Page 36 of 41
Posted: Tue Jul 09, 2013 6:46 pm
by ElEctric_EyE
Thanks Arlet, but some code now present on
Wikipedia has led me to the same line of thinking as the Line generator I developed which has worked very well. For now I'll forego the math tables I was planning on pursuing.
Although I will need ellipses, starting with a successful Verilog circle algorithm will hopefully lead me in the right direction for the creation of ellipses.
I've never seen the code so clearly stated from the Wiki before the last couple days, or maybe I was in the wrong frame of mind (I doubt it):
public static void DrawCircle(int x0, int y0, int radius)
int x = radius, y = 0;
int radiusError = 1-x;
while(x >= y)
DrawPixel(x + x0, y + y0);
DrawPixel(y + x0, x + y0);
DrawPixel(-x + x0, y + y0);
DrawPixel(-y + x0, x + y0);
DrawPixel(-x + x0, -y + y0);
DrawPixel(-y + x0, -x + y0);
DrawPixel(x + x0, -y + y0);
DrawPixel(y + x0, -x + y0);
y++;
if(radiusError<0)
radiusError+=2*y+1;
else
x--;
radiusError+=2*(y-x+1);
I'm thinking, after converting to Verilog, that this circle portion will add maybe 10 more states to the LineGen (which will be renamed to PlotGen). This module will act in a similar manner, in that 3 memory locations (blockRAM) will be written for XCenter and YCenter, and as soon as Radius register has been written to the plotting begins.
Ok, I'm off to write some code.
Also
this site deserves mention.
Posted: Wed Jul 10, 2013 1:55 pm
by ElEctric_EyE
Success!
Maybe a register is needed to count the pixels so the cpu can tell me exactly how big of a blockRAM is needed. 2xpixR would just be an approximation.
Posted: Wed Jul 10, 2013 3:33 pm
by ElEctric_EyE
Forgot the '2*' in
Now it is round, also I adjusted the HSize on the monitor to make up for the 1024x1024, non 4:3 ratio. Not sure why the cube on the right appears lighter on color, will have to investigate that.
Posted: Wed Jul 10, 2013 4:59 pm
by ElEctric_EyE
Fixed now. Was a delay problem I fixed by shifting the SyncRAM clock and videDAC clock by 315deg.
Now the software sends line coordinates to plot the cube in hardware, sends 3 coordinates to draw the circle in hardware, and copy/pastes a section in software.
The points you see at the very top of the circle and the very left of the circle are the result of removing the multiplication in the algorithm. I put the multiply back.
Now to continue marching towards ellipses.
Posted: Wed Jul 10, 2013 9:50 pm
by ElEctric_EyE
After some more testing, I am suspecting I have an issue that has been around since the beginning of the project.
The pixels are too thick.
It is deceiving because a diagonal line seems smooth as it should be @1024x1024 resolution.
I suspect this because once in awhile during previous testing, erroneous pixels would be present. These pixels would be very small, maybe 1/4 size, hard to tell...
I had attributed the pixel size difference to brightness/color of the pixel, or maybe a fuzzy focus of the monitor.
Now, I don't think this is the case, especially since more testing has been successfully concluded.
My apologies to 8bit, as I used his circle routine and I thought it was the software double plotting. I'm pretty certain it is my hardware.
Posted: Fri Jul 12, 2013 1:50 am
by ElEctric_EyE
...I'm pretty certain it is my hardware.
Idiot! The SyncRAM interface module and cpu/blockrom/blockram were all running at 1/2 speed of the videoDAC and SyncRAM clocks, in order to get the read data correctly from the SyncRAM. Of course it's going to get 2 data, also write 2 data per WE pulse from the cpu...
I am back to running the entire system @80MHz pixel clock, it passes synthesis.
As in the past PlotGen module & CPU writing is good . Cpu reading is not correct yet.
EDIT: BTW, the entire system running @25MHz pixel clk 640x480 is yielding the same results. This is actually encouraging and tells me my Verilog bidirectional interface to the SyncRAM is wrong. I will focus on this interface on the next two days. Need to do some more research on bidirectional Verilog.
Posted: Sun Jul 14, 2013 1:58 pm
by ElEctric_EyE
This is a pic taken from the CY7C1463 2Mx18 SyncRAM datasheet:
It looks like everything is timed on the negative edge of the clock. All the code I've written is timed on the posedge.
Is this going to be a problem? or maybe this is why I've seemed to have some success phase shifting the clock by some amounts?
Posted: Sun Jul 14, 2013 2:14 pm
by ElEctric_EyE
I think I may have answered my own question.
Finally reads from video memory by the cpu are working now
when everything is clocked at the same pixel clock @25MHz!
First to explain my usage of clocks inside the FPGA. I use 3 separate taps off of an internal PLL for flexibility. The clock signal going to the SyncRAM is phase shifted 90deg:
PLL_BASE
#(.BANDWIDTH ("OPTIMIZED"),
.CLK_FEEDBACK ("CLKFBOUT"),
.COMPENSATION ("SYSTEM_SYNCHRONOUS"),
.DIVCLK_DIVIDE (2), //100MHz/2=50MHz*14=700MHz/10=70MHz for 1024x768
.CLKFBOUT_MULT (14), //100MHz/2=50MHz*14=700MHz/28=25MHz for 640x480
.CLKFBOUT_PHASE (0.000), //100MHz/2=50MHz*18=900MHz/60=15MHz for 320x200
.CLKOUT0_DIVIDE (28), //video pixel clk
.CLKOUT0_PHASE (0.000),
.CLKOUT0_DUTY_CYCLE (0.500),
.CLKOUT1_DIVIDE (28), //cpu&system clk
.CLKOUT1_PHASE (0.000),
.CLKOUT1_DUTY_CYCLE (0.500),
.CLKOUT2_DIVIDE (28), //SyncRAM clk
.CLKOUT2_PHASE (90.000),
.CLKOUT2_DUTY_CYCLE (0.500),
.CLKIN_PERIOD (10.0),
.REF_JITTER (0.010))
CLK0 goes to the HVSync module and offchip to the VideoDAC
CLK1 goes to the cpu, reset logic, BRAMs.
CLK2 goes offchip to the SyncRAM.
The bit of software that copies/pastes a chunk (76x76pixel cube) of video memory starting at (300,375) to (400,375):
LDA #300
STA SCRLO ;x position
LDA #375
STA SCRHI ;y position
LDX #76 ;use X reg for easy test for end of y position
CHSH2 LDY #$00
LDWi $0064 ;LDW #100
CHSH LDA (SCRLO),Y
STAiw (SCRLO),W ;STA (SCRLO),W
INW
INY
CPY #76
BNE CHSH
INC SCRHI
DEX
BNE CHSH2
Posted: Sun Jul 14, 2013 2:25 pm
by ElEctric_EyE
I almost forgot to mention I had used the RDY to halt the cpu in this attempt in my SRAMif module. I will take it out and see if it still works.
`timescale 1ns / 1ps
module SRAMif( input clk,
input [15:0] cpuDO,
input vramCS, //cpu is reading/writing to videoRAM
input lineCS, //lineGen is writing to videoRAM
input cpuWE,
input RAMWE, //LineGen is drawing
inout [15:0] SRD,
input [15:0] QACCout, //pixel color from cpu
input [9:0] X, //LSB of LineGen address
input [9:0] Y, //MSB
input [20:0] Vaddr, //pixel clock address from HVSync Generator
input [31:0] cpuAB,
output [20:0] SRaddr,
output reg [15:0] SRDO, //to cpu
output SRWEn,
input CB0, //Control Bit 0 from cpu to control page 0 or 1, when page flipping
input CB1, //Control Bit 1 from cpu to control page flipping or scrolling
input CB2, //Control Bit 2 scrolling horizontal or vertical
output reg RDY = 1 //RDY = 0 halts cpu
reg SRWEn2;
reg [15:0] SRDI;
always @(posedge clk) begin
SRWEn2 <= SRWEn;
if (RAMWE && !vramCS) begin //hardware module selected
SRDO <= 16'h0000;
SRDI <= QACCout;
RDY <= 1;
end
if (RAMWE && (vramCS && cpuWE)) begin //collision, if both selected favor hardware module
SRDO <= 16'h0000;
SRDI <= QACCout;
RDY <= 1;
end
if (RAMWE && (vramCS && !cpuWE)) begin //collision, favor cpu read from video
SRDO <= SRD;
SRDI <= 16'hZZZZ;
RDY <= 0;
end
if (!RAMWE && (vramCS && cpuWE)) begin //cpu write to video
SRDO <= 16'h0000;
SRDI <= cpuDO;
RDY <= 1;
end
if (!RAMWE && (vramCS && !cpuWE)) begin //cpu read from video
SRDO <= SRD;
SRDI <= 16'hZZZZ;
RDY <= 0;
end
if (!RAMWE && !vramCS) begin //nothing selected
SRDO <= 16'h0000;
SRDI <= 16'hZZZZ;
RDY <= 1;
end
end
reg [20:0] cpuABopt;
always @* //optimize the videoRAM address for plotting (X,Y) in the (LSB,MSB) for indirect indexed
begin //CB1 = 0, page flipping
cpuABopt [20] <= CB0; //bank bit
cpuABopt [19:10] <= cpuAB [31:16]; //Y[9:0]
cpuABopt [9:0] <= cpuAB [15:0]; //X[9:0]
end
assign SRWEn = !(RAMWE || (vramCS && cpuWE));
assign SRaddr = RAMWE ? { CB0, Y, X } : vramCS ? cpuABopt : Vaddr;
assign SRD = SRWEn2 ? 16'hZZZZ : SRDI; //I/O MUX'd latch to SyncRAM databus. High 'Z' during a read
endmodule
Posted: Sun Jul 14, 2013 2:33 pm
by ElEctric_EyE
Using the RDY to halt the cpu is not necessary, at 25MHz anyway. Will attempt to ramp speeds up now...
Posted: Sun Jul 14, 2013 3:17 pm
by Arlet
It's based on the positive edge, but you have to respect the setup/hold times. If there's a non-zero setup time, the clock must be delayed wrt to the signals.
Posted: Sun Jul 14, 2013 3:42 pm
by ElEctric_EyE
Thanks for responding. Told you I struggle with timing diag's, but I see now that dotted line is the clue it is posedge clocked...
I've done many tests now changing the SyncRAM clock phase, i.e. delay, and I think it's going to be real tight @70MHz clock. Tight being a <15deg difference from a working to a non-working design, if it works at all. 70MHz = 14ns cycle time, so 15deg is (360deg/15deg = 24) (14ns/24 = .5ns) .5ns shift.
If it takes 2 cycles for 1 transaction, that cuts the effective 133MHz max speed of the SyncRAM down to 66.5MHz which is <70MHz. So it's probably not going to work. Am I thinking clearly on this matter?
EDIT: There are very definitive, reliable changes in observed behavior when changing the delay of the clock by only .5ns(15deg). I've almost covered then entire 360deg range, in 15deg intervals, starting at 360. Right around 90deg is when the most difference in changes are observed. No luck. I lowered the pixel clock to 64.3MHz on a hunch, still a good picture with 48.5kHz HSync and 60.3Hz VSync. Going in for the kill...
Posted: Sun Jul 14, 2013 8:16 pm
by ElEctric_EyE
...it takes 2 cycles for 1 transaction, that cuts the effective 133MHz max speed of the SyncRAM down to 66.5MHz...
This seems to be the case. Taking the delay of the FPGA and other factors into consideration now, the max speed seems to be in the neighborhood of 45MHz. All delays totalled must be greater than 20ns. Sort of disappointing, I couldn't find the sweet spot for the delay running @50MHz, although I may try again seeing the size of this window and the actual delay that seems to work.
An interesting thing about SyncRAM: Nothing random if the timing is off, like asynchronous RAM. The pixels will be in the wrong place, but is consistent.
So at 45MHz (22.2ns period) each degree of delay for the SyncRAM clock is 22.2ns/360=.062ns. I think I calculated the degree of delay incorrectly in the above post. Here are my observations @45MHz, 800x600 resolution, read-write-read:
156-157degrees: 1 pixel misplaced
153-155degrees: looks like 1/2pixel aberrations. barely noticeable, but no misplaced pixels
149-152degrees: looks best
148degrees: misplaced pixels everywhere
A couple other considerations: drive = 4 and slew = slow for the Spartan 6.
A test I would like to do next is to copy a small program from the BRAM and paste it in the video memory and jump to it and see if it works correctly.
Posted: Sun Jul 14, 2013 9:38 pm
by ElEctric_EyE
Drive of 4mA is too low for this SyncRAM. Just changing the screen color to black from blue resulted in alot of bad pixels.
Increasing drive to 6mA cleared 99% of them. More testing is needed to find the most efficient drive strength.
EDIT: Observations are: Changing slew rate from slow to fast had no effect. Changing drive strength from 4mA to 6mA had a large effect, as mentioned. Increasing drive strength from 6mA to either 8mA or 12mA had negligible effect. So, I continue forward with 6mA and more testing.
Posted: Sun Jul 14, 2013 10:16 pm
by ElEctric_EyE
Another problem: I changed the FPGA output pins driving the videoDAC and monitor signals from 6mA to 12mA with no change. Maybe I need the impedance matching resistors now? The yellow is disappearing into the white. Should be green cubes on white background.
I'm done for today, thoroughly worn out!
