Page 6 of 9
Posted: Mon Aug 29, 2011 5:16 am
by teamtempest
(I can't say how pleased I was to discover that on linux I did
./HXA_TW.EXE pi.asm
and by happening to have WINE installed it "just worked" - your assembler is cross-platform after all.)
It's always nice to have one's favorite programming environment available, isn't it? That's probably why I'm still fooling around with Thompson AWK in the first place!
Posted: Wed Sep 07, 2011 11:19 am
by ElEctric_EyE
I have noticed when using Bitwise's assembler, the org. starts at $FFFFF000 but the .bin file is 8K long meaning the org. is really $FFFFE000. When I try to change the .org to $FFFFE000 there are all zero's. Can someone confirm this?
Not really a huge deal at this point as I can change the reset vector in my hex editor, but something is skewed...
Posted: Wed Sep 07, 2011 1:49 pm
by ElEctric_EyE
My mistake, I forgot. It's 4Kx16. Not 8Kx8. My hex editor confuses me, even though I have it set up to display 16-bit data, it still thinks in terms of 8-bits, so the offsets are wrong. I guess I have no need for the hex editor now...
Posted: Wed Sep 07, 2011 2:57 pm
by BitWise
4K of 16 bit bytes = 8K of 8 bit bytes
Edit: Ah I see you got there. Thats the problem with leaving IE open and going off to meetings
Posted: Sun Oct 23, 2011 11:42 pm
by ElEctric_EyE
Bitwise, how do we define Labels in your assembler?
Posted: Mon Oct 24, 2011 6:43 am
by BitWise
SomeLabel
Or
SomeLabel:
You can also have local labels (which can be reused elsewhere) provided they follow a global label
GlobalLabel:
  LDX #10
.Loop DEX
  BNE .Loop
Posted: Mon Oct 24, 2011 9:53 am
by ElEctric_EyE
I've used local labels. I was able to see how you used them in your example boot program. They work as long as they're longer then 1 letter...
But I am trying to do something like:
   .CODE
	.ORG	$FFFFF000
	dcom = $FFFF0010
	ddat = $FFFF0011
CLRSCR:	PHA
		TXA
		PHA
		TYA
		PHA
		LDA #$2a	;set x address
		STA dcom
		LDA #$00	;start
		STA ddat
Posted: Mon Oct 24, 2011 10:37 am
by BitWise
Looks like you are trying to define some 'equates'. So either
dcom = $FFFF0010
ddat = $FFFF0011
or
dcom .EQU $FFFF0010
ddat .EQU $FFFF0011
No spaces before the symbol name.
Posted: Mon Oct 24, 2011 1:04 pm
by ElEctric_EyE
No spaces. That worked...
Your program automatically converts a 6502 program to 65Org16? It sure seems like it does after copying and pasting a short 6502 routine I wrote using MK's assembler.
Posted: Mon Oct 24, 2011 1:16 pm
by BitWise
I built the 65Org16 assembler from the same Java source as my 6502 family assembler. Its uses the same parser but I stripped out support for device switching (.6502, .65C02, .65816) and extended byte to be 16-bits through out.
So if you feed it vanilla 6502 source it will come out as 16-bit code.
Posted: Wed Oct 26, 2011 11:19 am
by ElEctric_EyE
Excellent!
Would it be too much trouble to increase the size of the boot.asm file to 8Kx16? The reason I ask is because I have 3 assemblers/disassemblers I'm looking at, and 2 of the 3 top out at 4Kx8. I'm looking to convert Micromon-64, Supermon-64, and/or Hashmon for my project.
Posted: Wed Oct 26, 2011 11:32 am
by BitWise
ElEctric_EyE wrote:
Excellent!
Just change the start address for your code in the source file (e.g. .ORG $FFFFE000) and the linker options to reflect the new code area
LK65_FLAGS = \
	-bss $$00010000-$$EFFFFFFF -code $$FFFFE000-$$FFFFFFFF
Posted: Wed Oct 26, 2011 11:46 am
by ElEctric_EyE
Thanks for the quick reply.
How does one go about changing the linker file/options?
I tried pasting that code in the assembly and it's giving some exceptions.
Posted: Wed Oct 26, 2011 12:34 pm
by BitWise
The linker options are in the makefile
Posted: Wed Oct 26, 2011 1:43 pm
by ElEctric_EyE
I see it. Thank You. :D
