Hi Daryl
Glad to see work progressing, looking forward to further updates especially for PI 3 as I have a few of them (not all in use).
Larry
65C02 Simulator on a bare metal Raspberry PI
- Sheep64
- In Memoriam
Re: 65C02 Simulator on a bare metal Raspberry PI
Firstly, I quite like the allocation of seperate cores to multi-media. This provides the most immediate performance boost.
Secondly, I am curious to know how much of this work can be deployed on MCL65+.
Thirdly, I strongly recommend augmenting the six bit RRGGBB palette with two least significant intensity bits shared across all channels. (See 16*16 Pixel Tile Video Display And Video Codec for subjective test results across four 8 bit palettes.) At the very least, common intensity bits provide 16 shades of gray rather than four.
Thanks for your input!
okwatts wrote:
Hi Daryl
Larry
Larry
https://sbc.rictor.org/pisim.html
8BIT wrote:
In core 2, I have a 320x200 display set up with 63 colors ( 2 bits for each Red, Green, & Blue). I have it set up as 4 addresses in the simulator IO space
$8040 = pixel color - 0x00RRGGBB
$8041 = Y coordinate 0 - 199, above that and the pixel will not get plotted
$8042 = X coordinate low byte
$8043 = X coordinate high byte 0-319, above that and the pixel will not get plotted
A write to $8044 will tell core2 to plot the point.
Just one comment: you might be able to get a fair efficiency boost, especially for doing things like clearing the screen, by changing it so that a write to $8042, the X coordinate low byte, triggers a plot. Then a lot of the plotting time for some common operations would simply be incrementing and writing the X co-ordinate.
I'd have to check to see if the plot engine could keep up, or if you might miss a point. I have a poll for engine ready status to prevent missing plots. Unfortunately, I dont have spare time to test right now. I'll keep this on my to-do list.
Thanks for the suggestion!
Perhaps generate wait states on write when not ready? Though that of course just slows the CPU.
MSX machines have this issue with their VDPs (TMS9118 and friends). There might be something in all the work that's been done on that that could help, but it probably is a bit of a rabbit hole.
