Page 38 of 62
Re: Vulcan-74 - A 6502 Compatible Retro MegaProject
Posted: Sat Mar 11, 2017 8:17 pm
It puts you in a time, and also in a tribe...
Posted: Sat Mar 11, 2017 8:21 pm
by Oneironaut
Since I am hosting a nasty flu, some quiet time in front of the wood-stove with 25 SRAMs has been very relaxing.
I actually made some progress, but the task does seem monumental!
First, the middle pins are bent outwards (this is VCC and GND on both sides)...
Then, I add the decoupling caps on each side and bend them towards the IC...
I then add solder to each of the socket pins and onto the IC pins.
So far, I have all 25 SRAMs on their sockets...
Now the task of cutting 900 tiny wires to connect all the pins to the DIP sockets!
Brad
Posted: Sat Mar 11, 2017 8:29 pm
by sjgray
Wow, that's dedication. If it was me I'd be designing an adapter pcb... cutting and stripping that many wires would not be my most favorite task... I recently designed and made a little 40-pin breakout pcb. They ended up costing about $1 each for a run of 30, which for me would be worth it just to avoid the hassle
http://www.6502.org/users/sjgray/projec ... index.html
Anyway, keep up the great job! I find it fascinating.
Steve
Posted: Sat Mar 11, 2017 8:32 pm
I'm still amazed the pins don't break off. I'd be fearful of trying that on a five dollar SRAM.
Posted: Sat Mar 11, 2017 9:48 pm
by Oneironaut
Thanks! The Visual memory Display is a cool project.
I have never broken an SRAM yet. Well, at least not physically.
I reversed VCC on one breadboard row, and toasted 2 of them a while back.
There is something fun about doing things the hard way.
I am cutting the wires now, and have it down to assembly line speed!
Brad
Posted: Sat Mar 11, 2017 9:50 pm
Or you could use three of my 4Mx8 5V 10ns SRAM modules (each one using eight Cypress CY7C1049D-10VXI 512Kx8 5V SRAMs, four
on each side), now available with .300" row spacing.
Posted: Sat Mar 11, 2017 10:09 pm
Are you referring to the SRAM packages?
Posted: Sat Mar 11, 2017 11:01 pm
No, the module itself. I was reluctant to do it, but due to demand, it's now available (for $10 extra, since it's more work for me). The picture shows the module pins with .300" row spacing. The SRAM ICs are still SOJ.
Posted: Sat Mar 11, 2017 11:58 pm
by Oneironaut
Those modules would certainly make my job easier!
But since Vulcan-74 is my "Hot Rod", I must hand craft it 100% myself.
Now that the Cypress parts are out of production, you can use this one...
http://www.digikey.com/product-detail/e ... ND/1831407
These are the ones I am soldering down right now.
Actually just finished the first one, and it has passed the video test.
Now that I have all the wires cut, it looks like I can complete one SRAM every half hour or so.
If my flu hangs on, I may just go at it all day tomorrow. Only 12 more man-hours of soldering!
Brad
Posted: Sun Mar 12, 2017 1:24 am
Thanks. I see Cypress is still making the 1049, but the D after it is replaced with GN. It's apparently only a die change. With a quick look, I didn't see any differences that would concern the user. They certainly didn't make any of the improvements I would have liked. I still have quite a lot of the D version left though, which I got at probably less than half what the hobbyist has to pay, because of the quantity I got.
Posted: Sun Mar 12, 2017 1:37 am
by Oneironaut
Isn't the Cypress GN only available as a TSOP package now?
I almost went that way, and considered making TSOP to DIP adapter PCBs, but it seemed like the easy way out!
3 Working SRAMs mounted now. It's very relaxing work, and a great way to spend a flu weekend.
Brad
Posted: Sun Mar 12, 2017 1:49 am
No, see the lower half of p.14 of the data sheet at
http://www.cypress.com/file/221601/download (.pdf). SOJ-36.
The Cypress search results summary page showing the three types of 1049 is at
http://www.cypress.com/search/all/CY7C1 ... 3Aproducts .
Posted: Sun Mar 12, 2017 2:35 am
by Oneironaut
I wonder what the market for SOJ packages would still be these days?
Last time I seen SOJ sockets was on ISA video cards and 386/486 mainboards as cache RAM.
Posted: Sun Mar 12, 2017 7:55 am
- 4.5 V to 5.5 V VCC = Min, IOH = –0.1mA VCC – 0.5
I noticed that in the GN data sheet.
Posted: Sun Mar 12, 2017 8:54 am
True, and that's good; unfortunately with any load (like while charging bus capacitance), you get Vcc = Min, I
OH = –4.0 mA, I
OH(min)=2.4V which will have the effect of slower response by devices that need it pulled up higher. It will take more time to finish bringing the line to a valid CMOS logic-high, since the pull-up current falls way off after the half-way point in the transition. (It won't be a problem the the '816 where you use a 74ACT245 bus transceiver or equivalent anyway though.)
