Re: screen editor design
Posted: Tue Jun 24, 2014 4:00 pm
Here's the code for building the docs for PETTIL from a json file. The json file has title, tags, and text for each tiddler (say it three times fast). That's it. I had to remove one line from the tiddlywiki.info file (the tiddlyweb plugin) to get it hostable from a file section.
echo . . . . Building docs/tiddlypettil.html
mkdir -p ./build/tiddlypettil/tiddlers
cp ./docs/statictiddlers/tiddlywiki.info ./build/tiddlypettil/
cp ./docs/statictiddlers/*.tid ./build/tiddlypettil/tiddlers/
cd ./build/tiddlypettil/
tiddlywiki --load ../pettil.json >/dev/null
tiddlywiki --rendertiddler $:/core/save/all tiddlypettil.html text/plain >/dev/null
I just rewrote the outer interpreter/compiler shell and am debugging that. I had been using Scott Ballantyne's outer interpret from Blazin' Forth, but there was a lot of weird stuff. His has a word RUN in it? His code for ']' had the compiler while the code for 'INTERPRET' didn't, which seemed like a good idea until I tried compiling a multi-line colon definition and it doesn't compile anything after the first line of input.
I am also pondering <BUILDS DOES> , specifically
http://www.vintagecomputer.net/fjkraan/ ... _00-09.pdf and this http://www.vintagecomputer.net/fjkraan/ ... -index.pdf . The second paper is all about <BUILDS DOES>
a) Why was <BUILDS renamed into CREATE ?
b) Given a two-dictionary model (compiler/interpreter/editor/assembler/symbols all in a transient dictionary, headless core dictionary at bottom of memory) what's a good way to set up <BUILDS ... DOES> such that compiler time code disappears along with the transient dictionary, while child-word runtime behavior goes in the core?
c) Who ever uses <BUILDS DOES> for anything?
d) Does <BUILDS have to be the very first thing in the definition of the builder? It was in every example I could find. Then it could be coded as (rewinding the dictionary pointer and starting the definition's CFA over)
LATEST NAME> DP ! 'dodoes CFA,e) If I'm calling it <BUILDS (not CREATE), and it's no longer in the standard, can I play fast and loose with how it operates?
more on e)
I wanted a word ?: to work like the ternary operator in Ruby/C/Java.
a = true ? 'a' : 'b' #=> "a"
b = false ? 'a' : 'b' #=> "b"
Usage like
( args flag ) ?: AFFIRMATIVE NOWAY MORECODECode: Select all
( args flag ) IF AFFIRMATIVE ELSE NOWAY THEN MORECODECode: Select all
: ?: ( == ) ( flag -- )
<BUILDS ['] , ['] , DOES> 0= -2 * + @ EXECUTE ( somehow move IP beyond both words ) ; IMMEDIATEI want
['] , ['] ,Code: Select all
0= -2 * + @ EXECUTE ;This would not work if <BUILDS performs a CREATE operation. There would be a JSR DOCREATE immediately following ?: in the core, and a new symbol table entry for TRUEWORD. The corollary to this statement is that words using <BUILDS need to perform their own CREATE. That's where I play with the conventional meaning of <BUILDS
: CONSTANT <BUILDS CREATE , DOES> @ ;
