Announce: Acheron VM
- barrym95838
Re: Announce: Acheron VM
Garth and Bruce are quite familiar with the fig-FORTH bug, and Garth helped me to recognize my "17th bit" problem here with some failing test cases. Is that the type of data you're seeking?
Hi White Flame,
Your presentation popped up in my youtube frontpage, so I just watched it last night. I have to say, very nice work! Some very smart and clever choices, and I like that you acknowledged the historical architectures that used some of the ideas (even if you learned of them after the fact, and so came up with them independently).
Have you investigated how well the VM might be applied to a 'C' compiler?
richard.broadhurst
I enjoyed the presentation; I was expecting a VM for a "known" 16 bit processor and was very pleasantly surprised.
I was also wondering about it being the target of a compiler, as I have tried a few times to write a Cish compiler for 6502, but always end up half inventing a new 6502ish language instead!
I'm from a (VIC-20 then) BBC Micro background which is 6502, unlike its later version the Master which is 65c02.
White Flame
The parameter passing/return scheme isn't really compatible with C's stack notions, which is the biggest issue. But a "mostly C-ish" language should be able to target it, using C syntax expressions and pointer operations, but a different function parameter model.
While a higher level language is obviously beneficial, the ability to create custom instructions is a good part of what keeps Acheron code fast, and that's more a low-level thing. Using an existing language like C would always require the system to do a bunch of extra stuff to maintain the C environment, which is always going to be a drawback on the 6502. I still haven't settled on what an optimal language on top of Acheron would be yet.
wanted to do some work with the ancheron VM...started with the basics...
makefile is given which uses ca65
but I am on windows.
gnu make installed.
cc65 installed.
I run make which would execute:
rm -r obj
rm -r bin
mkdir obj
mkdir bin
ca65 -l obj/acheron.o.lst src/acheron.asm -g -o obj/acheron.o -I src
ld65 -Ln bin/labels -C src/acheron.cfg -m obj/map -o bin/acheron.prg obj/acheron.o
# Display size information for each component. Only the above line is necessary for the build.
grep '^[^_]* Size=' obj/map
grep '\._size__' bin/labels
dir bin/acheron.prg
but at the ca65 step I get this:
rm -r obj
RemoveDirectory(C:\retro\6502\acheronvm-master\acheronvm-master\obj)
rm -r bin
RemoveDirectory(C:\retro\6502\acheronvm-master\acheronvm-master\bin)
mkdir obj
mkdir bin
src/acheron.asm:38: Error: String constant expected
115 / 128 opcodes defined
make: *** [obj/acheron.o] Error 1
it's having a issue with this macro:
.macro reportSize label, filename
label:
.include filename
.ident (.concat("_size__", .string(label))) = * - name
.export .ident (.concat("_size__", .string(label)))
.endmacro
specifically the .include filename
Any ideas?
gnu make installed.
cc65 installed.
rm -r obj
rm -r bin
mkdir obj
mkdir bin
dir bin/acheron.prg
rm -r obj
rm -r bin
mkdir obj
mkdir bin
label:
.include filename
.endmacro
Any ideas?
