Re: Vulcan-74 - A 6502 Powered Retro MegaProject
Posted: Fri Sep 25, 2020 2:23 pm
I managed to cut most of the steel for the cabinet as well as the square tube frame for the front of the monitor. The goal is to have the cabinet sitting in my lab over winter to be worked on. Since I weld outdoors, time is running out as the weather creeps towards the negatives at night around here now.
Yeah, I do everything the "hard way". Hand held grinder to cut sheet, welded outdoors on wobbly sawhorses using a basic AC buzz box. Not sure why, but it just makes the end result so much more rewarding!
To answer a few questions....
- CJS:Yes, the massive board will be completely hand wired. I intend to take a 750 square inch piece of thin lexan and hand drill every single hole for all 500+ ICs then insert them and run point to point wiring on the underside and VCC + GND on the top. This keeps that "crazy dude" effect strong and allows viewing of the entire job due to the clear board. Also, when the board slides out from the case, it will be able to tilt up to 90 degrees for inspection or repair of the P2P wiring on the underside. I am not a fan of wire wrap.
- CJS:Also yes, the older design pushed out 400x300 VGA and I did attempt 640x480 with 90% success. After some time, I realized that doing VGA was not fully "retro" and it felt wrong. Another reason to switch to NTSC is because it is so much more difficult to generate with logic as compared to VGA, which is rudimentary. Hell, I can pump out a 5 ball Boing Demo on a 512 byte 8 pin micrco-controller using VGA, it's that easy! NTSC requires careful control of nanosecond phase delays and all sorts of timing magic, so to me it is much more fun and keeps to the idea of building a system that is 100% true to the era. I am also stretching the boundaries with NTSC as well, pushing out 360x230 overscan with 8192 colors, twice what Amiga did back in the day. I have a system that will put out 256 shades of 32 colors, so no crazy "HAM" modes either! I intend to test the circuit very soon, it is mostly built on the breadboard now.
-TTLWorks:Yes, I already have a steel sheet between the monitors as well as steel between the base of the monitors and the other circuitry. So basically, both monitors live in their own steel cabinets, with full screen venting on the rear side.
-TTLWorks:Yes again, my video drive only puts out one global sync signal, but splits into a set of dual video generators. The "IDE" monitor puts out 320x200 text with 256 colors and a C-64 like border, and the "GFX" monitor puts out 360x230 overscan with 8K colors. Both are driven from the same sync signal, which is mixed into the Luma output. I am using the seperate Luma+Chroma inputs on the rear of the 1702 monitors for best clarity. I know 320 horizontal pixels is pushing the limits of NTSC, but C-64 does it well, and Vulcan will do it too!
I am looking forward to the first snowfall so I can migrate into my Commodore Cave and continue this project. This year, I will have graphics being displayed and a lot of the cabinet work done, so there will be a lot more to show off.
Cheers!
Radical Brad
Cheers!
Radical Brad
