It is currently Sun Nov 24, 2024 10:48 pm
PostPosted: Mon Feb 14, 2011 9:33 am
Hi Lee
thanks for the heads-up about the updated lib6502.
I had some ideas about projects...
A relatively simple project would be to fit Samuel's lib65816 into the same kind of wrapper as run6502 - I've done that, some time ago, but in a very rough and ready way, and I haven't published it. You could if you wished take my code as a starting point, but it might be better not to!
As it happens, there's a bug lurking in lib65816 (or possibly my run65816) which would be good to find and fix:
$ ./run65816 -B -l 0 bbc.img
loading ROM file bbc.img
WARP FACTOR 5
BBC Computer 16K
BASIC
>p
Mistake
>p
Mistake
Bad program
whereas lib6502 behaves itself:
$ ./run6502 -B -l 0 bbc.img
BBC Computer 32K
BASIC
>p
Mistake
>p
Mistake
A more advanced project would be to take lib6502 and put a GUI around it using a cross-platform toolkit like wxwidgets - that would give us a high performance cross-platform GUI for 6502 emulation. (It wouldn't match Michal Kowalski's program until it could be given an assembler, which would be another project.)
Note that I have a patch for run6502 which is needed for BBC emulation of BASIC errors:
*** 124,131 ****
        break;
      case 0x7E: /* acknowledge detection of escape condition */
!       return 0;  /* 2008-05-02  ed s this must trivially pass, for BASIC errrors */
!       return 1;  /* buggedly wrong in lib6502 1.0 and 1.1
        break;
      case 0x82: /* read machine higher order address */
--- 124,130 ----
        break;
!       return 1;
        break;
*** 505,511 ****
       0x8000 + mpu->memory,
       0x4000);
       n= 1;
-             n= 0; // was buggedly 1 in run6502 version 1.0 and 1.1
   argc -= n;
   argv += n;
--- 504,509 ----
Edit: added link target to new location of Kowalski's simulator
PostPosted: Mon Mar 07, 2011 8:40 pm
Hi Lee
There are a few alternatives to wxwidgets, that may be easier to use:
Qt
Gtk+
Cocoa/Cocotron
--- but the easiest solution might be to embed a simple web server in the simulator, and use a web browser to provide the GUI. (Ok, this solution might be "easiest" only for people who know HTTP/HTML/Javascript better than they known any of those GUI libraries :-)
It might be possible to use a65 (the assembler from cc65) instead of writing yet another 6502 assembler; it might even be possible to incorporate cc65 itself with the simulator.
