deciding upon the bits of precision and generating the first quadrant of sine samples. I did that using Python, but other languages would suffice. Here's the source: https://github.com/Martin-H1/Python/blo ... radians.py
This allowed me to select different values for the precision, with the tradeoff being a larger sine table size as angular precision increases. I opted for 12 bits of angular precision as that matches my servo encoders. For the sine samples I used 1 sign bit, 1 integer bit, and 14 fractional bits. The source in Git Hub: https://github.com/Martin-H1/Forth-CS-1 ... r/itrig.fs
Sine, cosine, and tangent are table lookups where angles outside the first quadrant are mapped onto the first quadrant with sign adjustments. Arcsine and arccosine are a binary search of sine table. This yields good results, except for a small error at 0 and 90 degrees as this Forth session demonstrates:
RIGHT_ANGLE  ok 1
.s <1> 1024  ok 1
sine  ok 1
.s <1> 16384  ok 1
arcsine  ok 1
.s <1> 1023  ok 1
0  ok 2
sine  ok 2
.s <2> 1023 0  ok 2
arcsine  ok 2
.s <2> 1023 1  ok 2
That's because I halve the correction factor for each iteration until I get an exact match, or the correction factor reaches zero. Here's the code for people who don't want to follow the Git Hub link.
hex
000c constant BRAD_N
000b constant DEGREE_ANGLE
0200 constant ACUTE_ANGLE
0400 constant RIGHT_ANGLE
0800 constant STRAIGHT_ANGLE
0c00 constant REFLEX_ANGLE
1000 constant FULL_ROTATION
000e constant BITSHIFT_FACTOR
4000 constant SCALING_FACTOR
create sineTable
  0000 , 0019 , 0032 , 004b , 0064 , 007d , 0096 , 00af , 00c9 , 00e2 ,
  00fb , 0114 , 012d , 0146 , 015f , 0178 , 0192 , 01ab , 01c4 , 01dd ,
  01f6 , 020f , 0228 , 0241 , 025b , 0274 , 028d , 02a6 , 02bf , 02d8 ,
  02f1 , 030a , 0323 , 033d , 0356 , 036f , 0388 , 03a1 , 03ba , 03d3 ,
  03ec , 0405 , 041e , 0437 , 0451 , 046a , 0483 , 049c , 04b5 , 04ce ,
  04e7 , 0500 , 0519 , 0532 , 054b , 0564 , 057d , 0596 , 05af , 05c8 ,
  05e1 , 05fa , 0613 , 062c , 0645 , 065e , 0677 , 0690 , 06a9 , 06c2 ,
  06db , 06f4 , 070d , 0726 , 073f , 0758 , 0771 , 078a , 07a3 , 07bc ,
  07d5 , 07ee , 0807 , 0820 , 0839 , 0852 , 086b , 0884 , 089c , 08b5 ,
  08ce , 08e7 , 0900 , 0919 , 0932 , 094b , 0964 , 097c , 0995 , 09ae ,
  09c7 , 09e0 , 09f9 , 0a11 , 0a2a , 0a43 , 0a5c , 0a75 , 0a8d , 0aa6 ,
  0abf , 0ad8 , 0af1 , 0b09 , 0b22 , 0b3b , 0b54 , 0b6c , 0b85 , 0b9e ,
  0bb6 , 0bcf , 0be8 , 0c01 , 0c19 , 0c32 , 0c4b , 0c63 , 0c7c , 0c95 ,
  0cad , 0cc6 , 0cde , 0cf7 , 0d10 , 0d28 , 0d41 , 0d59 , 0d72 , 0d8b ,
  0da3 , 0dbc , 0dd4 , 0ded , 0e05 , 0e1e , 0e36 , 0e4f , 0e67 , 0e80 ,
  0e98 , 0eb1 , 0ec9 , 0ee2 , 0efa , 0f12 , 0f2b , 0f43 , 0f5c , 0f74 ,
  0f8c , 0fa5 , 0fbd , 0fd6 , 0fee , 1006 , 101f , 1037 , 104f , 1068 ,
  1080 , 1098 , 10b0 , 10c9 , 10e1 , 10f9 , 1111 , 112a , 1142 , 115a ,
  1172 , 118a , 11a2 , 11bb , 11d3 , 11eb , 1203 , 121b , 1233 , 124b ,
  1263 , 127b , 1294 , 12ac , 12c4 , 12dc , 12f4 , 130c , 1324 , 133c ,
  1354 , 136c , 1383 , 139b , 13b3 , 13cb , 13e3 , 13fb , 1413 , 142b ,
  1443 , 145a , 1472 , 148a , 14a2 , 14ba , 14d1 , 14e9 , 1501 , 1519 ,
  1530 , 1548 , 1560 , 1577 , 158f , 15a7 , 15be , 15d6 , 15ee , 1605 ,
  161d , 1634 , 164c , 1664 , 167b , 1693 , 16aa , 16c2 , 16d9 , 16f1 ,
  1708 , 171f , 1737 , 174e , 1766 , 177d , 1794 , 17ac , 17c3 , 17da ,
  17f2 , 1809 , 1820 , 1838 , 184f , 1866 , 187d , 1895 , 18ac , 18c3 ,
  18da , 18f1 , 1908 , 1920 , 1937 , 194e , 1965 , 197c , 1993 , 19aa ,
  19c1 , 19d8 , 19ef , 1a06 , 1a1d , 1a34 , 1a4b , 1a62 , 1a79 , 1a8f ,
  1aa6 , 1abd , 1ad4 , 1aeb , 1b02 , 1b18 , 1b2f , 1b46 , 1b5d , 1b73 ,
  1b8a , 1ba1 , 1bb7 , 1bce , 1be5 , 1bfb , 1c12 , 1c28 , 1c3f , 1c55 ,
  1c6c , 1c83 , 1c99 , 1caf , 1cc6 , 1cdc , 1cf3 , 1d09 , 1d20 , 1d36 ,
  1d4c , 1d63 , 1d79 , 1d8f , 1da6 , 1dbc , 1dd2 , 1de8 , 1dfe , 1e15 ,
  1e2b , 1e41 , 1e57 , 1e6d , 1e83 , 1e99 , 1eb0 , 1ec6 , 1edc , 1ef2 ,
  1f08 , 1f1e , 1f34 , 1f49 , 1f5f , 1f75 , 1f8b , 1fa1 , 1fb7 , 1fcd ,
  1fe2 , 1ff8 , 200e , 2024 , 2039 , 204f , 2065 , 207b , 2090 , 20a6 ,
  20bb , 20d1 , 20e7 , 20fc , 2112 , 2127 , 213d , 2152 , 2168 , 217d ,
  2192 , 21a8 , 21bd , 21d2 , 21e8 , 21fd , 2212 , 2228 , 223d , 2252 ,
  2267 , 227d , 2292 , 22a7 , 22bc , 22d1 , 22e6 , 22fb , 2310 , 2325 ,
  233a , 234f , 2364 , 2379 , 238e , 23a3 , 23b8 , 23cd , 23e1 , 23f6 ,
  240b , 2420 , 2434 , 2449 , 245e , 2473 , 2487 , 249c , 24b0 , 24c5 ,
  24da , 24ee , 2503 , 2517 , 252c , 2540 , 2554 , 2569 , 257d , 2592 ,
  25a6 , 25ba , 25cf , 25e3 , 25f7 , 260b , 261f , 2634 , 2648 , 265c ,
  2670 , 2684 , 2698 , 26ac , 26c0 , 26d4 , 26e8 , 26fc , 2710 , 2724 ,
  2738 , 274c , 275f , 2773 , 2787 , 279b , 27af , 27c2 , 27d6 , 27ea ,
  27fd , 2811 , 2824 , 2838 , 284b , 285f , 2872 , 2886 , 2899 , 28ad ,
  28c0 , 28d4 , 28e7 , 28fa , 290e , 2921 , 2934 , 2947 , 295a , 296e ,
  2981 , 2994 , 29a7 , 29ba , 29cd , 29e0 , 29f3 , 2a06 , 2a19 , 2a2c ,
  2a3f , 2a52 , 2a65 , 2a77 , 2a8a , 2a9d , 2ab0 , 2ac2 , 2ad5 , 2ae8 ,
  2afa , 2b0d , 2b20 , 2b32 , 2b45 , 2b57 , 2b6a , 2b7c , 2b8e , 2ba1 ,
  2bb3 , 2bc6 , 2bd8 , 2bea , 2bfc , 2c0f , 2c21 , 2c33 , 2c45 , 2c57 ,
  2c6a , 2c7c , 2c8e , 2ca0 , 2cb2 , 2cc4 , 2cd6 , 2ce8 , 2cf9 , 2d0b ,
  2d1d , 2d2f , 2d41 , 2d52 , 2d64 , 2d76 , 2d88 , 2d99 , 2dab , 2dbc ,
  2dce , 2de0 , 2df1 , 2e03 , 2e14 , 2e25 , 2e37 , 2e48 , 2e5a , 2e6b ,
  2e7c , 2e8d , 2e9f , 2eb0 , 2ec1 , 2ed2 , 2ee3 , 2ef4 , 2f05 , 2f16 ,
  2f28 , 2f38 , 2f49 , 2f5a , 2f6b , 2f7c , 2f8d , 2f9e , 2faf , 2fbf ,
  2fd0 , 2fe1 , 2ff1 , 3002 , 3013 , 3023 , 3034 , 3044 , 3055 , 3065 ,
  3076 , 3086 , 3096 , 30a7 , 30b7 , 30c7 , 30d8 , 30e8 , 30f8 , 3108 ,
  3118 , 3128 , 3138 , 3149 , 3159 , 3169 , 3179 , 3188 , 3198 , 31a8 ,
  31b8 , 31c8 , 31d8 , 31e7 , 31f7 , 3207 , 3216 , 3226 , 3236 , 3245 ,
  3255 , 3264 , 3274 , 3283 , 3293 , 32a2 , 32b1 , 32c1 , 32d0 , 32df ,
  32ee , 32fe , 330d , 331c , 332b , 333a , 3349 , 3358 , 3367 , 3376 ,
  3385 , 3394 , 33a3 , 33b2 , 33c1 , 33cf , 33de , 33ed , 33fb , 340a ,
  3419 , 3427 , 3436 , 3444 , 3453 , 3461 , 3470 , 347e , 348c , 349b ,
  34a9 , 34b7 , 34c6 , 34d4 , 34e2 , 34f0 , 34fe , 350c , 351a , 3528 ,
  3536 , 3544 , 3552 , 3560 , 356e , 357c , 3589 , 3597 , 35a5 , 35b3 ,
  35c0 , 35ce , 35dc , 35e9 , 35f7 , 3604 , 3612 , 361f , 362c , 363a ,
  3647 , 3654 , 3662 , 366f , 367c , 3689 , 3696 , 36a4 , 36b1 , 36be ,
  36cb , 36d8 , 36e5 , 36f1 , 36fe , 370b , 3718 , 3725 , 3731 , 373e ,
  374b , 3757 , 3764 , 3771 , 377d , 378a , 3796 , 37a3 , 37af , 37bb ,
  37c8 , 37d4 , 37e0 , 37ed , 37f9 , 3805 , 3811 , 381d , 3829 , 3835 ,
  3841 , 384d , 3859 , 3865 , 3871 , 387d , 3889 , 3894 , 38a0 , 38ac ,
  38b7 , 38c3 , 38cf , 38da , 38e6 , 38f1 , 38fd , 3908 , 3913 , 391f ,
  392a , 3935 , 3941 , 394c , 3957 , 3962 , 396d , 3978 , 3983 , 398e ,
  3999 , 39a4 , 39af , 39ba , 39c5 , 39d0 , 39da , 39e5 , 39f0 , 39fb ,
  3a05 , 3a10 , 3a1a , 3a25 , 3a2f , 3a3a , 3a44 , 3a4f , 3a59 , 3a63 ,
  3a6d , 3a78 , 3a82 , 3a8c , 3a96 , 3aa0 , 3aaa , 3ab4 , 3abe , 3ac8 ,
  3ad2 , 3adc , 3ae6 , 3af0 , 3afa , 3b03 , 3b0d , 3b17 , 3b20 , 3b2a ,
  3b34 , 3b3d , 3b47 , 3b50 , 3b59 , 3b63 , 3b6c , 3b75 , 3b7f , 3b88 ,
  3b91 , 3b9a , 3ba3 , 3bad , 3bb6 , 3bbf , 3bc8 , 3bd1 , 3bda , 3be2 ,
  3beb , 3bf4 , 3bfd , 3c06 , 3c0e , 3c17 , 3c20 , 3c28 , 3c31 , 3c39 ,
  3c42 , 3c4a , 3c53 , 3c5b , 3c63 , 3c6c , 3c74 , 3c7c , 3c84 , 3c8c ,
  3c95 , 3c9d , 3ca5 , 3cad , 3cb5 , 3cbd , 3cc5 , 3ccc , 3cd4 , 3cdc ,
  3ce4 , 3cec , 3cf3 , 3cfb , 3d02 , 3d0a , 3d12 , 3d19 , 3d21 , 3d28 ,
  3d2f , 3d37 , 3d3e , 3d45 , 3d4d , 3d54 , 3d5b , 3d62 , 3d69 , 3d70 ,
  3d77 , 3d7e , 3d85 , 3d8c , 3d93 , 3d9a , 3da1 , 3da7 , 3dae , 3db5 ,
  3dbb , 3dc2 , 3dc9 , 3dcf , 3dd6 , 3ddc , 3de2 , 3de9 , 3def , 3df5 ,
  3dfc , 3e02 , 3e08 , 3e0e , 3e14 , 3e1b , 3e21 , 3e27 , 3e2d , 3e33 ,
  3e38 , 3e3e , 3e44 , 3e4a , 3e50 , 3e55 , 3e5b , 3e61 , 3e66 , 3e6c ,
  3e71 , 3e77 , 3e7c , 3e82 , 3e87 , 3e8c , 3e92 , 3e97 , 3e9c , 3ea1 ,
  3ea7 , 3eac , 3eb1 , 3eb6 , 3ebb , 3ec0 , 3ec5 , 3eca , 3ece , 3ed3 ,
  3ed8 , 3edd , 3ee1 , 3ee6 , 3eeb , 3eef , 3ef4 , 3ef8 , 3efd , 3f01 ,
  3f06 , 3f0a , 3f0e , 3f13 , 3f17 , 3f1b , 3f1f , 3f23 , 3f27 , 3f2b ,
  3f2f , 3f33 , 3f37 , 3f3b , 3f3f , 3f43 , 3f47 , 3f4a , 3f4e , 3f52 ,
  3f55 , 3f59 , 3f5d , 3f60 , 3f64 , 3f67 , 3f6a , 3f6e , 3f71 , 3f74 ,
  3f78 , 3f7b , 3f7e , 3f81 , 3f84 , 3f87 , 3f8a , 3f8d , 3f90 , 3f93 ,
  3f96 , 3f99 , 3f9c , 3f9e , 3fa1 , 3fa4 , 3fa6 , 3fa9 , 3fac , 3fae ,
  3fb1 , 3fb3 , 3fb5 , 3fb8 , 3fba , 3fbc , 3fbf , 3fc1 , 3fc3 , 3fc5 ,
  3fc7 , 3fc9 , 3fcb , 3fcd , 3fcf , 3fd1 , 3fd3 , 3fd5 , 3fd7 , 3fd8 ,
  3fda , 3fdc , 3fde , 3fdf , 3fe1 , 3fe2 , 3fe4 , 3fe5 , 3fe7 , 3fe8 ,
  3fe9 , 3feb , 3fec , 3fed , 3fee , 3fef , 3ff0 , 3ff1 , 3ff2 , 3ff3 ,
  3ff4 , 3ff5 , 3ff6 , 3ff7 , 3ff8 , 3ff9 , 3ff9 , 3ffa , 3ffb , 3ffb ,
  3ffc , 3ffc , 3ffd , 3ffd , 3ffe , 3ffe , 3ffe , 3fff , 3fff , 3fff ,
  3fff , 3fff , 3fff , 3fff , 4000 ,
1025 constant SINE_TABLE_SIZE
decimal
\ clampAngle takes brads as input and returns an angle that is positive and
\ always less than a FULL_ROTATION. That way we can be sure to use the angle
\ as an index into the trig table.
: clampAngle ( angle - angle between 0 to full rotation )
  FULL_ROTATION
  mod ;
\ Sine takes brads as input and returns a scaled sine value. However, to
\ save memeory the sine table only contains one quadrant, angles in other
\ quadrants are mapped onto the first with sign modification if needed.
: sine ( angle - result )
  clampAngle
  dup BRAD_N 2 - rshift		\ find the quadrant 0, 1, 2, 3
  case
    0 of
      cell *			\ convert angle to offset
      sineTable + @		\ index into sine table
    endof
    1 of
      STRAIGHT_ANGLE swap -	\ reflect angle and lookup.
    endof
    2 of
      STRAIGHT_ANGLE -		\ rotate angle and lookup.
      negate
    endof
    3 of
      FULL_ROTATION swap -	\ reflect angle and lookup.
      negate
    endof
   endcase ;
\ cosine is defined in terms of sine by coordinate rotation.
\ cos = sin ( angle + RIGHT_ANGLE )
: cosine ( angle - result )
  RIGHT_ANGLE +
  sine ;
RIGHT_ANGLE sine constant MAX_SINE
RIGHT_ANGLE negate sine constant MIN_SINE
\ clamps n between max and min to prevent inverse trig function overflow.
: clampSine ( n -- clamped_value )
  MIN_SINE
  2dup <			\ Compare without consuming them
  if
    nip				\ If n1 < n2, drop n1 and keep n2
  else
    drop			\ If n1 >= n2, drop n2 and keep n1
  then
  MAX_SINE
  2dup >
  if
    nip
  else
    drop
  then ;
\ arcsine takes an input and maps it to a valid sine value and returns the
\ closest angle that matches it. It is done using binary search of the sine
\ quadrent with sign adjustment.
: arcsine ( sine - brad )
  clampSine
  dup 0 <
  if
    -1 swap abs			\ save the sign
  else
     1 swap
  then
  ACUTE_ANGLE			\ 45° first approximation on data stack
  dup 2/ >r			\ 22.5° correction factor on return stack
  \ data stack has ( sign value approximation )
  begin
    r@ 0 >			\ loop until correction factor reaches zero
  while
    dup >r sine			\ stack has (sign, value, approximation)
    over =
    if				\ exact match, terminate loop
      r> r> drop
      0 >r			\ set correction factor to zero.
    else			\ otherwise adjust with correction factor
      r@ sine			\ stack has (sign, value, approximation )
      over <
      if
        r> r>
	dup 2/ >r		\ halve correction factor
	+			\ approximation too small, add the correction
      else
        r> r>
	-			\ approximation too large, subtract correction
      then
    then
  repeat
  r> drop			\ clean up return stack
  swap drop			\ drop input argument
  * ;				\ restore the sign
\ arccosine is defined in terms of arcsin with coordinate rotation.
: arccosine
  arcsine
  RIGHT_ANGLE
  negate ;
decimal
SamCoVT
Post by SamCoVT »
Thanks for posting your trig code. The only thing I had trouble figuring out was BRAD_N. After looking at the code, I'm pretty sure that's the Binary RADians Number of bits value (and it looks like it's set to 12 because 0-4095 is mapped to 0-2*pi to match your encoders).
I often use scaled integers or fixed point for microcontroller applications, but hadn't really seen it used with trig functions like this. I especially like the reuse of the table to keep the data size smaller. The whole thing compiled to about 3.8K (2.75K if I turn off in-lining) on my Forth. The only word I didn't have is CELL, which I'm assuming is the size of a cell in bytes so I just made that a constant 2 for my 16-bit forth. ANS Forth has the word CELLS that accepts the number of cells and returns the number of bytes, and it looks like GForth defines CELL to be 1 CELLS. I think I also could have converted your cell * in the word sine into just CELLS.
Martin_H
Post by Martin_H »
You're welcome, glad you found it helpful.
Yes, they're binary radians which are common in embedded systems. I should have added a link in my code to the Wikipedia article:
https://en.wikipedia.org/wiki/Binary_an ... easurement
Yes, I chose the resolution to match my encoders. It's always a tradeoff between accuracy and memory, but exceeding your ability to measure usually isn't helpful.
