Page 5 of 5
Re: A simple 6502 computer (doesn't work though)
Posted: Thu Jul 04, 2019 6:00 pm
by jgroth
Clearly the correct operation of zero-page and the stack page is the most critical. Without them, a significant proportion of 6502 opcodes become useless. But I think we can now assume that the VIA and ROM are working correctly.
Your code is on my list to try out.
Posted: Fri Jul 05, 2019 9:38 am
by LIV2
If the RAM is known to be good in another system then that just leaves something like a bad/incorrect connection. if the circuit is configured as per the diagram it should be working
Posted: Fri Jul 05, 2019 5:35 pm
by Chromatix
Yes, I had that in mind when writing the test code. You'll notice that there's a write to the VIA between filling the RAM with test values and verifying those values, which should catch cases where the decode is incorrect.
Posted: Sat Jul 06, 2019 1:44 pm
by floobydust
Despite having a fair number of bypass caps on your prototyping breadboard, I would suggest placing a 0.1uF directly at the SRAM chip to pins 14 and 28. I would also note that there's other differences between your implementation and Garth's original schematic. On U3b, move pin 5 directly to +5V and also use the PHI2 out on the CPU to drive U3a pin 1 and the 65C22 clk line. All are simple changes.
Lastly, I would also look to meter all of the lines for the SRAM to ensure your don't have any intermittent or bad lines between the SRAM and the CPU.
Posted: Sat Aug 31, 2019 5:12 pm
by jgroth
So I finally found out what's wrong with the circuit. The quality of that breadboard was so bad that the VIA didn't get high enough voltage to register a one although I did measure it and it looked OK. When I changed the breadboards to Global Specialities ones everything just started to work. :P So moved on replacing the 74XX00 with an ATF22V10 GAL and that works just fine as well. So my next SBC will have a GAL as an address decoder instead of a Lattice MACH4A.
All's well that ends well.
BTW the old breadboards have been binned, any prototyping will hereinafter be done with GS breadboards.
Posted: Sat Aug 31, 2019 5:52 pm
by Chromatix
Ah, the joys of dynamic versus static behaviour. You have no idea how much I have to explain to people who *should* know better that transient behaviour sometimes matters more than the steady state.
Posted: Sun Sep 01, 2019 3:42 pm
jgroth wrote:
So moved on replacing the 74XX00 with an ATF22V10 GAL...
What did you use to program the ATF22V10?
Posted: Sun Sep 01, 2019 9:31 pm
by jgroth
I used an XGecu PRO TL866II plus, that is the original programmer and not a clone.
