Page 1 of 2
Posted: Fri Mar 03, 2006 7:40 am
kc5tja wrote:
In fact, the 6502 and 65816 architectures are finding themselves in an increasing number of embedded environments, often times displacing the ARM processor!
Last year, I wrote to Bill Mensch asking for good reasons to use the 65-family processors, for an article.  One of the things he said was,
    • The 65xx architecture is sold in hundreds of millions of chips per year, and the volume is growing.  We now find engineers porting applications that might have first been market-tested on PCs or ARM processors and finding the 65xx economy (both business and silicon) attractive and well worth the effort to change to the 65xx.
(emphasis added.)
The 65c02 is indeed going into new designs, but in microcontrollers, not separate microprocessors.  These go into all kinds of consumer items like camcorders, and into automotive applications, as well as even life-support equipment.  Most of WDC's business seems to be in licensing the IP, not selling parts.  They do have a couple of off-the-shelf microcontrollers, the 65134 and 65265, but these off-the-shelf ones don't come in a lot of versions like the PICs do.  Unfortunately they're also not programmable on the workbench like the PICs are, but it sounds like that may be changing.  The microcontrollers being made today with 65c02 cores in them and being sold at the rate of hundreds of millions per year are mostly custom ICs.
Like Icy, I have designed Microchip PICs into several products too, and not because I like them—actually I hate the decrepit RISC processor at their heart—but because they're available in so many versions, from lots of stocking distributors, they're easy to program on the workbench, some even have complete onboard fixed-frequency clock oscillators, etc..  A 20MHz 65c02 can do a job a lot faster than a 20MHz PIC16 though, if the PIC can do it at all.  PICs are good for tiny jobs, but otherwise have severe limitations.
I have a lot of code comparisons between 65c02 and PIC16 written down, but in looking at them again I can see why I haven't just taken 15 minutes to compile them clearly for this website.  There's too much there.  I will give a few examples here, and just say that there's more where that came from.
Take the example of a single-byte table look-up, where table might be anywhere in ROM:
6502: 4-5 clocks        LDA address,X
PIC:  48 clocks, to do what the 6502 does in 4 or 5 clocks!  (This code is
from slide 234 of the seminar, and the same as what's in AN556 Example 5.)
       ORG    0x10          ; Page 0
       MOVLW  LOW (Table)   ; Low byte of address     4
       ADDWF  offset,F      ; added to offset.        4
       MOVLW  HIGH (Table)  ; High 5 bits of address  4
       BTFSC  STATUS, C	  ;   Page crossed?         4
       ADDLW  1             ; Yes...Inc high address  4
       MOVWF  PCLATH        ; Load high address       4
       MOVF   offset,W                                4
       CALL   Table                                   8
       ORG	 H'800'        ; page 1
Table:
       ADDWF  PCL,F         ; Calc table offset       4
       RETLW  'A'                                     8
       RETLW  'B'
       RETLW  'C'
       RETLW  'D'
       etc.
Edit, 1/7/13:  I just learned of another PIC stinker:  If an interrupt hits immediately before the PCL-modifying instruction above, it will misbehave after the return from interrupt, and you'll get the RETLW 'A' even if you wanted a different one; so you have to disable interrupts for the table look-up further lengthening the code and slowing things down and causing a longer interrupt latency.  This is from AN556, bottom of page 3.
The PIC has to use different code if the table is in RAM.  It can't use the same code for ROM and RAM like the 6502 can.  Furthermore, if you index past the end of the table in ROM, you won't just get bad data—you'll crash.
Or consider the disabling of interrupts.  The PIC's problem here is that if an interrupt hits during the instruction to clear the Global Interrupt Enable (GIE) bit, the interrupt will be taken, and if the ISR saves the status, the old status will be restored at the end, along with the GIE bit set.  So, after clearing that bit, you have to check to see if it's really clear, and go back to try again if it's not.
6502:  SEI                 ; 2 clocks to disable interrupts reliably.
PIC:                       ; This loop is from the caveat on
loop:  BCF    INTCON,GIE   ; P.2-767 of '95-'96 data book.
       BTFSC  INTCON,GIE   ; 12 clocks minimum, 28 clocks if you
       GOTO   loop         ; have to loop back even once.
On the 6502, no jump or branch, conditional or otherwise (excluding indirects and subroutine calls), ever takes more than 4 clocks, and they usually take 3.  On the PIC however, GOTOs take 8 clocks, but another 8 clocks are required for MOVLW xx and MOVWF PCLATH for longer jumps.  If W must be saved with MOVWF and MOVF xx,W during the latter process, yet another 8 clocks are wasted.  This makes for a total of 24 clocks to do what the 6502 does in 3.
The PIC can't shift, so if you want to shift something, so you have to rotate and then AND-out the bits that should have ended up as 0s.  PIC also can't rotate in W (which is like the 6502's accumulator), so you might have to put the number in a variable.  For the following example, shift right 2 bit positions W (PIC) or A (6502):
PIC: 16 clocks			   6502: 4 clocks
MOVWF  TEMP_W	   4
RRF    TEMP_W,F    4		LSR	A	   2
RRF    TEMP_W,W    4		LSR	A	   2
ANDLW  B'00011111' 4
Edit, 2/4/12:  For a PIC16F project, I just got the code from Microchip's Embedded Control Handbook Update for dividing a 32-bit unsigned number by a 16-bit one, to get a 16-bit quotient and remainder.  It's 237 instructions (obviously I won't list it here), to do what the 6502 does in just 35!!!
The 6502's interrupt sequence is only 7 clocks, including pushing the status register.  Pushing the accumulator (like PIC's W) takes another 3.  The PIC's interrupt sequence is 8 clocks minimum, but if you want to save the status and W, you need about 28 clocks to do what the 6502 does in 11—and then the PIC's is not re-entrant.
PIC16F's 8-level return stack is not enough.  With good programming practices, I overflowed it, and the processor crashed when it unwound its way out.  The 6502's stack is 16 times as deep (128 2-byte addresses), which has proven to be many times what you need for most applications.
When I first started working with PICs, as I went through programming examples in the Microchip books, I wrote 65c02 code next to the PIC code to help myself understand it better.  I soon began to realize that the 65c02 code was consistently shorter and took about half as many clocks to execute as the PIC's code.
PIC's lack of stack access and its shallow stack depth are very limiting.
PIC's page- and bank-switching requirements waste memory and execution time, and make the code more unreadable.
PIC's instruction set is very limited.
PIC's Harvard architecture, separating program from data, makes it harder to work with.
PIC cannot do an indirect or indirect indexed GOTO or CALL.
PIC has no address modes at all with indexing.
PIC's backward subtraction (F-W, instead of W-F) usually lengthens the code, and is quite confusing.
Since, as Icy said, the PIC's logic is backwards and confusing, I start my PIC source code with macro definitions named after 6502 mnemonics to make things more clear, like BEQ.
Edit 12/7/13:  Admittedly PIC16F1's and PIC18's have come in to fix a few of the PIC16 problems above, now many years later.  It took Microchip many years to do this, and what they have is still rather mickey-mouse compared to the 6502.
The 65c02 lends itself to more intuitive programming.  Howard Speegle, the president of Diva Automation, Inc., says he finds it easier to envision a solution with the 65c02 than with the others of the dozen processors he has used, and he can develop the application faster and with less bugs with the 65c02.
I understand one of WDC's licensees is running a 65c02 microprocessor inside a custom IC (ASIC) at 200MHz.  Certainly if the PIC can be so successful today with its comparatively lousy processor core, there is no reason to think the 65c02 has no future or even a present.
Posted: Sat Mar 04, 2006 3:19 am
by Icy
Yes, PIC's processor is lousy. 65x02 is wonderful. Programming 65x02 feels like vacation, you cannot get tired doing that. It is natural, logical, it doesn't give you headache.
So, why couldn't someone, like WDC, come up with a single chip microcontroller that is at par with PIC or Motorola? WDC's microcontrollers aren't microcontollers of today. WDC lives in past. Microcontroller of today is a one chip, and nothing else is needed to attach.
All of that core stuff will disappear in a few years. And, so will WDC, unfortunately. Unless they come up with something up to date. Who wants to tell them?
Posted: Sat Mar 04, 2006 3:51 am
by kc5tja
Both Garth and I have been regularly telling them.
However, they are reporting that sales are up (and this is evidenced by the fact that their website actually has content on it now!), so they are obviously doing something right, even if it isn't directly visible to us.
Posted: Sat Mar 04, 2006 8:41 am
We would all like an array of 6502-based µC's made available as standard products. I don't think WDC lives in the past at all; but again, their primary business as I understand it is not selling hardware, but licensing the intellectual property to other companies that do in fact make their own dedicated custom µC's with everything in one IC and the 6502 at the heart of that IC. I wish WDC would license their IP to Microchip. It would be nice if there were a widely available parallel line of PICs built around the 6502 instead of Microchip's little RISC. Everything would still be in one IC, as it is with the currently available PICs.
I suppose the nature of WDC's business and the lack of standard (as opposed to custom) parts is why it appears to most people that the 6502 got relegated to ancient history by industry's negligence to keep a good thing up to date. Actually the 6502's growth just took a less-visible path than the x86 did with desktop computing or Microchip did with standard-part microcontrollers. Surprisingly, more 6502's per year are being sold today than at any time in history. You probably own 6502's in modern consumer electronics products and didn't even know it.
I personally am convinced that what people get familiar with as hobbyists and students gets carried forward into their jobs later when they get into industry and favor the parts they're familiar with to design into their company's products, and I think that is why WDC would do well to support the little customers better. It seems that they are very slowly moving toward that. That's not to say a hobbyist who buys one IC for $5 has permission to take $100 of WDC's time now and then to get help troubleshooting something; but at least they've dropped the $100 minimum order requirement (which I didn't think was that bad anyway) and put their programming manual online instead of insisting that we pay $60 a copy, and they seem to be starting to look more favorably on this website as a supplier of ap notes and things they've been lacking. They're also starting to talk about flash-based µC's that can be programmed on the workbench.
Posted: Sat Mar 04, 2006 9:50 pm
by orac
Hi Everyone,
Remember... the ST7 from ST micro is a 6502 look alike. It IS a single chip device with Flash, RAM, and IO.
Note, I haven't actually used one of these yet.
Paul
Posted: Sat Mar 04, 2006 11:31 pm
by kc5tja
Isn't STMicro one of the licensees for WDC's IP?
Also, while I couldn't find any detailed documentation on the ST7, I did find some example code snippets, and its mnemonics are half-68000, half-Z80 (a very interesting combination to say the least). From what I've seen, it does not look anything at all like a 6502. Moreover, I have yet to see them use the Y index register.
Posted: Sun Mar 05, 2006 6:21 am
by leeeeee
http://www.st.com/stonline/products/lit ... m/4020.pdf
It's very like a 6502, accumulator, X an Y index registers, zero page addressing etc.
Of course there are differences, the decimal mode flag had been replaced by a Z80 like HalfCarry, the stack is smaller - only 64 bytes - and it isn't binary compatible, e.g. LDX #nn codes as $AE $nn not $A2 $nn as it does on the 6502.
Lee.
SOLUTION !!!!!!!
Posted: Mon Mar 06, 2006 3:09 am
by Icy
Hey, how about this: :idea:
This would be ideal situation for WDC. Just think of all that huge market suddenly open for them.
This could blow my mind. No more headaches programming crappy, hostile PIC's RISC!
Re: SOLUTION !!!!!!!
Posted: Mon Mar 06, 2006 3:20 am
by kc5tja
Although still not as convenient as a 6502, I do find AVR microcontrollers to be MUCH better than the PICs from a programming point of view.
Posted: Mon Mar 06, 2006 5:33 am
by 8BIT
I agree. My video project was my introduction to the AVR family. I found the opcodes to be very similar to the 65C02. The last 6 of the 32 gerneral purpose registers work as three - 16 bit index registers (X,Y,Z). These allow for easy access to SRAM and FLASH memories. The stack is only limited by the available SRAM. They also run at 16 MIPS which is faster than the 14MHz 65C02. The AVR's use dedicated IRQ vectors for a multitude of functions, making IRQ decoding simple. I have not experimented with multiple-IRQ handling, so cannot say they have better response than the 65C02. The biggest plus to me is the onboard I/O (SPI, UART, timers, etc). The biggest minus is the limited SRAM onboard. Some versions do support external SRAM, but access speed to this is cut in half.
My two cents... Daryl
Posted: Sun Mar 19, 2006 6:38 am
by Nightmaretony
Trying out other CPUs is a pain in the rear. Am deisnign a testing system for work, wanted a seperate sub computer to handle some switching. In the interest of time, wanted an off the shelf SBC with certain sets of IO and USB. Called WDC, no dice. And bummer, my fave person Ralph is no longer there :( Picked up an SBC using an 8051 with basic. The assembly is as you said, hostile on that unit. Basic is a tad strange format to one used to Applesoft. Had to sstruggle a bit with it.
Cant wait to get back to doing the pinball project. Got too many new projects, including a movie soundtrack....
Posted: Sun Mar 19, 2006 7:50 am
by kc5tja
What, if I may ask, is your set of requirements that you opted not to go with a 65xx solution? I'm curious, because it seems to me that something like the Kestrel-1 or the SBC-1/2 probably would have fit your needs except for a few key details. What are those key details?
Thanks.
Posted: Sun Mar 26, 2006 4:01 am
by Nightmaretony
RS232 communication with routines
basic or machine hooks, but the communication. Originally usb but opted out of it.
several i/o ports to work with
available finished and ready for action.
Already got this one based on the 8051, using basic for it. I still prefer 6502instead. Sigh. Little late now to not use it, already got thingtws going in there... refunding isnt an option since I already began modding into the board...
At least for the pinball and haunted house projects, it will remain 6502 all the way.
Posted: Sun Mar 26, 2006 4:08 am
by Nightmaretony
Actually, one other thing it will ened to do is IR command lines sending and recieving. If I cant get the other one to do it, I will switch it over pronto and go back to what I know and love best.
So what it would be:
RS232 i/o
8 or 16 i/o pins
the ability to recieve and send IR command sets such as RC5 or custom sets definable.
The trick was time, so I opted for the off the shelf. I dont know how it will do for the IR. If those iexist for 6502, let me get back to it :)
NOTHER fun project to keep me busy...
http://www.imdb.com/name/nm2158451/
Posted: Sun Mar 26, 2006 10:08 pm
by kc5tja
Nightmaretony wrote:
RS232 i/o
8 or 16 i/o pins
I remember one time reading about how someone was using a VIA chip for a UART. But their approach was quite unique! They used a timer to determine how long to keep the TXD line high or low. So, if you wanted to send 01001100 binary, and u is the bit duration, they'd first program the TXD line low, then tell the timer to expire after 2u. Then they'd simply EOR the TXD bit to toggle it, and tell the timer to expire after 2u again. Toggle, time, toggle, time, etc.
I'm sure that receiving was done a bit more traditionally, but I thought it was kind of interesting, especially since the baud rate was fully programmable within a certain range. However, I'm sure the baud rate wasn't all that great. But it should be able to handle at least 20kbps though, I'd think.
