I ran your Mandelbrot in Tachyon on the P2 as a quick test but even though it only takes about half a second to run, it doesn't look right
I can zoom in by 100 instead and it does zoom (takes about a second) so that part works correctly. BTW, this code is one of the simple benchmark tests I will run on the 65816/37702 chips when I convert Tachyon.
I haven't really looked into what is going wrong. Any ideas?
Parallax P2 *TAQOZ* Extensible Firmware V2.0 'CHIP' 125MHz 190212-1700
TAQOZ# 300 P2MHZ --- ok
$0004_0627 Parallax P2 *TAQOZ* Extensible Firmware V2.0 'CHIP' 300MHz 190212-1700
52 ---
53 lines and 274 bytes compiled, with 0 errors in 72ms ok
TAQOZ# GO ---
..!,.' .,,!~, '~..~, .,.,'. WWWWWW<:^!~''',,,,,,,...................
.'...^ .!,,.! .,.!,, .,',,, .WWWWWW[^!~''',,,,,,....................
'.,,'. ,...'. ~.~... !...., .WWWWWWW;!~''',,,,,,....................
,,..,; '.~!., .''~.! .,':., .WWWWWWW:!~''',,,,,,....................
'.~,!. ~....! .,,'.' .~',.[ .WWWWWWW~~;''',,,,,,....................
.'...~ .'..,. ,..... ,.~,., ..WWWWW~!;~''',,,,,,....................
..^:.. '...,! .~!'., .,..,. ..,WWW'''~~'',,,,,,,....................
.,,., ,,'.. !,.'. ~''.': ,~....,,, ok
TAQOZ#
