Microbot TeachMover 6502 based Robot Arm, Memory Map
leeeeee
- In Memoriam
falcon5252
I downloaded it an opened it in Vista and it ran, Do I need to use a compatibility mode with it, or will it work ok without it..
Also will Michal Kowalski's program compile it to a BIN or HEX file for programming a Prom or do I need a separate program for that
When falling from a high place, You might as well try to fly
Nightmaretony
- In Memoriam
The Kowalski will go into several formats, several hex and bin. you need an eprom programmer program, though.
///nother Kowalski lover
//since it is now abandonware, I can make a page to host it, can we get a project to udpate it for other things like 816 or 32 or org32?
- BigDumbDinosaur
Kowalski Simulator
;W65C816S INSTRUCTION MACROS
; These macros implement W65C816S native mode instructions,
; as well as 65C02 instructions that are not recognized by
; the Kowalski assembler (e.g., STP & WAI).
.if !.ref(brl)
brl .macro .op ;long relative branch...
.if .op ;won't work for forward...
.isize =3 ;branches because of forward...
.os =*+.isize ;address reference
.os =.op-.os
.if .os > 32767
.error %1 + ": FORWARD BRANCH OUT OF RANGE"
.endif
.if .os < -32768
.error %1 + ": BACKWARD BRANCH OUT OF RANGE"
.endif
.byte $82
.word .os
.else
.error "INSTRUCTION REQUIRES TARGET ADDRESS"
.endif
.endm
cop .macro .op ;co-processor
.if .op > $ff
.error "SIGNATURE MUST BE $00 - $FF"
.endif
.byte $02,.op
.endm
jsl .macro .bk,.ad ;JSL <bank><addr>
.byte $22
.word .ad
.byte .bk
.endm
jsrix .macro .op ;JSR (<addr>,X)
.byte $fc
.word .op
.endm
mvn .macro .s,.d ;move next <sbnk>,<dbnk>
.if .s > $ff
.error "SOURCE BANK MUST BE $00 - $FF"
.endif
.if .d > $ff
.error "DESTINATION BANK MUST BE $00 - $FF"
.endif
.byte $54,.d,.s
.endm
mvp .macro .s,.d ;move prev <sbnk>,<dbnk>
.if .s > $ff
.endif
.if .d > $ff
.endif
.byte $44,.d,.s
.endm
pea .macro .op ;pea <addr>
.byte $f4
.word .op
.endm
pei .macro .op ;pei (<addr>)
.if .op > $ff
.error "INDIRECT ADDRESS MUST BE $00 - $FF"
.endif
.byte $d4,.op
.endm
phb .macro ;push data bank register
.byte $8b
.endm
phd .macro ;push direct page register
.byte $0b
.endm
phk .macro ;push program bank register
.byte $4b
.endm
plb .macro ;pull data bank register
.byte $ab
.endm
pld .macro ;pull direct page register
.byte $2b
.endm
rep .macro .op ;clear status register bits
.if .op > $ff
.error "OPERAND MUST BE $00 - $FF"
.endif
.byte $c2,.op
.endm
sep .macro .op ;set status register bits
.if .op > $ff
.endif
.byte $e2,.op
.endm
stp .macro ;halt MPU
.byte $db
.endm
tcd .macro ;transfer .C to direct page register
.byte $5b
.endm
tcs .macro ;transfer .C to stack pointer
.byte $1b
.endm
tdc .macro ;transfer direct page register to .C
.byte $7b
.endm
tsc .macro ;transfer stack pointer to .C
.byte $3b
.endm
txy .macro ;transfer .X to .Y
.byte $9b
.endm
tyx .macro ;transfer .Y to .X
.byte $bb
.endm
wai .macro ;wait for interrupt
.byte $cb
.endm
xba .macro ;swap B & A accumulators
.byte $eb
.endm
xce .macro ;swap carry & emulation bits
.byte $fb
.endm
; stack-based accumulator instructions...
; Stack-based accumulator instructions take the form ***S or ***SI, the
; latter for indexed indirect operations. *** represents the parent
; instruction. For example, LDAS 1 is equivalent to LDA 1,S & LDASI 1
; is the equivalent of LDA (1,S),Y. The actual macro names are lower
; case. The macro comment indicates the official WDC assembly language
; syntax for the instruction being synthesized.
adcs .macro .op ;ADC <offset>,S
.if .op > $ff
.error "OFFSET MUST BE $00 - $FF"
.endif
.byte $63,.op
.endm
adcsi .macro .op ;ADC (<offset>,S),Y
.if .op > $ff
.endif
.byte $73,.op
.endm
ands .macro .op ;AND <offset>,S
.if .op > $ff
.endif
.byte $23,.op
.endm
andsi .macro .op ;AND (<offset>,S),Y
.if .op > $ff
.endif
.byte $33,.op
.endm
cmps .macro .op ;CMP <offset>,S
.if .op > $ff
.endif
.byte $c3,.op
.endm
cmpsi .macro .op ;CMP (<offset>,S),Y
.if .op > $ff
.endif
.byte $d3,.op
.endm
eors .macro .op ;EOR <offset>,S
.if .op > $ff
.endif
.byte $43,.op
.endm
eorsi .macro .op ;EOR (<offset>,S),Y
.if .op > $ff
.endif
.byte $53,.op
.endm
ldas .macro .op ;LDA <offset>,S
.if .op > $ff
.endif
.byte $a3,.op
.endm
ldasi .macro .op ;LDA (<offset>,S),Y
.if .op > $ff
.endif
.byte $b3,.op
.endm
oras .macro .op ;ORA <offset>,S
.if .op > $ff
.endif
.byte $03,.op
.endm
orasi .macro .op ;ORA (<offset>,S),Y
.if .op > $ff
.endif
.byte $13,.op
.endm
sbcs .macro .op ;SBC <offset>,S
.if .op > $ff
.endif
.byte $e3,.op
.endm
sbcsi .macro .op ;SBC (<offset>,S),Y
.if .op > $ff
.endif
.byte $f3,.op
.endm
stas .macro .op ;STA <offset>,S
.if .op > $ff
.endif
.byte $83,.op
.endm
stasi .macro .op ;STA (<offset>,S),Y
.if .op > $ff
.endif
.byte $93,.op
.endm
; 16 bit immediate mode instructions...
; Immediate mode instructions that are able to accept 16 bit operands
; take the form ***W, where *** is the parent 8 bit instruction. For
; example, ADCW is the 16 bit form of ADC. The actual macro names are
; lower case. It is the responsibility of the programmer to assure
; that MPU register sizes have been correctly configured before using
; ***W instructions. For example:
; LONGA ;16 bit .A & memory
; LDAW $1234 ;equivalent to LDA #$1234
; SHORTA ;8 bit .A & memory
; LDAW $1234 ;won't work as expected!!!
; The macro comment indicates the official WDC assembly language syn-
; tax for the instruction being synthesized.
adcw .macro .op ;ADC #nnnn
adc #<.op
.byte >.op
.endm
andw .macro .op ;AND #nnnn
and #<.op
.byte >.op
.endm
bitw .macro .op ;BIT #nnnn
bit #<.op
.byte >.op
.endm
cmpw .macro .op ;CMP #nnnn
cmp #<.op
.byte >.op
.endm
cpxw .macro .op ;CPX #nnnn
cpx #<.op
.byte >.op
.endm
cpyw .macro .op ;CPY #nnnn
cpy #<.op
.byte >.op
.endm
eorw .macro .op ;EOR #nnnn
eor #<.op
.byte >.op
.endm
ldaw .macro .op ;LDA #nnnn
lda #<.op
.byte >.op
.endm
ldxw .macro .op ;LDX #nnnn
ldx #<.op
.byte >.op
.endm
ldyw .macro .op ;LDY #nnnn
ldy #<.op
.byte >.op
.endm
oraw .macro .op ;ORA #nnnn
ora #<.op
.byte >.op
.endm
sbcw .macro .op ;SBC #nnnn
sbc #<.op
.byte >.op
.endm
; register size macros...
; These macros are a convenient way to change the MPU's register sizes
; without having to remember the correct bit pattern for the REP & SEP
; instructions.
longa .macro ;16 bit accumulator & memory
rep $20
.endm
longr .macro ;16 bit all registers
rep $30
.endm
longx .macro ;16 bit index registers
rep $10
.endm
shorta .macro ;8 bit accumulator & memory
sep $20
.endm
shortr .macro ;8 bit all registers
sep $30
.endm
shortx .macro ;8 bit index registers
sep $10
.endm
; INT instruction - assembles as BRK followed by operand...
int .macro .op ;INT <intnum>
.if .op > $ff
.error "INTERRUPT NUMBER MUST BE $00 - $FF"
.endif
.byte $00,.op
.endm
.endif
.end-----
I updated the macro listing to fix a typo that was recently discovered.
--BDD
Last edited by BigDumbDinosaur on Thu Oct 06, 2011 4:22 am, edited 1 time in total.
falcon5252
Tony ... I'm just going by what Lee Recommended.. And I just downloaded it 15 min ago so I have no Idea what it is capable of.. Besides I don't see allot of alternatives that will run in windows.. So are there any windows based Compilers, And which do you recommend... I have a Prom Programmer but it's a piece if junk, But it let me extract the binary from the Robots Prom... Just hoping it will program the Fash Mem I bought to replace the original Prom...
Wheres a good place to buy a 4mhz or faster 65802 & 65C02P4 at a decent price that takes Paypal.. I know its not ebay 65C02P4 listed at $79
Do the 65802's default to 8 bit mode or do they need a command in the Prom reset vector to set the Mode..
Lee... How are they creating the stepper step and speed timing routines, And would it be a major or minor change to get it to run on a faster processor.. With a clock divider circuit for slow I/O including ACIA and VIA all timed events there should run at the same speed.. I think therefor I could be wrong...
leeeeee
- In Memoriam
Lee.
Nightmaretony
- In Memoriam
leeeeee
- In Memoriam
Ok. Definately not abandonware. The current page for Michal's simulator is http://exifpro.com/utils.html
Lee.
Lee.
falcon5252
I found a SBC 65C02P2 $30 just bought it... Main board from a arcade game..16k ram, 16k rom, 2 via, 6 x 8 bit latched outputs 2 relays and 10 unpopulated & un-socketed places for what appears to be more latches or buss drivers routed to dip & sip headers, Plus 2 serial port drivers but no ACIA .. Looks like it will bee a good project board
ElEctric_EyE
Lee.
Lee.
This new version has a help file in addition to the doc's...
I've actually become more interested the abilities of the disassembler part of MK's work, when one opens a .bin/binary file in order to analyze.
- BigDumbDinosaur
leeeeee wrote:
I've found a current email address for Michal and have asked him for permission, I'm just waiting on a reply.
As it's written in Microsoft Visual C a lot of it is pretty impenetrable. I've asked about this before and the consensus seemed to be it would be easier to write a new program than port this one to C++.
Lee.
Lee.
- BigDumbDinosaur
falcon5252 wrote:
Tony ... I'm just going by what Lee Recommended.. And I just downloaded it 15 min ago so I have no Idea what it is capable of.. Besides I don't see allot of alternatives that will run in windows.. So are there any windows based Compilers...
The 65C02 can be purchased directly from WDC or from other sources. The stock part is rated at 14 MHz, but can be run as slowly as you desire.
- GARTHWILSON
- Forum Moderator
If you want 16-bit functionality you should consider the 65C815
You can easily make the same board take either a 65c02 or an '816, using a few jumpers to make the choice. It is not necessary to latch, decode, or use the 816's high address byte to take advantage of many of the 816's strengths over the '02. You can totally ignore that bank byte if you're not interested in anything outside the first 64K bank. That's pretty much what the '802 does. I have one in a socket intended for the 65c02. I have one spare, but it's not for sale!
- BigDumbDinosaur
- BigDumbDinosaur
