Page 7 of 9
Posted: Thu Nov 24, 2011 8:28 am
by Arlet
In more concrete news, I tried to fit Arlet's core (the smallest) to CoolrunnerII, and it failed to fit the largest CPLD: 577 macrocells needed versus 512 available. Not missing by an enormous margin, but missing.
I assume you tried the old core without BCD support. Correct ?
Ah, I see you already said that you tried the smallest. Never mind.
Posted: Thu Nov 24, 2011 8:17 pm
ah, actually no, I merely meant that yours is the smallest of the collection of cores. We can indeed lose a bit with BCD and a bit by losing RDY. (But not much.)
Posted: Thu Nov 24, 2011 8:28 pm
by ElEctric_EyE
If I may interject, I thought I was able to fit one of the cores (I thought it was Arlet's) into a Xilinx 208-pin CPLD...
I searched this forum, but could not find the post I'm referring to. But I would've sworn that I'd posted it somewhere on this forum.
Posted: Thu Nov 24, 2011 8:54 pm
Just checked - looks like the largest CPLDs are very expensive (£40, and that's only 384 macrocells). So if the advantage is the 5v tolerance, it would have to be very important. (Smaller CPLDs are a different matter, but for a super fast 6502 part it seems to me that a small Spartan 3AN at £7 makes more sense.)
Posted: Fri Mar 16, 2012 2:47 pm
I see Oleg Odintsov has posted a new core:
http://opencores.org/project,ag_6502
It's unusual in being phase accurate, a relatively compact implementation but coded in some High level source compiled to verilog.
Posted: Fri Mar 16, 2012 3:55 pm
Also Ian Chapman posted a core back in late 2010
http://opencores.org/project,lattice6502
which is not intended to be cycle accurate but to take fewest clock cycles per instruction.
From the source:
---- I will make it run as fast as I can. Timing not per a real 6502.
---- Lattice EBI has clocked address inputs, so as not to add a cycle
---- 6502 address outputs are not latched. The data output of the EBI ROM and
---- RAM is not clocked.
---- To maintain speed the 6502 address to ROM/RAM is not clocked and the data
---- returned is not clocked by ROM/RAM. Structures of form address <= address + "1";
---- cause a race condition. I had to store the address from the mux for
---- INC type instructions ie read then write.
Re: 6502-Core Comparisons: Fitting a Xilinx Spartan 2 XC2S20
Posted: Sun Apr 22, 2012 9:43 pm
by fachat
I think you finally may add the 65k core to the list of available cores
http://www.6502.org/users/andre/65k/index.html
André
Posted: Sun Apr 22, 2012 9:46 pm
by ElEctric_EyE
So it is a fully functional 6502 core as well? I can add it in a couple days. Thanks!
Posted: Sun Apr 22, 2012 9:48 pm
by fachat
It's binary compatible, but of course adds my extensions. It's huge though - extensions were more of a goal than code/silicon size.
Still kind of alpha though.
André
Re:
Posted: Mon Jun 11, 2012 11:58 am
by Oleg Odintsov
Hello everyone! At present, I am testing my new core and preparing documentation for both compiler and core. So if you found some mistakes or improper behaviour of the core, please send me a bug report.
Latest version of the core stably works at 10 MHz (using 50 MHz clock source for phase shift and delays). I was trying to increase it's speed by using DCM to multiply clock source to 200 MHz thus enabling to increase cpu speed to 40 MHz, but it doesn't works in my Spartan 3E (even if I was using 1 MHz clock source with 200 MHz phase shift). Did anybody happened to do this on Spartan family of FPGA?
Posted: Mon Jun 11, 2012 1:48 pm
Welcome Oleg!
I can't answer your question, but I'm sure someone can.
This is presumably your system:
http://www.youtube.com/watch?v=rOFKD8A-syU
Posted: Mon Jun 11, 2012 1:58 pm
by Oleg Odintsov
Yes, those videos tagged with "agat-7" are mine.
Posted: Mon Jun 11, 2012 7:07 pm
by ElEctric_EyE
Oleg, welcome to the Forum!
Another one bitten by the 6502 'speed bug'
Posted: Tue Feb 26, 2013 11:12 pm
by ElEctric_EyE
Rob Finch has a new
website. I will update the link in the original post.... Thanks for Dr. Jeff alerting me. I see Rob has contributed to 6502.org's
sister site. Welcome back!
I'm thinking of re-doing this thread but doing the comparisons around a Spartan 6 device, since we have some new additions like Oleg and MichaelM's softcore. I know I've said it before, but tomorrow I will start on the new thread, with pics as attachments. Hopefully 6502.org Admin will not have a problem with this. The service Photobucket, which I used to use has changed too much to be useful.
Posted: Wed Feb 27, 2013 8:41 pm
by ElEctric_EyE
Also, Mike J. has a recent update on his
fpgaarcade site just this month, after almost a year delay.
