Page 7 of 15
Re: Breaking 6502 apart
Posted: Mon Aug 27, 2012 8:31 am
Switched Google code project to MIT License.
Posted: Fri Aug 31, 2012 3:30 pm
by org
Completed random logic at trans-level
Random logic interconnections with other 6502 parts:
Inputs
PHI1,PHI2: timing
Reset0: from RST pin
NMIG: from NMI pin logic
IRQP: from IRQ pin logic
/IR5: from instruction register, to determine CLC/SEC and others
SO: from SO pin, set V-flag
RDY: from RDY pin
BRKDONE, VEC: from interrupt priority logic
2 inputs from predecode logic.
129 lines from PLA.
AVR: overflow out from ALU
ACR: carry out from ALU
Outputs
TRES: reset T-counter
sync: shift T-counter, additionally output to SYNC pin
T0, T1X: first two steps of instruction decoding, to PLA
R/W: Goes to R/W pin and data latch
fetch: Force instruction register to load from Predecode Register
VEC0: to interrupt priority logic, when BRK detected
48 output drivers, to control bottom part.
Also random logic is connected with internal data bus (DB) to exchange status reg (flags).
Posted: Tue Sep 04, 2012 5:01 pm
by org
Fixed shortcut in T-step shift register:
Added C simulation:
http://code.google.com/p/breaks/source/ ... TIME_REG.c
+ modified first post.
Posted: Tue Sep 04, 2012 6:28 pm
All good! Please could you link to something like
http://code.google.com/p/breaks/source/ ... 6502%2FSRC
from the first post too?
Posted: Wed Sep 05, 2012 12:29 pm
by org
Added address bus registers simulation + modified first post with direct links.
Posted: Thu Sep 06, 2012 5:59 am
by org
Added missing R/W distribution tri-state, which goes from random logic to data latch.
(attached)
- More clear picture of PLA for double-checking
- Started complete 6502 schematics (WIP)
- Complete PLA simulation here:
http://code.google.com/p/breaks/source/ ... /SRC/PLA.c
Posted: Mon Sep 10, 2012 11:29 am
by org
Almost complete 6502 schematics. Only left to add missing latches and fix small errors )
I decided not to draw PLA as transistors and left it just as color diagram.
Posted: Mon Sep 10, 2012 11:39 am
Nice progress! I've subscribed to the
RSS feed of your code project, and to
the feed for
your wiki.
Posted: Mon Sep 17, 2012 12:55 pm
by org
I have a small break due to HDD failure, but thanks to Google Drive, I quickly restored all data.
Now I can present complete 6502 rev. D schematics. This part of my job is done here:
High-resoultion images can be found on google code project.
I uploaded photoshop sources here :
http://ogamespec.com/6502/sources.zip (~200 MB)
And updated most interesting parts (ALU and random logic) by recent changes:
http://ogamespec.com/6502/ALU.psd
http://ogamespec.com/6502/LOGIC.psd
(remember, this is not WIP anymore)
Posted: Mon Sep 17, 2012 1:31 pm
Very nicely done!
Posted: Mon Sep 24, 2012 4:51 pm
by org
Integrated simple assembler, to test 6502 operations in simulator.
ASM.c
ASMOPS.c
Posted: Thu Oct 04, 2012 10:38 am
by org
I started to simulate /NMI logic and I have problems, understanding a part of circuit.
Here:
I know, this is called bistable latch, but I dont understand it at all ))
The upper MOSFET is grounded at the same time, as bottom one.. Can you explain me what happen here )
EDIT: I found solution by myself
static nout;
b = ~(~(in & Ф2) | nout);
nout = (~(~in & Ф2) | b);
out = ~nout;
Posted: Thu Oct 04, 2012 5:00 pm
I agree with the general form: it's a pair of NORs cross-coupled, with a final output inverter.
But I'm not completely sure about all the '~' operators.
I suppose you can see the result in simulation!
Posted: Thu Oct 04, 2012 6:14 pm
by org
Simulation work badly ( And I cannot track the error...
Posted: Thu Oct 04, 2012 6:21 pm
How about
static nout;
b = ~((in & Ф2) | nout);
nout = ~((~in & Ф2) | b);
out = ~nout;
