Page 6 of 10
Re: From 8bit breadboard to 6502
Posted: Sat Aug 05, 2017 9:40 pm
by nei02
If for future Project useful! Maybe I Should Buy one.
Its 100nF I have no smaller ones. I have tried without condenser .
Posted: Sat Aug 05, 2017 10:00 pm
by Dr Jefyll
Thank you.
And are the results the same? Really, it's important to provide plenty of information! Otherwise it becomes harder for anyone trying to help.
I get only dots ...........
Do you mean the UART is connected to a terminal, and the terminal is receiving the period character ($2E)?
Posted: Sat Aug 05, 2017 10:58 pm
by nei02
I am using CoolTerm.
Adapter: PL2303HX USB zu TTL RS232.
https://www.amazon.de/gp/product/B00WE0 ... UTF8&psc=1
Dots mean Hex00. So basically nothing.
When I run it without the condenser it is the same.
I have checked address decoding. When the programm reaches the step to store to address $4080
The write pin gets low. CS0 High, CS1B Low, RS0 & RS1 Low.
1-VSS-ground
2-CS0-A7
3-CS1B - output NAND address decoding
4-RESB - 5V
5-RXC - NC
6-XTLI - Crystal
7-XLT0 - Crystal
8 - RTSB - NC
9 - CTSB - ground
10 - TXD - Adapter pin green TXD
11 - DTRB - NC
12 - RxD - Adapter pin white RXD
13 - RS0 - A0
14 - RS1 - A1
15 - VDD - 5V
16 - DCDB - ground
17 - DSRB - ground
18-25 Data
26 - IRQ - NC
27 - PHI2 - Clock CPU 1 MHz
28 - RWB - Read/Write CPU
Posted: Sun Aug 06, 2017 5:55 am
by nei02
Since the loopback test with CoolTerm and am RS232-USB adapter doesn't work,
(First time that I those things) I will stop testing and order a new adapter.
Posted: Sun Aug 06, 2017 7:48 am
You can put [co
de] and [/code] around your code so the forum software will keep the white space you intended instead of throwing out all the spaces it thinks are extra.
Next, some things to simplify the code a bit (although this still leaves a problem I'll address further down):
- You can leave out the LDA #$00 because you don't do anything with it before the LDA ACIA_DATA further down.
- You can leave out the LDX #$00 because it doesn't matter what the data is when storing to the status register. You can store anything to the status register and it will reset the '51. Even if it did need to be 0, you could save a byte by doing INX (a single byte, since you had $FF in there from before the TXS). Assuming you have a CMOS 6502 (65c02), you could store 0 without it being in a register, using STZ ACIA_STAT.
- You can leave out the LDY #$00 because you have it below anyway.
- Since you null-terminate the string, you can use the LDA Hello,Y's automatic, implied compare-to-0 and leave out the CPY.
So the result is:
RESET: LDX #$FF
TXS
STZ ACIA_STAT ; You can store anything to ACIA_STAT. It doesn't matter.
LDA ACIA_DATA
LDA #%00011110
STA ACIA_CTRL
LDA #%00001011
STA ACIA_COMM
START: LDY #$0
OUTPUT: LDA Hello,y
BEQ START ; If we just picked up the null terminator, start over.
STA ACIA_DATA
INY
BRA OUTPUT
hello: .byte "HELLO", 0
Now: The next thing is that you have a severe overrun problem! You don't have any delay between bytes fed to the '51 to give it time to send each one. If you don't have a WDC '51 with the bug, you would use bit 4 of the status register to make sure it's ready for the next byte. But with WDC's bug, you can either use a delay loop (not my favorite, because then the computer can't do anything else while waiting), or use one of the timers in a 65(c)22 VIA, and then either poll the timer or set it up to produce an interrupt.
Currently I have a 100nF connected.
If you have a 100nF (ie, 0.1µF) in the crystal circuit, it absolutely will not work. You should have something like what's in the second diagram at
http://wilsonminesco.com/6502primer/IO_ICs.html, in about the middle of the page. 100nF is about 4,000 times too much. (1nF is a thousand pF.)
Posted: Sun Aug 06, 2017 11:09 am
by nei02
Thank you for revising my code. This helps a lot to learn!
Capacitor:
Will order a couple of capacitors to have various values at hand.
Delay:
Yes I have a WDS 65C02. The manual says that there is a bug and one should use a delay.
But even without delay I would have assumed that I get a least some characters transmitted.
For the first step I will go with a delay since I don't have an AVIA. And I want to reduce the complexity.
I saw anywhere in this forum (or it was the primer turorial) how to implement a delay. Will study this.
Adapter:
But still believe that the adapter doesn't work since the loopback test doesn't work.
I ordered a new one with an CP2102.
Posted: Sun Aug 06, 2017 3:56 pm
Delay:
Yes, if you try transmitting "HELLO" over and over, you should see those letters coming through, but not in order, since many letters would get skipped between the ones that do get sent. The problem is that the onboard oscillator will not work with the .1µF capacitor from input to ground. If you use an outboard oscillator can, you don't need the capacitor at the input at all. Make sure you put the 1M resistor across the crystal like the WDC data sheet shows. Not all brands use this. Also, check the lot on your '51. I see now that the WDC data sheet says the internal oscillator didn't work right in a couple of lots SA1105A and SA0519A. Darn. It looks like they hurried this thing too much! I never had any trouble with the other (slower) brands of '51 I used, as long as I had the 22pF capacitor at he input.
You wouldn't need the VIA for just RS-232 I/O; but soon you'll probably want the other benefits of a VIA anyway, especially some parallel I/O and timers. BTW, it's "VIA" (for "Versatile Interface Adapter," not "AVIA." The "A" in "ACIA" (the 65c51) is for "Asynchronous," in "Asynchronous Communications Interface Adapter.")
At 1MHz processor clock speed, one frame of RS-232 at 9600,8,N,1 will take a little over 1042 processor clock cycles. Your software delay could be something like:
which with the other instructions in your loop, will give just a few more cycles than you need. I'm in a hurry to leave now so I can't take time to merge it with your code, but I'll take a look later.
Posted: Sun Aug 06, 2017 4:24 pm
by nei02
Thank you very much! I was thinking to buy an oscillator can 1.8432 MHz. So I will do now.
I ordered a collection of ceramic capacitors anyway. So I can test both variants.
I can't read the lot on the chip.
The 1Mg resistor is in parallel to the crystal.
I bought the eBook of Programming the 6502, 65C02,.... as suggested.
Vielen Dank
Ralf
Posted: Sun Aug 06, 2017 4:43 pm
by nei02
So -> Ordered
a second ACIA 65C51 (just in case)
Oscillator can 1.8432 MHz
22 pF, 37pF
CP CP2102N-MINIEK
http://www.mouser.com/ds/2/368/SiLabs_0 ... 080002.pdf
It would mean so much to me if my 65C02 could talk to me!
Posted: Sun Aug 06, 2017 6:57 pm
by nei02
Found this interesting cause I was wondering why the 6502 steps to different addresses when powered on
http://www.pagetable.com/?p=410
Posted: Sun Aug 06, 2017 7:55 pm
by nei02
The Ophis Assembler seems to have a problem with the OPCODEs
STZ and BRA
Perhaps because Ophis is only for 6502 and not for 65C02
Posted: Sun Aug 06, 2017 8:00 pm
by nei02
And I have a question:
If I assemble my the (unrevised) code and disassembled this. I don't understand where the last three opcodes come from and where the .byte "Hello World" is stored.
The jump at the end to $004F concerns me since my code start at $8600 (ROM)
But which opcode tells the 6502 to store the .byte "Hello World"
Assembler: Ophis
Posted: Sun Aug 06, 2017 8:19 pm
I'm back.
STZ and BRA
The 65c02 has only been out about 35 years. Maybe they just need a little more time to catch on!
If I assemble my the (unrevised) code and dissemble this I don't understand where the last three opcodes come from and where the .byte "Hello World" is stored.
That's a problem with disassemblers. They don't understand when something is data rather than code. Your "HELLO",0 is there. ASCII for "H" is the $48 which is also PHA; ASCII for "E" is $45 which is also EOR ZP; and so on.
by rwiker
Hint: what are the hexadecimal values for the ascii codes of "H", "E", "L" and "O"?
Posted: Sun Aug 06, 2017 8:23 pm
The reset circuit should always do its thing upon power-up, not just when someone presses a button. So on power-up, the reset routine will always be the first thing run, and automatically. It's the one whose address is found at $FFFC and $FFFD. The other two vectors are for interrupts, and their sources should be disabled by the reset, and should not be enabled until the software enables them. My 6502 interrupts primer is
here.
