Page 6 of 17
Re: Random-number generation
Posted: Thu Mar 23, 2023 5:38 pm
by Arlet
In your code, when you do 'rndbyte = (rndbyte + carry)' you should generate an additional carry when rndbyte=255 and carry=1
Posted: Thu Mar 23, 2023 5:44 pm
by Arlet
Alex1 wrote:
Found '008AA873' at index 0 !
Found '008AA873' at index 11EC9D07 !
Found '008AA873' at index 36982356 !
Found '008AA873' at index B20751BF !
I don't see that. Here is my output (byte #, internal state, output byte)
11ec9d02 : 8a a0 25 94 ba 34 ef - 55
11ec9d03 : cf 6f 95 29 81 b6 a5 - 24
11ec9d04 : 14 84 19 43 67 1e c4 - a3
11ec9d05 : 59 dd f6 39 65 84 48 - 2d
11ec9d06 : 9e 7b 72 ac 49 ce 16 - 5f
11ec9d07 : e3 5e d1 7d b5 83 9a - 2f
11ec9d08 : 28 87 58 d6 01 85 1f - 1e
11ec9d09 : 6d f4 4c 23 3e c3 e2 - dc
11ec9d0a : b2 a6 f3 16 33 f7 d9 - ea
11ec9d0b : f7 9d 91 a8 a4 9b 75 - d1
Posted: Thu Mar 23, 2023 5:51 pm
by Alex1
ah yes, thanks !
by Arlet
Here's when I see the bytes 00 8A A8 73 in sequence:
(index)    : internal state       - output 4-byte sequence
0000000004 : 14 b3 66 74 dc ce af - 73 008aa873
001b4c11af : 2b 0c f5 cc 69 0f 1a - 73 008aa873
031110bb51 : d5 19 99 54 ff aa 8c - 73 008aa873
036d723c01 : 45 71 51 42 13 8c 60 - 73 008aa873
038707f8e7 : 43 72 c4 30 59 ea 2a - 73 008aa873
As you can see, even though the sequence 00 8A A8 73 shows up repeatedly, the internal state differs. That's because you're only watching 4 consecutive bytes, but there are 7 bytes of state.
Posted: Thu Mar 23, 2023 5:52 pm
by Alex1
Here is the code i use, something wrong with unint_t ? Could you paste your C code ready to compile ?
#include <stdint.h>
#include <stdio.h>
#define ADD( a, b )                 \
    do {                            \
        x = a + (b);                \
        a = x;                      \
    } while (0)
#define ADC( a, b )                 \
    do {                            \
        x = a + (b) + (x >> 8) % 2; \
        a = x;                      \
    } while (0)
    uint16_t x;
void main()
    uint8_t s0,s1,s2,s3,s4,s5,s6,res;
    uint32_t z,q;
    s0=0;s1=0;s2=0;s3=0;s4=0;s5=0;s6=0;
    q=0xffffffff;
    for (z=0;z<q;z++)
        ADD( s0, 0x45 );
        ADC( s1, s0 );
        ADC( s2, s1 );
        ADC( s3, s2 );
        ADC( s4, s3 ^ s6 );
        ADC( s5, s4 );
        ADC( s6, s5 );
        res= s6 ^ s4;
       // putchar( s6 ^ s4 );
        printf("%0.2X",res);
        //printf("%0.2X %0.2X %0.2X %0.2X %0.2X %0.2X %0.2X %0.2X\n", s0,s1,s2,s3,s4,s5,s6,res);
Posted: Thu Mar 23, 2023 6:01 pm
by Arlet
That looks good, as far as I can see, but when I run it, I don't see 008AA873 at index 11EC9D07
Posted: Thu Mar 23, 2023 6:04 pm
by Alex1
Okay so you find the same repetitive outputs, but why don't you find them at the same indexes as on my side?
Can an onverflow cause this?
something with uint16_t and uint8_t ? Data loss during conversion?
Posted: Thu Mar 23, 2023 6:11 pm
by gfoot
I think you need to cast up to uint16_t before adding, inside the macros. Otherwise it does the add truncated to 8 bits, even though the result is stored in a 16 bit variable.
Edit: here for sure in ADD - doesn't matter which operand you cast:
x = (uint16_t)a + (b);
And maybe similarly in ADC though in that one the fact that "x" is involved might mean it's already evaluated at 16 bits - I don't recall whether these things associate left or right though so maybe casting the a or b term would be needed.
Posted: Thu Mar 23, 2023 6:12 pm
by Alex1
could you give me an example ?
Posted: Thu Mar 23, 2023 6:26 pm
by Arlet
According to C standard, addition of smaller integer types should be promoted to 'int' before doing the addition, so there's no need to do a cast first.
Posted: Thu Mar 23, 2023 6:30 pm
by Arlet
I copied your program, and then let it run to the point where you found the first repetition, and printed out the values. At that point, I did not see the pattern in the output.
Posted: Thu Mar 23, 2023 6:32 pm
by gfoot
Ah OK, apologies, I had thought it just promoted to the wider width of the two.
Posted: Thu Mar 23, 2023 6:33 pm
by Alex1
Then it's a compilation problem. I'm on linux ARM.
How should i cast your code to try if the problem is solved with it ?
Posted: Thu Mar 23, 2023 6:39 pm
by Arlet
It does that too, but only if one of the types is larger than 'int'. So if you do int + long, it will first promote the 'int' to 'long' and then do long+long addition.
Posted: Thu Mar 23, 2023 6:42 pm
by Arlet
I added this to your code:
        ADC( s3, s2 );
        ADC( s4, s3 ^ s6 );
        ADC( s5, s4 );
        ADC( s6, s5 );
        res= s6 ^ s4;
        if( z > 0x11EC9D00 )
            printf("%08x : %0.2X %0.2X %0.2X %0.2X %0.2X %0.2X %0.2X = %0.2X\n", z, s0,s1,s2,s3,s4,s5,s6,res);
            if( z > 0x11EC9D10 )
                break;
When I run it, I get this:
11ec9d01 : 8A A0 25 94 BA 34 EF = 55
11ec9d02 : CF 6F 95 29 81 B6 A5 = 24
11ec9d03 : 14 84 19 43 67 1E C4 = A3
11ec9d04 : 59 DD F6 39 65 84 48 = 2D
11ec9d05 : 9E 7B 72 AC 49 CE 16 = 5F
11ec9d06 : E3 5E D1 7D B5 83 9A = 2F
11ec9d07 : 28 87 58 D6 01 85 1F = 1E
11ec9d08 : 6D F4 4C 23 3E C3 E2 = DC
11ec9d09 : B2 A6 F3 16 33 F7 D9 = EA
11ec9d0a : F7 9D 91 A8 A4 9B 75 = D1
11ec9d0b : 3C DA 6B 14 06 A2 17 = 11
11ec9d0c : 81 5B C7 DB D2 74 8C = 5E
11ec9d0d : C6 21 E9 C4 1B 90 1C = 07
11ec9d0e : 0B 2D 16 DB E2 72 8F = 6D
11ec9d0f : 50 7D 93 6E C4 37 C7 = 03
11ec9d10 : 95 12 A6 14 98 D0 97 = 0F
11ec9d11 : DA EC 92 A7 C8 98 30 = F8
can you try that too?
